Epson PowerLite Pro Cinema LS10000 3LCD Reflective Laser
  • Αγαπητοί φίλοι και φίλες.
Browser
10,575
[h=2]A 3LCD Reflective laser home theater projector featuring 4K Enhancement.[/h] The elite Pro Cinema LS10000 home theater projector combines revolutionary 3LCD Reflective laser projection and 4K Enhancement Technology[SUP]2[/SUP] for the ultimate movie theater experience. Immerse yourself in stunning, crystal-clear images with unbelievable detail, even close to the screen. Offering 1500 lumens of color brightness and 1500 lumens of white brightness[SUP]1[/SUP], the LS10000 also boasts an unprecedented Absolute Black contrast ratio, wider color gamut, richer colors and smoother gradations. Full HD 1080p and 4K content come alive in amazing 2D and 3D with Super Resolution and frame interpolation technologies. ISF® calibration tools ensure color accuracy. And, installation is easier and more flexible than ever.
  • Experience 4K Enhancement — revolutionary 4K Enhancement Technology[SUP]2[/SUP] for unbelievable sharpness, clarity and detail
  • One measurement of brightness is not enough — look for both high color brightness and high white brightness.
    The Pro Cinema LS10000 has:
    • Color Brightness: 1500 lumens[SUP]1[/SUP]
      White Brightness: 1500 lumens[SUP]1[/SUP]
  • Laser light source — lamp-free design ensures high-speed contrast control and wider color gamut with rapid warm-up and cool down
  • 3LCD Reflective technology — improved pixel density, increased aperture ratio and fast performance for incredibly smooth, film-like picture quality
  • Absolute Black contrast ratio — together, the 3LCD Reflective system and laser light source deliver unprecedented black levels, displaying zero lumens during full-black scenes
  • Full HD 1080p in 2D and 3D — Super Resolution with Detail Enhancement and frame interpolation technology deliver a stunning viewing experience; RF 3D glasses included
  • Superior image quality — ISF calibration tools and THX® Display Certification ensure accurate and exceptional performance, the way filmmakers intended
  • Easy installation and image adjustments — 2.1x power zoom, power focus and extraordinary lens shift (90 percent vertical, 40 percent horizontal)
  • Lens position memory — store up to 10 settings in the projector memory, including zoom and focus positions for standard 16:9 or 4:3 projection areas, and 2.35:1 wide cinema ratio
  • Expansive color space — get broad color reproduction with DCI and Adobe RGB modes
[h=3]Specifications[/h]
Projection System: 3LCD Reflective 3-chip technology
Projection Method: Front / rear / ceiling mount
Product Color: Black
Driving Method: Epson Poly-silicon TFT Active Matrix, 0.74-inch wide panel Reflective HTPS
Projected Output: HD, 2D, 3D, 1080p
Pixel Number: 2,073,600 dots (1920 x 1080) x 3
Color Brightness (Color Light Ouput): 1500 lumens[SUP]1[/SUP]
White Brightness (White Light Output): 1500 lumens[SUP]1[/SUP]
Aspect Ratio: 16:9 widescreen (4:3 resize) Compatible with 4:3 and 2.35:1 video formats with Normal, Full or Zoom Modes
Native Resolution: 1080p (1920 x 1080)
Resize: 16:10, 4:3
Laser Type: Laser Diode 41.9 mW (Output)
Light Source Life: Up to 30,000 hours (ECO Mode)[SUP]2[/SUP]
Throw Ratio Range: 1.28 (Zoom: Wide), 2.73 (Zoom: Tele)
Size (projected distance): 100" diagonal (wide: 9.3' – tele: 19.8')
Keystone Correction: ±30 degrees
Contrast Ratio: Absolute Black (Full White 1500 lumens / Full Black 0 lumens)
Color Reproduction: Up to 1.07 billion colors
Color Processing: 10 bit (Partial 12 bit)
[h=3]Projection Lens[/h]
Type: Powered Optical zoom/ Powered focus
F-number: 2.5 – 3.7
Focal Length: 21.3 mm – 44.7 mm
Zoom Ratio: 1.0 – 2.1
Lens Shift:
  • Vertical: 90% max (up and down with horz. centered)
  • Horizontal: 40% max (left and right with vertical centered)
Lens Cover: Powered, Slide Lens Shutter
[h=3]Other[/h]
Lens Position: the following 3 items are saved in memory: Lens Shift Position / Zoom Position / Focus Position
Memory Positions: 10 (Memory 1 – 10)
Picture-in-Picture: Yes (HDMI® only)
Display Performance: 1920 x 1080 native 1080p; HD, 2D, 3D, 2D to 3D conversion
Color Modes: Dynamic, Living room, Natural, THX, Cinema, B&W Cinema, Adobe RGB, Digital Cinema, 3D Dynamic, 3D Cinema, 3D THX
Lens Iris: Fine adjustments
Super Resolution: 4K Enhancement Off / 1 / 2 / 3 / 4 / 5 / 4K-1 / 4K-2 / 4K-3 / 4K-4 / 4K-5
Deinterlacing: Film / Auto, Video, Off
Frame Interpolation: Off / Low / Normal /High (2D and 3D Mode)
Pull Down: (1080/24p) 10:10 pull down
Epson Super White: Controlled automatically adjusting to HDMI source (Available at Natural / THX / Cinema / B&W Cinema / 3D Cinema / 3D THX, User selectable On/Off on OSD)
Input Signal: HDMI: 480i/576i/480p/576p/720p/1080i/1080p/ 4K x 2K
Terminal Outputs: (2 x) configurable as Screen Power or Anamorphic Lens - Trigger On/Off (3.5 mm mini-stereo jack) each - 12 VDC 200 mA (max.)
Computer Compatibility: PC, Mac®
Interfaces:
  • HDMI x 2
  • RS-232c x 1
  • RCA (composite) x 1
  • RCA (component) x 3
  • VGA D-sub 15 pin (computer input) x 1
  • Wired LAN (RJ45, 100 Mbps) for command and Control only x 1
Operating Temperature: 41° to 95° F (5° to 35° C)
Power Supply Voltage: 100 – 240 VAC ±10% , 50/60 Hz
Power Consumption:
  • ECO mode: Laser on 267 W
  • Standby mode: 0.29 W
Fan Noise: 19 dB – 28 dB (4K Enhancement: Off)
Security: Kensington Security Lock Port
[h=3]Notes[/h]
[SUP]1[/SUP] Color brightness (color light output) and white brightness (white light output) will vary depending on usage conditions. Color light output measured in accordance with IDMS 15.4; white light output measured in accordance with ISO 21118.
[SUP]2[/SUP] 30,000 hours is the estimated projector life when used in ECO Mode. Actual hours may vary depending on usage environment. The projector comes with a three-year limited warranty, described in the warranty statement.
4K Enhancement Technology shifts each pixel diagonally by 0.5 pixels to double the resolution to 3840 x 2160 and surpass Full HD image quality. Resolution is 1920 x 1080 in 3D Mode.
www.epson.com
Review απο το projectorcentral
http://www.projectorcentral.com/epson_ls10000_projector_review.htm?em
Babis K.
28,484
Απάντηση: EPSON PowerLite Pro Cinema LS10000 3LCD Reflective Laser
Δείχνει πολύ καλός !!!
Εδώ ίσως έχουμε ένα θεματάκι αλλά γενικά τα νέα είναι ελπιδοφόρα...
"Black Level Performance
The Pro Cinema LS10000 has the deepest black levels I’ve seen yet from Epson. From a practical standpoint it does better than Epson’s less expensive UB series, which set the standard for under $4000 projectors several years ago, and those haven’t been bested yet for under that price point, although there’s serious competition.
I do not believe that this Epson is a match for the projectors with the very best black levels out there. I’m talking about the $8000 and $12000 JVCs, they remain the champs, but, that said, the black level performance is better than the Sony HW55ES and JVC X35, and even Sony’s $15K VW600ES true 4K machine. How it stacks up against Sony’s $27,000 VPL-VW1100ES is a good question, one I expect to answer soon as I’m expecting that Sony to arrive shortly after the Cedia show (9/2014), so I’ll be able to do side by side comparisons.
As I have always said, great black levels have been the “holy grail” of home theater performance. That’s the difference between good $2000 projectors (or good $5000 projectors…) and great ones. But I’ve also said that once black levels achieve a certain level of excellence, while even better is always desirable, that’s the point where other aspects of the projector become more important than further black level improvement".
Τα Bold είναι υπογράμμιση δική μου...
3 July 2006
206
Re: EPSON PowerLite Pro Cinema LS10000 3LCD Reflective Laser
Μπάμπη, ας μην ξεχνάμε ότι είναι και μοντέλο προ-παραγωγής. Θα υπάρχουν αρκετές βελτιώσεις στο μοντέλο παραγωγής.
Νομίζω ότι ήρθε ο καιρός να ολοκληρωθεί ο προβολικός σου κύκλος: Με Epson ξεκίνησες, με Epson Θα τελειώσεις!
Ειδικά τώρα με την μεγαλύτερη οθόνη, θα έχεις σταθερή φωτεινότητα και χρωματική απόδοση για πολυυυυυυυυυυυύ καιρό!
Babis K.
28,484
Νικόλα, όπως λές, με Epson ξεκίνησα και (ίσως) κάποτε να "κλείσω" με Epson αλλά νομίζω είναι νωρίς ακόμα...
Είπαμε: Great black levels have been the "€œholy grail"€ of home theater performance. :ernaehrung004:
spcav
18 August 2006
16,549
Καλα, η καραμελα με τα προ-παραγωγής δεν παίζει.
Αυτά τα λεγανε κατι συντάκτες του hitech για να δικαιολογήσουν ελαττώματα.
(δεν εννοω κατι προσωπικό προφανώς :p)
Ποτε δεν θυμαμαι ουσιαστική βελτίωση σε μοντέλο παραγωγής vs προ-παραγωγής.
Εξάλλου, σκεψου ότι καμια εταιρία δεν ρισκάρει να στείλει για review μοντέλο που δεν δίνει το full των δυνατότητών του - θα ταν κακή κίνηση.
Φτου! Χτυπα ξύλο, τον πέθανες τον άνθρωπο :p
No worries Bikos, ο 700 δεν αλλαζει για 1,5 χρονο ακόμη.
Babis K.
28,484
Απάντηση: Re: EPSON PowerLite Pro Cinema LS10000 3LCD Reflective Laser
Δεν ανησυχώ... Απλά δεν ξέρω αν θ´αντέξω... :p
3 July 2006
206
Πράγματι είναι νωρίς ακόμη. Πιστεύω ότι σε 3-4 χρόνια όταν θα υπάρχουν προβολείς 4Κ με laser φωτισμό σε "προσιτές" τιμές, πολύς κόσμος θα θελήσει να απαλλαγέι από τις λάμπες και να ηρεμήσει για αρκετά χρόνια.
JL_?
19 September 2008
15,415
Terra
Καλά, αυτό το ακούω ως επιχείρημα κοντά μια δεκαετία τώρα. Βέβαια, οι περισσότεροι κάτοχοι βιντεοπροβολέων που γνωρίζω, αλλάζουν προβολέα πριν χρειαστεί να αλλάξουν λάμπα... :silly: :laugh:
Babis K.
28,484
Έτσι είναι κυρίως γι´αυτούς που χρησιμοποιούν πάρα πολύ τον προβολέα, γι αυτούς που τον χρησιμοποιούν και σαν τηλεόραση ή παίζουν παιχνίδια.
Για μένα που "γράφω" λίγες ώρες, αλλά αυτό που βλέπω θέλω να το απολαμβάνω, οι 30.000 δεν είναι και η μεγαλύτερή μου έννοια. 'Οχι οτι δεν με νοιάζει ή δεν θα ήθελα να βγάλω στον Καστρουνή στην ανεργία αλλά πάνω απ´όλα μετράει η εικόνα.
Αν κάποιος προβολέας, στις οικονομικές μου δυνατότητες, "βγάλει" καλύτερη εικόνα απ´τον 700-άρη το συζητάμε... Μέχρι τότε ηρεμία και προσευχή. :coool:
Υπάρχουν τέτοιοι; :p
spcav
18 August 2006
16,549
Re: Απάντηση: Re: EPSON PowerLite Pro Cinema LS10000 3LCD Reflective Laser
Ελα ρε...
Εδώ πήραμε ένα ακόμη μηχανακι (το οποίο όμως, ΟΚ, ένανε τη διαφορα) λιγο πριν τα 4Κ και τωρα μου σκέφτεσαι και γι άλλο (και μαλιστα EPSON :p) ;
Θα σε μαλωσω....κακό παιντί....:p
Φήμες....:p
Browser
10,575
Καλα ειναι τα "δισκοποτηρα" κι ολα και συνφωνω.
Απλα θα γινουμε ολοι "πλουσιοτεροι" αν κατα την επιλογη ενος μηχανηματος λαβουμε σοβαρα υπ'οψιν το χωρο στον οποιο θα το τοποθετησουμε.
Τι να το κανω να εχει το "απολυτο" μαυρο οταν τον βαλω στο κατασπρο σαλονι μου.....
Μπαμπη, ειδες μεγαλη διαφορα στο μαυρο απο τον 55 στον 700? Ρωτω ειλικρινα γιατι τον 700 στο χωρο σου δεν τον εχω δει.
Babis K.
28,484
Ναί, κι εμένα μου έκανε μεγάλη εντύπωση αλλά η διαφορά είναι σημαντική.
Browser
10,575
[video=youtube;aT-b6yVjY0E]https://www.youtube.com/watch?feature=player_embedded&v=aT-b6yVjY0E[/video]
nektar
4 January 2007
4,326
Μελίσσια
Πιστεύω το μεγάλο πλεονέκτημα μιας τέτοιας υλοποίησης είναι οι ώρες λειτουργίας (30,000) και η μη πτώση της φωτεινότητας με την πάροδο του χρόνου αν τα έχω καταλάβει σωστά. Αυτό σημαίνει ότι ένας τέτοιος προβολέας μπορεί να βρει πιο άνετα την θέση του σε ένα σαλόνι καθώς μπορούμε εκεί να βλέπουμε άνετα και πράγματα που δεν θα τα βλέπαμε για να μην κάψουμε λάμπα (π.χ. αθλητικά, καμιά ταινία στο Nova, να παίζουμε παιχνίδια κλπ κλπ).
Εμένα δεν θα με πείραζε να χάσω λίγο σε εικόνα σε σχέση π.χ. με ένα JVC και να έχω τις παραπάνω ευκολίες και να μην έχω το άγχος των ωρών στην λάμπα. Για να δούμε βέβαια και πως θα παίζουν και πόσο θα κάνουν.
365 χ 3 ώρες την ημέρα (που δεν είναι τόσες) = 1095 τον χρόνο.
Οπότε καταλαβαίνουμε όλοι ότι στην 5ετία μας παίρνει μέχρι και να τον πουλήσουμε :p
vas_papavas
21 December 2010
8,849
Re: Απάντηση: EPSON PowerLite Pro Cinema LS10000 3LCD Reflective Laser
και εγώ αυτό εισπράττω με την στροφή στο laser. Λέμε το 4κ θέλει ίντσες και οι προβολάκηδες το έχουν πιάσει το νόημα και κινούνται αναλόγως στη λογική ο προβολέας να χρησιμοποιείται πέρα από ταινίες.
Babis K.
28,484
Καλά όλα αυτά αλλά (σχεδόν) τα ίδια λέγαμε και για τους Led αλλά αποδείχτηκε άνθρακας ο θησαυρός.
Μέχρι να δούμε τι πραγματικά συμβαίνει, υπομονή, ηρεμία και προσευχή. :grandpa:
Browser
10,575
To θεμα ειναι οτι καποιοι ειδαν εξω και τα σχολια ειναι ιδιαιτερα ενθαρυντικα !
Babis K.
28,484
Γιατί, για τους Led τα πρώτα σχόλια ήταν αποθαρυντικά; Μακάρι να είναι όπως τα λένε κι ακόμα καλύτερα...
Όχι τίποτε άλλο, αλλά να μην κυνηγάω και το καημένο που βλέπει Youtube στον προβολέα...:flipout:
