Lola by Blue
Gojakla
20 May 2009
5,856
Περιμένοντας τον Μιχάλη να μας γράψει εντυπώσεις, παρουσιάστηκε και η αδελφή Lola.
Meet Lola
Παρακάτω οι διαφορές της Λόλας απο τον "μεγάλο" αδελφό...
The new Lola builds on Blue's success with their Mo-Fi headphone, while responding to specific suggestions for improvement. As such, the Lola is neither a successor nor a total re-imagining of the Mo-Fi. Rather, it is an extension, distillation and refinement of concepts first introduced in the Mo-Fi when it was launched last year (2014). The main differences in the Lola are as follows:
Passive Output:
The Lola does not include a built-in amp like the Mo-Fi does. For me, this makes perfect sense as the Mo-Fi's passive mode offered me the best overall balance in terms of frequency response. By removing the amp, I no longer have to deal with having to charge the headphone. I also don't have to bear the weight of an amp or its associated components (like batteries).
Re-Engineered Gimbals:
While the superstructure remains the same, Blue has re-engineered the gimbals for an easier and more comfortable fit. And while this is a subtle modification, it does lead to a more significant change in the form of...
Streamlined Design:
Along with the new and improved gimbal design, and the resulting improvement in comfort, there now less of a need for the tension adjustment mechanism that was built into the top of the headband. As such, it has been removed from the Lola. This reduces complexity, points of failure, and most importantly - weight.
Reduced & Redistributed Weight:
Due to the removal of the tension adjustment mechanism - as well as the removal of the built-in amp - the new Lola is now noticeably lighter than the Mo-Fi. Whereas the Mo-Fi weighed in at 466 grams, the new Lola is now 397 grams. In addition, since the tension adjustment mechanism has been removed from the top of the headband, the overall weight has been redistributed away from the top of the head... resulting in a reduced hot spot and a headphone that feels lighter than it is.
SPECS
DRIVERS
• Type and size: 50mm, fiber-reinforced dynamic driver
• Impedance: 42 ohms
• Frequency response: 15Hz-20kHz
• Enclosure details: Sealed enclosure with tuned damping materials
HEADPHONES
• Weight: 397 g (14 oz)
• Outer dimensions (closed): 21cm x14cm x12cm (8.27" x 5.51" x 4.72")
• Outer dimensions (open): 18cm x 29cm x 12cm (7.09" x 11.42" x 4.72")
$249.99
Sonus Naturalis
12 July 2009
9,099
Αθήνα, Ηλιούπολη
Re: Mo-Fi by BLUE: World's First Powered Headphones
Λοιπόν η Lola ανταποκρίνεται σε προτάσεις για βελτίωση που σκέφτομαι από καιρό.
Ειδικά το βάρος είναι νομίζω το κυριότερο θέμα που έχουν τα ακουστικά.
Να πώ τώρα ότι θέλω και τη Λόλα στο "χαρέμι" μου; :laugh:
Manosss
7 June 2012
2,251
Πειραιάς
Η συγκεκριμένη λόλα τα κάνει όλα?
Δηλαδή παρόμοιο ήχο , με μειωμένο βάρος, καλύτερη άνεση και φορητότητα σε καλύτερη τιμή?
dimmanoukas
11 March 2009
900
ΑΘΗΝΑ
Και πανω που ελεγα οτι μου εφευγε η ιδεα του ακομη ενος ζευγους ακουστικων...τσουπ η Λολα
Θεματα εδαρμογης για μενα δεν υπηρχαν και στα mo-fi
Οποτε εαν ειναι πιο ελαφρια τοτε ακομη ενα μεγαλο + στην ανεση (για εμενα ξαναλεω γενικα πρεπει να ρυθμιστουν σωστα και μετα ειναι πολυ ανετα)
Χωρις ενισχυτη...καλυτερα καθως δεν τον χρειαζομουν ουτως η αλλως
Η τιμη εαν παιξει καμια προσφορα στα 200 θα ειναι πολυυυυ μεγαλη προκληση
(Εαν εχουν και ενα μεγαλυτερο αερα σε ολο το φασμα τοτε φανταζουν το απολυτο deal ειδικα σε μαυρο χρωμα που ειναι πανεμορφα)
Οποτε στα things to do οταν με το καλο κυκλοφορησουν και προς τα εδω
Δημοκηδής
23 June 2006
9,967
Φιλαράκ'! Μόνο μιά Λόλα ξέρουμε εμείς
υπάρχει και μια Λόλα που κάνει καταπληκτικό σπιτικό παγωτό-γιαούρτι με γεύση πορτοκάλι στην Καρδαμύλη ... υπάρχει και η Λόλα το τρεχαντήρι του Τίκβερ ...
Gojakla
20 May 2009
5,856
Εγω παντως δεν μπορω να ξεπερασω το ποσο ασχημα ειναι. Εντελως προσωπικη γνωμη.
Σαν ηχος μου αρεσαν πολυ.
MakisM
12 May 2009
5,360
Πιστεύω ότι το Mo-Fi είναι ένα ψαγμενο ακουστικό που αν το φορέσεις σωστά ακούγεται περισσότερο σαν ηχείο.
Ναι σαν ήχος μου άρεσε ,με πολύ καλή ποιότητα κατασκευής για τα λεφτά που ζητάει...Σίγουρα το καινούργιο θα είναι πιο ελαφρύ αφού απουσιάζει ο ενισχυτής.
asahi
27 March 2011
122
ισως το πετυχαν αυτη τη φορα..αμα βγει και σε μαυρο, το ξαναβλεπουμε..
Manosss
7 June 2012
2,251
Πειραιάς
Τhe empire strikes back :flipout:
Kαλως ήρθες πίσω στο άθλημα!
Να τα ευχαριστηθείς. Περιμένουμε εντυπώσεις
