Teclast X98 Pro
ΒΛΑΣΙΔΗΣ
19,341
Σε χώρες σαν τη δική μας γίνεεται ψιλοχαμός με τα teclast ειδικά το x98 για android. Τώρα όμως κυκλοφορεί και το αντίστοιχο win ή διπλό με τιμή στα 220 τόσα ευρώ και με hardware τουλάχιστον ενδιαφέρον . Αξίζει σχετικά με τα άλλα που κυκλοφρούν και στην Ελλάδα π.χ. to HP pavillion X2 που έχει πολύ υποδεέσστερο hardware?
CPU: Intel Atom X5-Z8500 (Cherry Trail T4 Z8500) Quad Core 1.44GHz ( up to 2.24GHz ) has a better performance, sixty percent power consumption reduction and almost half package areas than the 32-bit processor, delivering plenty of power for multitasking and fueling casual games and movies.
GPU: Grafis intel HD Gen8 processor is better and faster in playing games and watching videos than the previous generation.
RAM + ROM: 4GB + 64GB offers ultrafast surfing online, video playing and 3D gaming experience enhanced with LPDDR3 memory which makes all applications faster. Whether it is needed for work, study or play this tablet will suit your needs.
Gravity sensing system: Can fluently and sensitively run various applications.
9.7 inch screen: 2048 x 1536 QXGA IPS screen offers good experiences for watching videos and browsing the Web.
Windows 10 + Android 5.1 system: Latest Windows system with more excellent interface, compatibility and running effect.
8000mAh battery: can manage the current, power and the temperature and increase the performance dynamically.
Bluetooth 4.0: Supports fast transmission of data, pictures and files.
OTG Function: Can connect with keyboard, mouse, projector and so on.
HDMI output: You could use a HDMI cable to connect your tablet to output the tablet display onto TV screens, monitors or projectors, creating your personal home theater.
Dual cameras: 5.0MP back camera with auto focus makes HD video recording and video calls more clearly and vividly. And you will be surprised at 2.0MP front camera for selfie.
Other functions: WiFi/MP3/MP4/Calendar/Calculator supported.
Delicate design, portable and comfortable to touch.
http://www.gearbest.com/tablet-pcs/...b506BL-o5MWW2RC6aTbc4lpy3Tn_-Dr0sAaAtST8P8HAQ
tmjuju
Administration Team
21 January 2007
21,651
Γενικά είναι λίγο αργά στη χρήση σαν υπολογιστές, όλα με τον αντίστοιχο επεξεργαστή
Μπορείς να δοκιμάσεις κάποιο αντίστοιχο σε κοτσόβολο mediamarkt etc Έχουν αντίστοιχα μηχανάκια acer hp lenovo etc. (+100 με +200 ευρω από αυτό που είδες)
H RAM οριακή
Ο SSD πολύ μικρός, και πιθανότατα και αργός (όχι κανονικός ssd αλλα κατι που περισσότερο θυμίζει usb stick)
Σίγουρα θα θες έξτρα χώρο και usb sticks ή sdcard
Είναι περισσότερο δλδ ταμπλέτα παρά PC
Εάν το θες για ελαφρύ μεταφερόμενο που θα έχεις μόνιμα στο backpack θα σε βολέψει για μικροδουλειές στο δρόμο καφετέριες κ.ο.κ.
Εάν θες να αντικαταστήσεις φορητό ή κανονικό υπολογιστή δεν είναι και η καλύτερη λύση
Αρά πήγαινε σε ένα πολυκατάστημα, δες αντίστοιχα μηχανάκια και την απόδοση τους και αποφασίζεις
Η τιμή του είναι καλή σε σχέση με τα επώνυμα, από ποιότητα μιας και δεν το έχω πιάσει στα χέρια μου δεν ξέρω
alextrela
28 November 2011
3,129
Σαν hardware και εξοπλισμο ειναι σε υψηλα επιπεδα εφόσον ξέρεις τα όρια του βέβαια.
Στην ουσία ειναι πολυ κοντά σε επιδόσεις i3 2-3 ετων και low-mid χρηση.
Στην τιμή θα ελεγα ειναι ο ορισμός του value for money αλλα απο την αλλη δεν γνωρίζω την υλοποίηση σε βάθος χρονου ποσο αξιόπιστη ειναι.
Εφόσον σε ενδιαφέρει βέβαια ο τομέας αξιοπιστία και λειτουργικοτητα σε υψηλό επίπεδο σε βάθος χρονου διοτι δεν υπαρχουν και πολλά review για τέτοιες συσκευες.
Μονο οτι λένε χρήστες στα κινεζικά σκρουτζομαγαζα.
Ο δίσκος ειναι μορφής eMMC flash και εφόσον ειναι υψηλής ποιότητας προσεγγίζει ταχύτητες παραδοσιακού HDD 7200 στροφών δηλαδη 120-140mb/s στην ανάγνωση και 60-80mb/s στην εγγραφή.
tmjuju
Administration Team
21 January 2007
21,651
Απάντηση: Re: Teclast X98 Pro
αν θες επιδόσεις λαπτοπ αυτό http://www.gearbest.com/tablet-pcs/pp_232112.html είναι καλύτερη επιλογή με core m και κανονικο replaceable ssd,ποιο ακριβό βέβαια
Core m & Wacom … σε αυτή την τιμή … ε ρε τι πληρώνουμε στα επώνυμα …
O m2 να φανταστώ ssd πρέπει να αλλάζει εξαιρετικά δύσκολα, όπως σε όλα τα αντίστοιχα tablets
leo06
14 October 2007
6,732
Πάτρα
Re: Απάντηση: Re: Teclast X98 Pro
όχι, δεν είναι τόσο δύσκολο, http://forum.xda-developers.com/windows-8-rt/general/cube-i7-stylus-t3151563 ο δίσκος είναι 2242 και είναι ποιο δυσεύρετοι
το δικό μου το έχω ανοίξει δυο φορές,300 το είχα αγοράσει από geekbuying
ΒΛΑΣΙΔΗΣ
19,341
Παναγιώτη εκείνο αν θυμάμαι καλά ήταν μόνο android και μόνο 2gb. Αυτό όμως θα είναι dual boot και με 4gb. Σκέψου ότι μπορεί να κάνεις ακόμη και βασική photoshop επεξεργασία. Και το άλλο που στοιχίζει 300 ευρώ είναι ουσιαστικά πλήρης ΗΥ, άρα αν θέλεις κάτι μεγαλύτερο σε οθόνη πολύ απλά τον συνδέεις σε ένα 24άρη και βλέπεις το φως το αληθινό.
ΒΛΑΣΙΔΗΣ
19,341
Το x98 pro μάλλον σταμάτησε να παράγεται. στη θέση του θα αρχίσει να κυκλοφορεί το x98 plus με λίγο πιο αδύναμο επεξεργαστή, αλλά με διπλάσια διάρκεια μπαταρίας και μάλλον λιγότερα θέματα θέρμανσης ή υπερθέρμανσης.
http://techtablets.com/teclast-x98-plus/review/
