Sony α6300 - παρουσίαση και φωτογραφική χρήση
22 June 2006
34,775
NEO HRAKLEIO
μολις ανακοινωθηκε η α6300 with 4K internal recording με full pixel readout .
A6300 Key specs:
new 24MP sensor
11fps
4D focus
4K video (no pixel binnning 14 stops dynamic range)
world’s fastest af 0,05 sec
425 phase detect AF points
Ships in March for $1000
πολυ σημαντικο αυτο...
Of note is the fact that the camera’s 425 phase detection AF points, enhanced tracking and focus accuracy are all available on the α6300 when using A-mount lenses4 with a mount adaptor like the Sony LA-EA3. This is a first for Sony E-mount interchangeable lens cameras with an APS-C sized sensor, as the only other cameras to feature this capability are the full-frame α7R II and α7 II models.
κι επιτελους slog3 και στην α6300 , οπως kai 120 fps στα 1080p !
Και νεο EVF, το πρωτο στο ειδος του... "The a6300 is capable of uninterrupted live view at up to 8fps "
udt71
13 October 2006
1,792
Deep Sea
Απάντηση: Sony A6300
Sony A6300
Sensor:
24.2-megapixel CMOS sensor with copper wiring
14-stops of dynamic range
Performance:
Eight frames-per-second continuous live view
11 fps with no autofocus between frames
Autofocus:
0.05-second autofocus with 425 points
World's highest number of autofocus points covering entire image frame
High-density tracking autofocus technology activates large number of points surrounding the subject, tracks at 11 fps
Supports phase-detect AF with older lenses
Viewfinder:
XGA OLED TruFinder
"the advantages of electronic preview with the immediacy of an optical viewfinder"
"the A6300 truly connects you with the action like no other camera can"
Video capture:
4K video capture in Super 35mm format with full-pixel readout, no pixel binning
"Best 4K video in a Sony consumer camera ever"
2.4x oversampling from downsampling 6K sensor data
120 fps high frame-rate video
S-Log and S-Gamut
Coming in March 2016, priced at US$1,000 body-only or $1,150 for a kit (with what appears to be a 16-50mm lens)
New G Master lens series
"From the design stage, we have to take resolving power to a higher level"
"Supreme blend of high resolution and beautiful bokeh"
XA (Extreme Aspherical) lens elements, gives groundbreaking spatial spatial frequencies of 50 line pairs per mm, vs the 30 lp/mm that's common in the industry
XA elements with 0.01 micron surface precision eliminates abrupt defocusing transitions. (Probably also eliminates onion ring bokeh.)
Can bond two elements together also, to take XA to the next level
Also have advanced simulation tech, to make it possible to control bokeh right from the design stage
"Incredible resolution, not only in the center, but also in the corners"
Optimized for both still and video
Focus drive is silent, iris activation is silent, will also continuous AF very fast
Use different drive techniques on each lens
Direct Drive Supersonic Motor DDSM, silently moves heavy focus groups with 0.01mm precision.
Supersonic Motor (SSM) Dual Linear motor ring for front AF group, linear motor drives dual floating rear group, a first.
New G Master lenses are as follows:
Sony FE 24-70mm f/2.8GM, available March @ US$2,200 ($2,900 Canadian)
Sony FE 85mm f/1.4GM, available March @ US$1,800 ($2,400 Canadian)
Sony FE 70-200mm f/2.8GM OSS, available May with no information yet on pricing
1.4x / 2x teleconverters for 70-200mm f/2.8
22 June 2006
34,775
NEO HRAKLEIO
Re: Απάντηση: Sony A6300
Υποθέτω οτι τα 425 point AF detection θα λειτουργούν και με e-mount φακούς.
προφανως με e mount λειτουργουν.... αλλα το θεμα ειναι οτι λειτουργουν και με τους A mount φακους και τον απλο και οικονομικο ανταπτορα LAEA3 , χωρις καθρεπτη .
Κριμα που δε βαλανε παλι μια touch screen.... :smash:
jtheogr
13 July 2010
806
Καλαμάτα
Σημαντικό επίσης για τους βιντεάδες το παρακάτω όπως και τα s-log.
In another first for non-full-frame Sony interchangeable lens cameras, the new α6300 offers internal 4K movie recording in Super 35mm format. When shooting in 4K, the camera uses full pixel readout without pixel binning to collect 20 megapixels of information – approximately 2.4x[vi] (6K equivalent) as many pixels as 4K UHD and then oversamples the information to produce high quality footage with exceptional detail and depth.
jtheogr
13 July 2010
806
Καλαμάτα
Και εγώ την περίμενα την touch , θα μας έκανε τη ζωή εύκολη και παιχνιδάκι το rack-focus.
Αλλα έβαλαν είσοδο για μικρόφωνο απο οτι διάβασα.
22 June 2006
34,775
NEO HRAKLEIO
Re: Sony A6300
ανοιγει και ο δρομος για AF με υψηλη ταχυτητα και με third party lenses με το καταλληλο ανταπτορα , απο canon - sigma, nikon κλπ οπως και με την A7rII , αυτο για πολλους θα ειναι μεγαλο δωρο .
vamvakoulas
30 April 2011
528
Οι φωτο που παραθεσατε παιδια ειναι οι πραγματικες ή φτιαχτές? Γιατι αν ειναι πραγματικες μαλλον τους ειχαν μεινει σασι απο 6000 και βαλανε τα ιδια :D
Η μονη διαφορα που βλεπω ειναι οτι τυπωσαν το 4Κ και εβαλαν και διακοπτη στο ael.
Σταθης
Banned
24 June 2006
1,175
Γλυκόπικρη γεύση για 'μένα που περίμενα πως και πως το IBIS.
Γιάννη, αν θες κάνε άσπρα τα γράμματα στο πρώτο νήμα γιατί δε φαίνεται τίποτα.
jtheogr
13 July 2010
806
Καλαμάτα
Οι επίσημες φώτο είναι.
Το πιθανότερο είναι να μην χωρούσε IBIS σε αυτό το σώμα.
cacau
7 June 2008
20,338
Re: Sony A6300
Κρίμα για το IBIS, δείχνει πολύ ενδιαφέρουσα κατά τα λοιπά. Να δούμε τι λέει ο νέος αισθητήρας σε συνδυασμό με τους νέους φωτεινούς φακούς - που είναι λίγο γκουμούτσες, αλλά δείχνουν την σοβαρότητα και την δέσμευση της εταιρείας στο APS-C format...
evanfotis
26 March 2008
5,475
Κριμα το IBIS αλλα η έλλειψη touch screen με επιλογή AF point στο βίντεο είναι που μας τα χάλασε..
http://www.eoshd.com/2016/02/6k-ove...-1000-impressive-sony-a6300-to-ship-in-march/
Και επιτέλους f/2,8 FE lenses!!!
