Asus Transformer 3 Pro/Transformer 3 (Intel 7th Generation CPU)
alextrela
28 November 2011
3,129
Brand new 2 in 1 by Asus from Computex 20156 unveiled few minutes ego.
http://www.engadget.com/2016/05/30/asus-transformer-pc/#gallery=390823&slide=3905681&index=2
http://www.windowscentral.com/asus-latest-transformers-take-surface-pro-4
http://wccftech.com/asus-transforme...surface-pro-4-to-shame-check-out-these-specs/
Both the Transformer 3 Pro and the Transformer 3 have a 12.6-inch display with a 2880 x 1920 resolution and 275 ppi pixel density. There are other similarities as well: Both feature USB Type-C and Thunderbolt 3 connections, Harmon Kardon speakers, and USB 3.0 and HDMI ports. They both also have built-in fingerprint readers. As you might expect, both 2-in-1s are also compatible with ASUS accessories such as the Pen, a Universal Dock, an AudioPod (a quad speaker with surround sound) and the ROG XG Station 2, a graphics dock that gives the humble tablet PC the power of a desktop computer (and it's VR-ready to boot!). Both tablets are available in Icicle Gold as well as Glacier Gray.
Of the two, the Transformer 3 Pro is the heftier one at 8.35mm thick. Its kickstand has a "stepless hinge" that lets you set the device at any viewing angle up to 170-degrees. The 3 Pro also comes with a Cover Keyboard that's backlit and offers "laptop-grade 1.4mm key travel" which ASUS says will provide a typing experience similar to that of a normal-sized notebook. It also boasts an Intel Core i7 processor and up to 1TB PCIe x4 SSD and 16GB of 2133MHz RAM. It has a 13-megapixel rear camera plus a front-facing one as well.
While the Transformer 3 has the same display size as the Transformer 3 Pro, the 3 is thinner and lighter with a thickness and weight of 6.9mm and 695 grams respectively. The Transformer 3 features a 7th generation Intel Core processor plus up to 512GB SSD and up to 8GB of RAM. Its display stand is not quite as flexible, with only two positions. It ships with a Transformer Sleeve Keyboard, also with 1.4mm of key travel and is available in the same four colors as the Cover Keyboard (Stone, Charcoal, Taupe, and Amber).
There are several other specification details that are common between the two products and they have been listed below:
USB Type-C port
Thunderbolt 3 port
USB 3.0 port
HDMI ports
Built-in fingerprint readers
Pen
A Universal Dock
An AudioPod (which is basically a quad speaker with surround sound)
The ROG XG Station 2 (a unique graphics dock that allows you to connect the slate to a powerful machine and grant it immense graphics horsepower)
Sent from my iPad Air 2
alextrela
28 November 2011
3,129
Re: Asus Transformer 3 Pro/Transformer 3 Intel 7th Generation CPU
Τελικά η οθόνη επιτέλους αποφάσισε η Asus να το γυρίσει σε 3:2 aspect.
Ιδιαιτερα θετικό γεγονός.
Επίσης το Transformer 3 Pro θα ενσωματώνει την τρέχουσα SkyLake σειρά επεξεργαστών ενώ αντίθετα το Transformer 3 θα ενσωματώνει την 7η σειρά Kaby Lake πιθανότητα την 3ή γενιά Core M.
Εδω τα full specs του Transformer 3 Pro που ειναι άμεσος ανταγωνιστής του Surface Pro 4.
http://www.asus.com/2-in-1-PCs/T303UA/
Current list of official specs:
Processor
Intel® Core™ i5 6200U Processor,
Intel® Core™ i7 6500U Processor,
Operating System
Windows 10 Home
Windows 10 Pro
Chipset
Integrated Intel® CPU
Memory
16 GB LPDDR3 2133MHz SDRAM Onboard Memory
Display
12.6" (3:2) LED backlit WQHD+ (2880x1920) Glare Touchscreen with 85% NTSC
Support ASUS Splendid Technology
With WideView Technology
Graphic
Integrated Intel HD Graphics 520
Storage
Solid State Drives:
128GB/256GB/512GB/1TB PCIE Gen3X4 SSD
Card Reader
Multi-format card reader
WebCam
Front 8 Mp and Rear 13 Mp
IR Camera
Networking
Wi-Fi
Integrated 802.11 AC (WIDI Support)
Bluetooth
Built-in Bluetooth V4.1
Interface
1 x COMBO audio jack
1 x USB 3.0 port(s)
1 x HDMI
1 x Thunderbolt port
Audio
Built-in Stereo 2 W Speakers And Array Microphone
Support Windows 10 Cortana with Voice
ASUS SonicMaster Premium Technology
Battery
39 Whrs Polymer Battery
Power Adapter
Plug Type :USB TYPE C
Output :
20 V DC, 2.25 A, 45 W
Input :
100 -240 V AC, 50/60 Hz universal
Dimensions
Tablet:
298.8 x 210.1 x 8.35 mm (WxDxH)
Weight
Tablet:
795 g
Security
TPM (Trusted Platform Module)
Και εδω του Transformer 3 που θα έλεγα μια βελτιωμένη εκδοχή του Tab Pro S της Samsung ειναι.
http://www.asus.com/2-in-1-PCs/T305CA/
Current list of official specs for the non-pro Transformer 3:
Operating System
Windows 10 Home
Windows 10 Pro
Memory
4 GB LPDDR3 1866MHz SDRAM Onboard Memory, up to 8 GB SDRAM
Display
Graphic
Storage
Solid State Drives:
256GB SATA3 M.2 SSD
Solid State Drives:
512GB SATA3 M.2 SSD
WebCam
Front 5 Mp and Rear 13 Mp
Networking
Wi-Fi
Bluetooth
Interface
1 x USB 3.1 TYPE C port(s)
Audio
Battery
38.5 Whrs Polymer Battery
Power Adapter
Output :
5 V DC, 2 A, 45 W
Input :
Dimensions
Tablet:
303 x 202 x 6.9 mm (WxDxH)
Weight
Tablet:
695 g
enoxos
6 July 2008
798
Κοζάνη
εχουμε πληροφορίες για το ποτε θα ειναι διαθεσιμο?
alextrela
28 November 2011
3,129
Για το 3 Pro λογικά εντός καλοκαιριού θα κυκλοφορήσει.
Για το σκέτο 3 απο Σεπτέμβριο και έπειτα μιας και θα κάνει χρήση της 7ης σειράς επεξεργαστών Kaby Lake.
evanfotis
26 March 2008
5,473
Απάντηση: Asus Transformer 3 Pro/Transformer 3 Intel 7th Generation CPU
Tέτοιο copy-paste στο σχέδιασμό δε το περίμενα απο την Asus (απορώ πώς πέρασαν τις επιτροπές σχεδιασμού, σίγουρα θα γίνουν μηνύσεις)...
Άλλες ιδέες δέν έχουν εκτός απο κάποια εξέλιξη στα specs;
enoxos
6 July 2008
798
Κοζάνη
φοβερο design και το μπλε χρυσό.Αναμονη μηπως ξεκινησουν κανα προωθητικο προγραμμα με δωρο το dock...!
alextrela
28 November 2011
3,129
Μια χαρά ειναι το form factor και το ντιζάιν.
Δεν νομίζω τεχνολογικά να μπορούσε να δώσει κατι διαφορετικό.
Κατα βάση η MS εχει οριοθετήσει και οι OEM ακολουθούν.
Μόνο το Intel smart frame ίσως αλλα εως τώρα μόνο σαν δοκιμαστικό το έχουμε δει και πουθενά στην πράξη.
Εκτος αν ήθελες κατι σαν Surface Book competitive με τις κάποιες βελτιώσεις/προσθήκες που επιδέχεται.
Βέβαια θα περίμενα DDR4 μνημη οπως και τι ψάρια θα πιάνει η γραφίδα.
Ελπίζω μην ειναι τίποτα Synaptics.
evanfotis
26 March 2008
5,473
Δέν είπα οτι υστερεί το design, είπα οτι είναι ξεδιάντροπα copy paste απο το surface και απορώ πως μια εταιρια προχωρά σε μια τέτοια υλοποίηση που πολύ πιθανών και δικαίως να έχει συνέπειες.
alextrela
28 November 2011
3,129
Re: Απάντηση: Asus Transformer 3 Pro/Transformer 3 Intel 7th Generation CPU
Αφού η MS τα "επιτρέπει".
Αυτός ηταν ο βασικός της σκοπός με την surface σειρά.
Να δώσει μια κατεύθυνση.
Καμία συνέπεια για κανέναν δεν θα εχει.
alextrela
28 November 2011
3,129
Πλουσιότατο φωτογραφικό υλικό απο τις νεες προτάσεις της Asus.
Περιλαμβάνεται και το mini 3 στις 10 ίντσες.
http://www.mobile01.com/newsdetail.php?id=18753
Και εδω φωτό απο την γραφίδα που πιθανότητα ειναι n-trig technology.
Αν αληθεύουν θα πρόκειται όντως για τις πιο πλήρης και ολοκληρωμένες ανταγωνιστικές προτάσεις ενάντι του SP4 σαν σύνολο και με αρκετα συν κυρίως απο άποψη θυρών επέκτασης.
alextrela
28 November 2011
3,129
Άρχισε σταδιακά η κυκλοφορία της συσκευής(3 Pro) αρχής γενομένης απο την Ινδία οπως ανακοίνωσε η Asus.
http://liliputing.com/2016/08/asus-...mium-tablet-launches-india-premium-price.html
Εντός τον επόμενων εβδομάδων μέσα στο Σεπτέμβριο λογικά θα κάνει την εμφάνιση του σε περισσότερες περιοχές του πλανήτη.
Θα κάνει και την εμφάνιση του στην IFA 2016 σε λιγότερο απο 2 εβδομάδες οπου λογικά θα μάθουμε την επίσημη τιμολόγηση στην Ευρώπη.
alextrela
28 November 2011
3,129
alextrela
28 November 2011
3,129
Επίσημη παρουσίαση στην IFA 2016 πριν λίγες ώρες οπου
ανακοινώθηκαν οι τιμες στην Ευρώπη για την νεα πρόταση της Asus και συγκεκριμένα για το Asus Transformer 3 Pro
http://mspoweruser.com/asuss-gold-surface-pro-clone-coming-europe/
Θα ξεκινάνε απο 1200 ευρω για την entry level i5/4/256 εως 1800 για την πλεον πλούσια έκδοση με i7/16/1TB SSD
It’starting at 1200 for the base secs and going all the way up to 1800 for the i7 equipped, 1TB SSD and 16GB of RAM powerhouse
Εδω και 2 επιπλέον hardware configuration option στις προτάσεις της Asus με επίσημη τιμολόγηση στην Ευρώπη οπως και στο Transformer 3 με Kaby Lake Core M CPU
Ολόκληρη η σημερινή παρουσίαση της Asus.
https://m.youtube.com/watch?v=4rrirmg3kyg
23,730
Πάντως επειδή η κατηγορία αυτή είναι καινούργια και πέφτουν κυριολεκτικά σαν βροχή τα μοντέλα, τα 1000 και 1500 είναι ΠΑΡΑ ΠΟΛΛΑ για κάτι που έχει ημερομηνία λήξης σε κάτι μήνες....
Μιλάω για 1000 και 1500 για να πάρεις κάτι που να αξίζει. Τα entry μοντέλα δεν τα εμπιστεύομαι γιατί θα σέρνοναι. Τα βγάζουν για να τα βγάζουν.
alextrela
28 November 2011
3,129
Καλώς η κακώς αυτο συμβαίνει σε κάθε τεχνολογικό προϊόν.
Κάθε χρόνο και νέο μοντέλο για να συντηρούν το ενδιαφέρουν του κόσμου διαρκώς και για να πιάσουν νεα καταναλωτικό κοινό που σκέφτεται να προβεί σε αναβάθμιση η αγορά μετα κάποια ετη χρήσης ενός πιο παλιού μηχανήματος.
Διαφωνώ όμως για τα entry level και οχι δεν θα σέρνονται.
Μια χαρά αξίζουν και σε βάθη 2-3 ετών εφόσον ξέρει ο οποιοδήποτε για ποιο λογο τα παίρνει και τι ανάγκες θέλει να καλύψει.
Δεν χρειάζονται οι περισσότεροι να ειναι εξοπλισμένα σαν αστακός για να εχει νόημα η αγορά τους.
