Microsoft Surface Studio (AIO)
soulkeeper
5 October 2006
1,984
ΚΑΛΑΜΑΤΑ
Αμάν αμάν.......:afro::drool1::worshippy:
https://www.microsoft.com/en-us/surface/devices/surface-studio/surface-studio
Tech specs
Dimensions/Weight Display: 637.35 mm x 438.90 mm x 12.5 mm (25.1” x 17.3” x 0.5”)
Base: 250.00 mm x 220.00 mm x 32.2 mm (9.8” x 8.7” x 1.3”)
Product weight: 9.56 kg max (21 lbs max)
Display Screen: 28” PixelSense™ Display
Resolution: 4500 x 3000 (192 PPI)
Color settings: Adobe sRGB and DCI-P3, individually color calibrated
Touch: 10 point multi-touch
Aspect Ratio: 3:2
Supports Pen enabled and Zero Gravity Hinge
Memory 8GB, 16GB, or 32GB RAM
Processor 6th Generation Intel® Core™ i5 or i7
Security TPM chip for enterprise security
Enterprise-grade protection with Windows Hello2 face sign-in
Software Windows 10 Pro
Office 30-day trial
What’s in the box
Surface Studio
Surface Pen
Surface Keyboard
Surface Mouse
Power cord with grip-release cable
Quick start guide
Safety and warranty guide
Booklet
Storage Rapid Hybrid Drive options: 1TB or 2TB.
Graphics
i5 Intel 8GB: NVIDIA® GeForce® GTX 965M 2GB GDDR5 memory
i7 Intel 16GB: NVIDIA® GeForce® GTX 965M 2GB GDDR5 memory
i7 Intel 32GB: NVIDIA® GeForce® GTX 980M 4GB GDDR5 memory
Connections & expansions
4 x USB 3.0 (one high power port)
Full-size SD ™ card reader (SDXC) compatible
Mini DisplayPort
Headset jack
Compatible with Surface Dial on-screen interaction*
1 Gigabit Ethernet port
Cameras, video and audio
Windows Hello1 face sign-in camera
5.0 MP camera with 1080p HD video (front)
Autofocus camera with 1080p HD video (rear)
Dual microphones
Stereo 2.1 speakers with Dolby® Audio™ Premium
3.5 mm headphone jack
Wireless
Wi-Fi: 802.11ac Wi-Fi wireless networking, IEEE 802.11 a/b/g/n compatible
Bluetooth: Bluetooth 4.0 wireless technology
Xbox Wireless built-in
Buttons/Keyboard Volume key and power key
Surface Pen
Surface Keyboard
Surface Mouse
Warranty 1-year limited hardware warranty
spcav
18 August 2006
16,598
Βρωμάει Apple στα πάντα
Απο το ίδιο το μηχάνημα (design) μέχρι το στήσιμο της ιστοσελίδας...
alextrela
28 November 2011
3,129
Καμια σχεση.
Μερα με τη νυχτα τα 2 μηχανηματα σε λειτουργια,δυνατοτητες,form factor,τυπος οθονης,aspect ratio γενικα κοινο στο οποιο απευθυνεται.
Ενας τεχνολογικος αβυσσος μεταξυ τους χωριζει.
Κατα τα αλλα ΕΚΠΛΗΚΤΙΚΟ αλλα και Πανακριβο.:violent-smiley-030::grinning-smiley-043
Αν κερδισουμε κανα τζοκερ κατι γινεται:flipout:
ωραιο... αλλα το βλεπω να περναει το τριχιλιαρο στην Ελλάδα!
Sent from my Nexus 6P using Tapatalk
Χαλαρα.
3500 το κοβω σε ευρω το entry level.:p
Δεν το συζητω τα πιο βαρβατα σε specs.
ΑΠΛΗΣΙΑΣΤΑ
pontios
6,734
Clermont-Ferrand, France
Σε τι ακριβώς βρωμάει apple? Στο ότι η οθόνη είναι τετράγωνη?
Και λίγα λες. Απλά δες πόσο έχουν τιμολογήσει το surface και το book. Αλλά είναι αδιάφορο από την στιγμή που μπορείς άνετα να παραγγείλεις από το Microsoft store Αγγλίας ή Γαλλίας ή Γερμανίας.
22 June 2006
34,776
NEO HRAKLEIO
στο οτι ειναι ενα μηχανημα ΟΛΑ ΣΕ ΕΝΑ, σαν τον imac, και στο οτι απευθύνεται πια στο ίδιο κοινο... που εχει πιο prestige.
το ανεφερε δεκαδες φορες στη παρουσίαση , η νεα εκδοση του λειτουργικου ονομάζεται creators version.
και η συγκριση, στη παρουσιαση, παλι με τα apple προϊόντα έγινε.
το θεμα ομως δεν ειναι μόνο το hardware αλλα το software... κι εκεί θέλει πολύ δουλειά.
alextrela
28 November 2011
3,129
Πάντως τις εκπτώσεις δεν τις απέφυγε η MS
Το μηχάνημα όντως σπέρνει από πολλές πλευρές και όντας το μοναδικό AIO θα τιμούσα αν σκεφτόμουν να μεταπήδουσα σε αυτή τη κατηγορία προϊόντων.
Αλλά ως συνήθως στην πρώτη προσπάθεια μιας νέας σειράς υπάρχουν αρκετοί συμβιβασμοί που λογικά θα τελειοποιηθούν με τη δεύτερη γενιά.
Πχ η χρήση 1 γενιά πίσω CPU(Skylake) η έλλειψη τελευταίας γενιάς PASCAL Nvidia GPU ,η απουσία USB C 3.1 Thunderbolt support έστω και με extra controller μιας και ο Skylake δεν υποστηρίζει εγγενως Thunderbolt όπως και η έλλειψη τελευταίας γενιάς NVMe PCIe SSD πχ Samsung 960 Pro είναι πράγματα ανεπίτρεπτα σε ενός τόσο υψηλού κόστους μηχανήματος.
Θα μπορούσε να περιμένει λίγους μήνες παραπάνω έτσι ώστε να προσφέρει την αφρόκρεμα της τεχνολογίας στο χώρο των υπολογιστών μιας και Kaby Lake H σειρά θα βγει αρχές του 17.
Επίσης ο δίσκος που προσφέρεται είναι υβριδικός και όχι pure SSD στο σύνολο του πράγμα εξίσου απαράδεκτο.
https://www.microsoftstore.com/stor...900?icid=HP-PDP-Takeover-Surface-102616-MSUSA
Δεν διανοείται 2016 και να βγαίνουν τέτοιου είδους απαρχαιομενο αποθηκευτικό χώρο σε τέτοια αξίας μηχάνημα που αποτελεί βιτρίνα για την εταιρία.
alextrela
28 November 2011
3,129
αν πας σε i7 kai ssd, δεν το γλυτωνεις το τετραχιλιαρο...
Καμία version δεν εινάι με pure SSD λέμε.
Είναι υβριδικός δίσκος δηλαδή ένα μικρό μέρος είναι SSD όπου φορτώνει το λειτουργικό και το υπόλοιπο κομμάτι είναι παραδοσιακός HDD σαν προέκταση αποθηκευτικός ρόλος.
Κοστολογεις που κοστολογεις στα ύψη ε βάλε μου τα κορυφαία components και όχι τσιγκουνιές.
Θα τα μάθουμε βέβαια αναλυτικά όταν βγουν τα ακριβή specs με κάθε λεπτομέρεια από review πχ anandtech η notebookcheck
Αλλά έως τότε το hybrid που αναφέρει η MS μου κάνει για κοτσάνα.
alextrela
28 November 2011
3,129
βαζεις εσυ ενα.... μακαρι νατανε αυτο το προβλημα.
Αν αλλάζει δηλαδή έχεις εύκολη προσβασιμότητα τότε λύνεται το θέμα.:p
Με κόστος βέβαια που επωμίζεται εσυ όμως(και που η MS θα έπρεπε να προσφερει out of the box)
Αρκεί εξίσου να έχει μια M2 NVMe αντίστοιχη θύρα για να βάλεις τον αντίστοιχο υψηλών προδιαγραφών SSD.
Αλλά δεν το γνωρίζουμε σήμερα αυτή τη παράμετρο.
Η MS δεν ανέφερε τίποτα άρα κρατάμε μικρό καλάθι.
Βέβαια η οθόνη του που καθηλώνει και αναστενει νεκρούς θα την ήθελα να διακοσμεί το χώρο της δουλειάς η σπιτιού :flipout:
Αλλά όπως είπαμε και το χρηματικό είναι μεγάλο ζήτημα :p
underdog
26 November 2007
6,744
Μακαρι να εβγαιναν καταναλωτικες εκδοσεις σε λογικες τιμες....
Στάλθηκε από το SM-G900F μου χρησιμοποιώντας Tapatalk
Gojakla
20 May 2009
5,856
Ενας illustrator παντως θα τριβει τα χερια του... θα χρειαζοταν περισσοτερα χρηματα για ενα καλο PC και ενα μεγαλο Wacom...
buffos
17 July 2006
675
Με το συμπάθειο, εσείς που λέτε ότι είναι πανάκριβο, μήπως θα μπορούσε κάποιος να φτιάξει μία παρόμοια σύνθεση και να την κοστολογήσει να δούμε αν είναι όντως πανάκριβο ή όχι.
Ξεκινώντας φυσικά από την οθόνη.....
Μήπως να δει κάποιος πόσο κοστίζει ένα wacom σε αυτά τα μεγέθη;
Τώρα πώς θέλουμε να έχει hardware που δεν έχει ακόμη καλά καλά κυκλοφορήσει ακόμη και τώρα, Samsung 960 nvme, ή δεη είχε κυκλοφορήσει όταν το προϊόν σχεδιάζονταν είναι ένα θέμα.
Αν είμαι designer , architect κλπ τα 3Κ για αυτό που προσφέρει είναι ένα μικρό ποσοστό από ένα πρότζεκτ
alextrela
28 November 2011
3,129
Κοιτα ο υβριδικός δίσκος δεν συνάδει με οποιοδήποτε high end product.
Σε αυτό η MS είναι fail.
Ο 960 μόλις κυκλοφόρησε,αλλά κυκλοφορούν ήδη πολύ καιρό πχ το 950 που είναι εξίσου πολύ πολύ γρήγορος δίσκος.
Κατά τα αλλά η συσκευή απευθύνεται σε συγκεκριμένο κοινό και είμαι σίγουρος όσοι το αποκτήσουν θα αποσβέσουν τα λεφτά της αξίας του πολύ πολύ γρήγορα.
Τώρα εμείς οι "κοινοί θνητοί" θα το βλέπουμε με τα κυάλια ειδικά Ευρώπη που λογικά θα το δούμε αρχές άνοιξης του χρονου :flipout:
Και λόγο κόστους αλλά και λόγο ότι για πολλούς δεν μας χρειάζεται.
Πάντως το form factor η ευελιξία του και η οθόνη του είναι από μόνα τους selling point για το surface Studio.
Όσο να ναι είναι μοναδική και ξεχωριστή υλοποίηση στην αγορά κάτι εντελώς φρέσκο.
evanfotis
26 March 2008
5,475
Tα All in One σχεδόν ποτέ δεν ήταν value for money.
Sexy ναι!!!
Aπευθύνεται στο κοινό που θέλει να το έχει σε θέση "βιτρίνας" παρά σαν "workhorse".
Είναι δεσμευτικά γιατί τα components που παλιώνουν γρηγορότερα δε μπορούν να ξεχωρίσουν απο τα περιφερειακά , οθόνη που συνήθως καρατάνε για πολύ περισσότερο καιρό.
Μακάρι να έβγαζε την οθόνη ξέχωριστά απο το μηχανάκι απο κάτω. Θα ήταν υποψήφια για πού μεγαλύτερο κοινό.
Όσο για τους Illustrators, αυτοί μάλλον θα πάνε κατευθείαν σε cintiq 27 άσχετα με την μικρότερη ανάλυση, απλά επειδή έχει καλυτερη πιο φυσική αίσθηση η επιφάνεια, εχει καλύτερους οδηγούς για τα επαγγελματικά προγράμματα, , έχει tilt το πενάκι, έχει τo remote με τα hotkeys κλπ.
Συνδυασμενη με ένα μηχανάκι της αρεσκείας τους είτε λάπτοπ ή υπερυπολογιστή με πολλούς CUDA cores, ssds RAM κλπ.
Στη τιμή πάλι κοντά θα είναι, 2.5Κ η Cintiq και 1.5Κ ενα αξιοπρεπέστατο μηχανάκι πολύ πιο δυνατό απο αυτο εδώ.
Πιο πιθανοί πελάτες του Studio είναι φωτογράφοι, αρχιτεκτονες και άλλοι που μεγαλύτερη σημασία έχει η εντύπωση που δίνει η εικόνα της οθόνης και πού και πού τη κατεβάζουν να μασκάρουν η κατι παρεμφερές, παρά να σχεδιάζουν πάνω της όλη την ώρα.
Πάνως η Wacom πρέπει να έχει ανοικτά τα μάτια για τον εντυπωσιακό μηχανισμό που ανεβοκατεβαίνει η οθόνη, καμία σχέση με τη στιβαρή μεν γκουμουτσα δε βάση τους.
MakisM
12 May 2009
5,362
Διάβασα ότι η Microsoft αποκάλυψε ότι διάφορες εταιρείες (Acer, Dell, HP, Lenovo) θα κατασκευάσουν νέα 'σετ' εικονικής πραγματικότητας συμβατά με τα Windows 10 (το φθηνότερο θα κοστίζει μόνο 300 δολάρια). Οι νέες αυτές δυνατότητες αναμένεται να ικανοποιήσουν τους παίκτες βιντοπαιγνιδιών και όχι μόνο.
alextrela
28 November 2011
3,129
Έφτασε το πλήρωμα του χρόνου και για κυκλοφορία στην Ευρώπη.
Όσοι πιστοί προσέλθετε.
https://mspoweruser.com/microsoft-reveals-the-secret-behind-the-amazing-surface-studio-hinge-video/
Microsoft today announced the expanded availability of Surface Studio outside the US. Surface Studio is now available in Austria, China, Denmark, Finland, France, Germany, Hong Kong, Japan, Netherlands, Norway, Sweden, Switzerland, and the UK.
