Lake People PHONE-AMP G100 FE
vadergr
17 August 2007
27,460
Μεταμορφωση
Νεο μοντελάκι !
Στηρίζεται σε παλιότερο (highly praised) μοντέλο με balanced inputs (εκτος των κανονικών)
Vintage looks και κατασκευή οσο πιο στιβαρή γίνεται.
Η τιμή του δειχνει ταμαμ... (399 )
ΥΓ.Το παλιο μοντέλο λενε ηταν ιδανικό ταιρι των HD800 :p
http://lake-people.de/produktdetails/G100_FE-e.html
STEREO HEADPHONES AMPLIFIER G100 FE (Final Edition)
PHONE AMP G100 can be regarded as the ancestor of the HiFi / HiEnd units from von Lake People and Violectric.
It was the first item from Lake People which was widely used by professional and private customers. Professionals praised the indestructible stainless steel construction while private users loved the exceptional sound quality.
PHONE-AMP G100 FE includes all major construction details which are still important:
- transistorized amplifiers for unmatched transmission quality
- smooth performing RK 27 Potentiometer for volume control
- oversized power supply with toroidal transformer
Also, PHONE-AMP G100 defined for the first time or technical guidelines which
are still unique in their combination:
LOWEST NOISE
because of low internal gain.
Therefore the self-generated noise from the amplifier is not audible.
HIGHEST OUTPUT VOLTAGE
through 60 Volt internal operating voltage.
Over 90 % of all headphone amplifiers in the market offer not half that voltage !!
Therefore best suited for high impedance headphones.
HIGHEST OUTPUT POWER
because of powerful amplifiers able to deliver much more current a headphone needs.
Therefore best suited for low impedance headphones and even magnetostatic cans !!
HIGH DAMPING FACTOR
through lowest output impedance.
Therefore best suited for full control even over critical headphones with
the guarantee to have flatest possible response.
By the way:
the launching of Violectric was due to the marketing success of PHONE-AMP G100 !
All this is not too long ago, nevertheless a reason for us to offer again
PHONE-AMP G100 FE as Final Edition in a limited Edition for a very special price !!
The Features:
- balanced inputs via gold plated XLR connectors
- unbalanced inputs with priority via gold plated RCA connectors
- PRE-GAIN: gain adaption in five steps
- channel separated circuitry for minimized crosstalk
- discrete amplifier design with 4 transistors per channel (V100 Technology !)
- NF transmission band exceeds 150 kHz (-3 dB)
- High-Grade Potentiometer Alps RK 27 with optimized channel balance and lowest cross talk
- toroidal transformer, large smoothing capacitors
- outputs with relay controlled switch-on delay
- ultra compact stainless steel case
Technical Data
Balanced inputs:2 x XLR (L / R), gold plated
Unbalanced inputs:2 x Cinch (L / R), gold plated with priority
Impedance:10 kohms
Amplifier Channels:2 (Stereo)
Nom. input level:+ 6 dBu
Amplifier Gain:+8 dB
... with PRE-GAIN:-4 / +2 / +8 / +14 / +20 dB
Frequency range:0 Hz ... 150 kHz (-3 dB)
Slew Rate:> 8V / usec
Dynamic range:> 129 dB (A-wtd)
Noise:< -101 dBu (A-wtd)
THD+N:< -100 dB @ 10V in 100 Ohms (1W)
< -100 dB @ 18V in 600 Ohms (5W)
Crosstalk:< -110 / -95 dB (@ 1 / 15 kHz)
Max. output level:> 18.9 Veff in 600 ohms = 600 mW
> 16.5 Veff in 300 ohms = 900 mW
> 13.2 Veff in 100 ohms = 1750 mW
> 9.2 Veff in 50 ohms = 1700 mW
> 6.2 Veff in 32 ohms = 1200 mW
> 3.5 Veff in 16 ohms = 750 mW
Outputs:2 x 1/4" phone jacks
Power supply:230 / 115 V AC 10 VA
Dimensions:129 x 42 x 170 mm (W x H x D)
Case Material:Stainless Steel
DomieMic65
10 July 2006
9,689
πολύ θα ήθελα ν ακούσω κάτι από Lake People!
αυτός εδώ θεωρείται λίγο πιο "κάτω" μοντέλο από τον 109;
βέβαια είναι και ο R. Neve που παίζει στην ίδια κατηγορία (λίγο πιο πάνω)
vadergr
17 August 2007
27,460
Μεταμορφωση
Στα ίδια πρέπει να είναι.
Ενισχυτικα λίγο πιο κάτω από τον 109.
Είναι η κατασκευή,η balanced και o vintage χαρακτήρας
DomieMic65
10 July 2006
9,689
πάντως τελευταία που διαβάζω στο Super Best Audio Friends forum τα Lake People δεν χαίρουν και της πιο μεγάλης εκτίμησης (όπως και τα ifi, Burson, κ.α.) σε αντίθεση με τα Σιιτ...
δεν ξέρω αν και τι μπορεί να σημαίνει αυτό απλά το λέω...
Gojakla
20 May 2009
5,856
Το SBAF μαλλον ειναι οτι και το What Hi-Fi με τα βρετανικα προϊοντα.
Χωρις να εχω ακουσει Lake People ή πολλα αλλα, αυτο το "σπρωξιμο" για την Schiit εμενα δεν μου αρεσει. Και την Schiit την εκτιμω.
Τα σπρωξιματα σιχαινομαι.
Manosss
7 June 2012
2,251
Πειραιάς
Καλά το έχεις παρατηρήσει!
Σπρώχνουν τα schiit όσο δεν πάει...
Και έχω αρχίσει και τα παίρνω γιατί το παίζουν ότι είναι η αντικειμενική καλύτερη έκδοση του head-fi το οποίο κράζουν εν χορώ όλη μέρα...
Shiit στα μούτρα τους αντικειμενικοί είναι...
DomieMic65
10 July 2006
9,689
όντως και εγώ για "αντικειμενικό" φόρουμ το είχα....
ΔΕΝ ε;
Manosss
7 June 2012
2,251
Πειραιάς
Αντικειμενικό φόρουμ είναι μόνο ένα :D
Πέρα από την πλάκα πάντα λέω ότι πρέπει όλοι να διαβάζουμε με κριτική σκέψη και να μην παίρνουμε τίποτα σαν απόλυτο.
Ακόμα και για τις παρουσιάσεις που έχουμε κάνει εμείς εδώ έχω γράψει ότι είναι οι υποκειμενικές μας απόψεις και ότι λέμε δεν είναι και αυτονόητα σωστό.
Αλλά η διαφορά είναι ότι να διατηρεί κάποιος ένα ποσοστό υποκειμενικότητας σε μια παρουσίαση είναι φυσιολογικό.
Αντίθετα να ευλογάνε από το πρωί μέχρι το βράδυ συγκεκριμένες εταιρείες, να αναφέρουν μόνο τα θετικά και στα αρνητικά να κάνουν μόκο (ναι για τον Jotunheim τα γράφω) και να σνομπάρουν κατευθείαν άλλες εταιρείες με το παραμικρό χωρίς ίσως να έχουν ακούσει καν το μοντέλο που σνομπάρουν...Ε αυτό δεν είναι φυσιολογικό! Και δεν θέλει και πολύ να στραβώσει ο άλλος που διαβάζει!
Ειδικά όταν oι ίδιοι κράζουν όλη μέρα το head-fi για αυτούς ακριβώς τους λόγους.
Π.χ Δες το νήμα που έχει φτιάξει ο Marvey (που κινεί τα νήματα στο forum) για τα dac.
Στην κατηγορία "Great Value" σχεδόν όλα dac είναι της Schiit...! :bang:
7 dac έχει η schiit στο κατάλογο και τα 6 έχουν πιάσει 6 από τις 9 συνολικά θέσεις της κατηγορίας "Great Value"
Tο Mytek Stereo 192 dsd το έχει στην κατηγορία "Float it down to the LA river , global warming will eventually restore it"
Mάλλον οι επαγγελαματίες που τη χρησιμοποιούν είναι ηλίθιοι και έπρεπε να είχαν πάρει schiit.
