Series & Model
______________________ | UHD Premium _____ | ISF ccc ______
ISFccc -
Certified
Calibration
Controls | THX ____ | Hybrid
Log Gamma
(HLG) _____ | HDR 10
ST2084
(EOTF PQ),
ST2086
(static metadata)
ST2094
(dynamic metadata)
________
| Dolby Vision
VS10 ____ | Advanced HDR Technicolor
_______ | SoC / GPU / RAM
_________________________
Plattform,
Central Processing Unit,
System on Chip,
Instruction set,
Graphic Processor Unit,
RAM,
Total memory | Software
____________
Operating System,
Firmware version, | Videopanel _________________________Size class,
Type LCD/Oled matrix,
Resolution,
Pixel structure,
Bits of color,
Quantum dots,
Frequency of T-Con board,
Curvature,
Screen Uniformity,
Anti-reflective filter | Backlight Unit ______________Type backlight,
Local Dimming zone,
Type LED,
MEMC,
Backlight Scanning,
Black Frame Insertion,
PulsΠϴ Wide Modulation | Opportunities for calibration _____________________
ISF ccc,
Color Menagment System,
Technicolor Expert Mode,
White balance,
Gamma, | Internal Processing _____________________________Scaling,
Interpolation,
Overscaninng,
Digital Noise reduction,
Deinterlacing (Video mode, Film mode),
-, | Color _______________________________DCI P3 coverage (xy / uv),
Rec.2020 coverage (xy / uv),
White balance dE,
Color Delta E,
Gamma,
Color Temperature, | Brightness _______________________________Peak in HDR
Peak in SDR,
Average Picture Level,
Automatic Brightness Limiter,
| Contrast ______________ANSI Contrast,
With local dimming,
Without local dimming,
Static contrast,
Dinamic contrast,
White level,
Black level | Viewing angle
_____________ Horizontal & Vertical
(°cone) | Motion resolution ______________ | Input Lag ______________ | Audio _____________________________
Total power,
speakers,
Surround,
Sound mode, | Built in Media Player
Supported file systems
Image file formats
Audio file formats/codecs
Video file formats
Subtitles _______________________________________________ | Connectivity __________________ | Supported Resolutions __________________________Resolution / Frame per seconds
24, 25, 30, 50, 60, 100, 120fps
Progresive / Interleased
Chroma subsampling
4:4:4
4:2:2
4:2:0 | Conectors __________________________________ | Tuners ___________________
Twin HD tuner,
Teletext reception,
Multi window,
Timeshift,
PVR, | Note _____________________________________Pros & Cons | Series & Model
EZ1000 (Oled)
TX-65EZ1000E
TX-65EZW1004 (only in DACH)
TX-65EZ1002B (only in UK)
no 3D
no HFR (High Frame Rate) | Yes | Yes | Yes | Yes - in Internet video services, HDMI, USB port. | Yes - in Internet video services, HDMI, USB port. | ? | No | Plattform:
SoC: MediaTek MT5
Core Architecture: 4 cores
Instruction set:
Operating at up to:
GPU:
Open GL
RAM:
Total memory:
Available memory:
Internal storage total space:
Internal storage free space:
E
| OS: Firefox 3.0 | 64.5" - AM-OLED(Triple Stacked), 3840x2160, WRGB,
10-bit, No, 120/100Hz, Flat
Model: LC650LQD (LG Display)
54.6" - AM-OLED(Triple Stacked), 3840x2160, WRGB,
Model: LC550LQD (LG Display)
No vignetting;
PWM - No
BFI - No | No backlight
| ISF Professional
(expert mode -Day & Night)
THX Bright Room
3D LUT - 8000 points (2 table)
CMS - RGBCYM
White balance - 23/20 points
Gamma
gray scale of 10 points
Rec.2020
Rec.709
direct Display Control mode to allow to adjust settings directly from the Calman software (professional edition) by connecting screen to a PC via Ethernet | Very Good for HD,
| 65" - DCI/P3 - 97% / 98%
65" - BT.2020 - 73% / 76%
65" -
65" -
65" - 2.2
65" -
55" - DCI/P3 - 98% / 99%
55" - BT.2020 - 73% / 76%
55" -
55" -
55" - 2.2
55" -
| 65" - max 800cd/m2 in HDR
65" - max 430cd/m2 in SDR
55" - max 800cd/m2 in HDR
55" - max 430cd/m2 in SDR
APL -
ABL - full-field peak white came in at:
5% - 900cd/m2 (Vivid mode) - in HDR
10% - 700cd/m2 (Vivid mode) - in HDR
| 65" -
65" - x
65" - Inf.:1
65" -
65" -
65" - cd/m2
65" - 0cd/m2
55" -
55" - x
55" - Inf.:1
55" -
55" -
55" -
55" - 0cd/m2 | 65" - 65°(h)/ °(v)
55" - 65°(h)/ °(v)
Color shift - 26°
Brightness - 69°
Black Level - 75°
| 77" - horizontal lines 65" - horizontal lines
| 65"- HDR - ms
65"- Game mode -
65"- by default
55"- HDR - ms
55"- Game mode -
55"- by dafault
| 80W (RMS)
Dynamic Blade Speaker:
Tweeter x 2, Squaker x 4, Woofer x 8,
Quad Passive Radiator
VR-Audio True Surround+
Dolby Plus, Dolby Puls,
No- DTS Standard/Music/Ambience/User | FAT16, FAT 32, NTFS and exFAT
Image file formats
JPEG 4K, JIF, PNG, MPO, JPG, GIF, Audio file formats/codecs
AAC (Advanced Audio Coding)
FLAC (Free Lossless Audio Codec, .flac)
MP3 (MPEG-2 Audio Layer II, .mp3)
WMA Pro (Windows Media Audio, .wma)
WAV (Waveform Audio File Format, .wav, .wave)
Apple Lossless Video file formats
AVCHD/Progressive,
3GPP (3rd Generation Pertnership Project, .3gp)
AVI (Audio Video Interleaved, .avi)
DivX (.avi, divx,, .mkv)
H.263
H.264 / MPEG-4 Part 10 / AVC Video
H.265 / MPEG-H Part 2 / HEVC
MKV (Matroska Multimedia Container, .mkv, .mk3d, .mka, .mks)
Quik Time (.mov,. qt)
WMV (Windows Media Video, .wmv)
MP4 (MPEG-4 Part 14, .mp4, .m4a,. m4p, .m4b, .m4r, .m4v)
MPEG-4
TS (MPEG Transport Stream, .ts, .tsv, .tsa)
FLV
VRO (DVD-VR, .VRO)
VOB (Video Object, .vob)
PS
VP9, profile ?
To playback HDR, a HDR source is required (H.264 or H.265(ST2084 or HLG format)
Subtitles
Micro DVD, SRT, SUB, SubRip, TMPlayer, TXT
Obviously not playing DTS-HD tracks or TrueHD or ISO or Blu-ray folders (BDMV) and like all televisions, 24p videos are played in 60 im / s, but converting the framerate is well managed, with smooth playback without jerkiness and a picture of beauty. The reading is also interesting audio files with management Flac, WAV and ALAC, the ability to display album art or tags, but no native playback of files called "HiRes" all files in 88.2, 96, 176.4 or 192 kHz are downmixes in 48 kHz / 24 bits. | Lan (100BASE-TX/10BASE-T)
Wi-Fi,
802.11 a,
802.11 b,
802.11 g,
802.11 n,
802.11 n 5GHz,
802.11 ac,
Wi-Fi Direct,
DLNA 3.0,(DTCP-IP/DMP/DMR/DMS)
Bluetooth (HID)
(NFC) Ver.4.1(Keyboard/Mouse)
Miracast,
| 4096x2160 - 60p (displayed as 3840x2160)
4096x2160 - 50p (displayed as 3840x2160)
4096x2160 - 30p (displayed as 3840x2160)
4096x2160 - 25p/4:4:4 (10, 12 bit) (displayed as 3840x2160)
4096x2160 - 24p/4:4:4 (10, 12 bit) (displayed as 3840x2160)
3840x2160 - 120- No
3840x2160 - 60p /4:4:4, 8bit
3840x2160 - 60p/4:2:2 (8,10,12-bit)
3840x2160 - 60p/4:2:0 (8,10-bit)
3840x2160 - 50p
3840x2160 - 30p
3840x2160 - 25p /4:4:4 (10, 12 bit)
3840x2160 - 24p /4:4:4 (10, 12 bit)
1920 x 1080 / 120Hz - ?
1920 x 1080 / 60p (HDMI 1/2 / Component)
1920 x 1080 / 50p (HDMI / Component)
1920 x 1080 / 30p (Only HDMI 3/4)
1920 x 1080 / 24p (Only HDMI)
1920 x 1080 / 60i
1920 x 1080 / 50i
1366 x 720 / 24p (Only HDMI)-Up to 18Gbps
HDR included in HDMI 2/3 | 2 x USB 2.0 (DC 5V MAX 500mA)
1 x USB 3.0 (DC 5V MAX 900mA)
1 x Ethernet RJ45
4 x HDMI 2.0a - (ARC(input 2), CEC, MHL 3.0)
with HDCP (High-bandtwidth Digital Content protection) 2.2
1 x Satelite In(Main; F-typefemale)
1 x AV Composite in 3.5mm jack
1 x Video Component In 3.5mm jack
1 x Optical Audio Out (AAC/PCM/AC3)
1 x Hedphone output
1 x Antena (RF) (female)
1 x CI+, Ver. 1.3
1 x SD Memory Card Slot
Compatible Rec.2020 input | Double tuners
2 x DVB-T/T2/C/S/S2
Analog (NTSC, PAL, SECAM)
1 x TV IP Server & Client
DiSEqC version 1.0
2000 P
PIP, PAP, PAT
Timeshift & PVR
MPEG2, MPEG4, HEVC H.265, VP9 ver.2 | | EZ1000 (Oled)
TX-65EZ1000E
TX-65EZ1004 (only in DACH)
no 3D
