Beelink SEA Ι .... Ο Δράκος επανέρχεται ;;;;;;;;;;
alambi
30 November 2006
294
Αθήνα - Γλυφάδα
Beelink SEA β…* Realtek 1295DD Chip, DDR4 2GB eMMC 16GB, Support HDMI IN PIP Video Recording and SATA Hard Disk
Προπώληση στο GEARBEST - 2GB+16GB EU PLUG 95,09 ευρώ
Προπώληση στο GEARBEST - 2GB+32GB EU PLUG 104,14 ευρώ
Αποστολή προιόντων απο 1η Μαρτίου ...........
Launch Date:January , 2017
Product model:SEAβ…*
Dimension:188*119*20mm
Processor Number:Realtek 1295DD
β€’System Config
OS:Android 6.0
Language:Multi -language
CPU:Realtek 1295 DD Quad-Core ARM Cortex-A53
GPU:ARM Mali-T820MP3 GPUβ€”Mali-450 8-core equivalent
RAM:DDR4 2GB
ROM:Onboard eMMC Flash 16GB
Ethernet:1000Mbps LAN
WIFI:IEEE 802.11a/b/g/n/ac, 2.4G+5.8G
BT:BT 4.0
Antenna:Built-in antenna for WIFI
Expand Memory:SD Card (support 128GB)
β€’ Button & Ports
Button:Not Power Button(Connecting the power supplies,automated system operationοΌ‰
DC-in:1*DC in Port
SPDIF:1*S/SPDIF Port
RJ45:1*RJ45 (network connection) Port
HDMI IN:1*HDMI IN Type Port
HDMI OUT:1*HDMI OUT Type Port
USB2.0:1* Standard USB Port
USB3.0:1* Standard USB Port
SD Card Slot:1* SD card slot
Power LED:1* power LED
Hard disk:1* Standard hard disk SATA port
β€’RTC
Real Time Clock(RTC Battery)
There is no need to repeat the correction time,System startup--to automatically display the real-time time
β€’Hard disk specifications
The device is in working condition, Please do not insert / remove the hard disk
Hard disk interface type: Support SATA III (1.5G / 3G / 6G) specifications
Hard disk size:2.5 inches
Hard disk thickness support: 9.5MM /7.5MM
β€’Powerful codec capabilities
UHD 4K 60fps HW decoding, supports multiple formats including H.265 10-bit, H.264 and AVS+
FHD 1080p 60fps HW encoding, supports H.264
β€’Video/Picture Decoding
VP9 Profile-2 up to 4Kx2K@60fps
H.265 HEVC [email protected] up to 4Kx2K@60fps H.264 AVC [email protected] up to 4Kx2K@30fps
H.264 MVC up to 1080P@60fps
MPEG-4 ASP@L5 up to 1080P @60fps
WMV/VC-1 SP/MP/AP up to 1080P@60fps
AVS-P16(AVS+)/AVS-P2 JiZhun Profile up to l080P@60fps
MPEG-2 MP/HL up to 1080P@60fps(ISO-13818)
MPEG-1 MP/HL up to 1080P@60fps(ISO-11172)
RealVideo 8/9/10 up to 080P@60fps
WebM up to VGA
Multiple language and multiple format sub-title video support
MJPEG and JPEG unlimited pixel resolution decoding(ISO/IEC-10918)
Supports JPEG thumbnail,scaling,rotation and transition effects
Supports*.mkv,*.wmv,*.mpeg,*.dat,*.avi,*.iso,*mp4,*.rm and*.jpg file formats
β€’Video Post-Processing Engine
1.Supports HDR10 and HLG HDR processing
2.Motion adaptive 3D noise reduction filter
3.Advanced motion adaptive edge enhancing de-interlacing engine
4.3:2 pull-down support
5.Programmable poly-phase scalar for both horizontal and vertical dimension for zoom and windowing
6.Programmable color management filter(to enhance blue,green,red,face and other colors)
7.Dynamic Non-Linear Luma filter
8.Deblocking filters
9.Programmable color matrix pipeline
10.video mixer: 2 video planes and 2 graphics planes per video output
β€’Video Output
1.Built-in HD 2.0a transmitter including both controller and PHY with CEC,HDR and HDCP 2.2,4Kx2K@60 max resolution output
2.CVBS 480i/576i standard definition output
3.Supports and standard SD/HD/FHD video output formats: 480i/p,576i/p,720p,1080i/p and 4Kx2K
β€’Audio Decoder and Input/Output
1.Supports MP3,AAC,WMA,RM,FLAC,Ogg and programmable with 5.1 down-mixing
2.Built-in serial digital audio SPDIF/IEC958 output and PCM input/output
3.Built-in stereo audio DAC
4.Stereo digital microphone PDM input
5.Supports concurrent dual audio stereo channel output with combination of analog+PCM or I2S+PCM
β€’Power management
Power management Adapter: DC12V 1.5A(100-240V,50/60Hz)
β€’Environment
Work Environment :5°C -- 35°C,30%--90% Humidity
Storage Environment :-20°C -- 60°C,10%--90% Humidity
Product packing list:
1.Beelink SEAβ…*TV Box*1
2.HDMI cable * 1
3.Power Adapter DC12V 1.5A(100-240V,50/60Hz)*1
4.Operations guide*1
5.Infrared remote control*1
Packing size: 196 * 121 * 75mm
Product size: 188 * 119 * 20mm
vadergr
17 August 2007
27,457
Μεταμορφωση
H τιμή του πάντως (ασχετως εκπτωσης κιολας) ειναι εκπληκτική για το hardware και τις δυνατότητες που έχει.
Αρκει να υπάρχει καλό software να το υποστηρίζει.
H Beelink ειναι μεγάλη εταιρεία.
Μακάρι να το δούμε και απο κοντά.
leonkoum
20 December 2008
4,882
Αν δεν είναι πάλι καμία 'πατάτα' στιλ GT1 με την απίστευτη 'υποστηριξη' σε θέματα λογισμικού που είχε το προηγούμενο μηχανάκι ΙΣΩΣ να είναι εξαιρετική λύση ΑΛΛΑ εγώ τουλάχιστον δεν θα το αγόραζα πριν περάσουν τουλάχιστον 6 μήνες από την κυκλοφορία του και στρώσει κάπως το λογισμικό.
(Είπαμε, μια φορά καημένος από αυτούς άλλη φορά δεν...)
Εντύπωση πάντως μου κάνει ότι και αυτοί φοράνε το RTD1295 και εγκαταλείπουν το amlogic912s. Ίσως τελικά τα πρόβλημα στον ήχο να είναι αξεπέραστα και 'συνεργασια' σε επίπεδο οδηγών με αυτό το soc ...'προβληματικοι'.
Πάντως σαν υλοποίηση ομολογώ ότι δείχνει εξαιρετικη.
Άντε να δούμε...
vertical
15 November 2011
3,337
Όλα θα κριθούν στο software που θα δίνει η εταιρεία. Zidoo, Zappiti και Beelink θα μοιράζονται το ίδιο hardware. Πάντως τα fixes που βγήκαν στο x9s βγήκαν και στο Zappiti πράγμα που δείχνει πως κάποια θέματα τα λύνει η Realtek. Το 1295 πάντως είναι καλό τσιπ. Πολύ καλή ποιότητα σε εικόνα, εξαιρετικό δίκτυο κλπ. Σε αυτές τις τιμές κάνουν αρκετά προσιτά χαρακτηριστικά που θα περίμενες σε πολύ πιο ακριβά μηχανήματα.
starkman
15 January 2011
123
Re: Απάντηση: Beelink SEA Ι .... Ο Δράκος επανέρχεται ;;;;;;;;;;
Άντε να δούμε...
Ενδιαφέρον σχετικό άρθρο
http://www.minipcdb.com/articles/Amlogic-S912-Realtek-RTD1295-HiSilicon-Hi3798C-V200
vertical
15 November 2011
3,337
Λετε να ηρθε η ωρα να σουταρω το MED600 ???
Τα έχω δίπλα-δίπλα με το x9s και δεν έχει ανάψει εδώ και 2 μήνες. Αγαπημένο αλλά έφτασε στο τέλος της ζωής του κατ' εμένα και σύντομα θα βγει σε αγγελία.
Lef7234
Inactive User
5 May 2007
6,504
Απάντηση: Re: Απάντηση: Beelink SEA Ι .... Ο Δράκος επανέρχεται ;;;;;;;;;;
Εγω για τις 3D ταινιες το κραταω ακομα.
Ποιο X9S εχεις;
Lef7234
Inactive User
5 May 2007
6,504
Ναι το ειδα βρισκω ποιο ενδιαφερον αυτο του θεματος λογω οτι μπορει να παρει και δισκο μεσα.
leonkoum
20 December 2008
4,882
Είπαμε, η τιμή του είναι ασυναγώνιστη.
ΑΝ δουλέψει με την πρώτη 'καλα' χωρίς σοβαρά θέματα τότε πραγματικά είναι 'κελεπουρι'.
Αλλιώς θα υπάρχει 'θεμα' και μάλιστα σοβαρό.
Την zidoo μπορεί να τις λέμε 'πολλα' αλλά εγώ ξέρω & βλέπω ότι το δουλεύουν το λογισμικό και γενικά το παλεύουν και δεν κρύβονται.
Με τους άλλους αντίθετα η υποστήριξη απλά ήταν τραγική!
Πάντως περιμένω να δω και την υλοποίηση της xiaomi με το RTD που είμαι σίγουρος ότι θα έλθει σε λίγους μήνες.
Αλήθεια,το εκπτωτικό κουπόνι ποιο είναι;
vertical
15 November 2011
3,337
Ο εσωτερικός δίσκος συνεπάγεται και υψηλότερη θερμοκρασία. Από κάποιες παρουσιάσεις αναφέρθηκε πως σε 4K αρχεία το 1295 στο x9s ανεβάζει θερμοκρασίες. Αυτό που η Beelink βάζει εσωτερικά, το x9s το έχει με sata connector. Εγώ έχω ένα HDD enclosure με eSata connector και το οποίο είναι κρυμμένο στο έπιπλο. Όταν γίνουν οι πρώτες παρουσιάσεις στο beelink θα δούμε!
kyrliot
31 March 2008
3,913
Tην Realtek και την Apple μου τις έχει απαγορεύσει... ο γιατρός. Παρολα αυτα είχα πάρει το πρώτο player με τον 1195. Φτηνό, hdmi in και out αλλά έκαναν ακριβώς ένα χρόνο για να έρθει σε ένα αποδεκτό επίπεδο firmware.
ΓΙΩΡΓΟΣ ΔΟΥΝΑΚΗΣ
258
Tο γραφω στο 3ο ποστ.
GB9%
95.09 euro χωρίς κουπόνι
94.16 με την έκπτωση του 9% (που στην πράξη δεν ειναι ούτε 0.9%) !!!
Μας πήραν χαμπάρι και οι Κινέζοι και μας δουλεύουν μάγκες αφού μόλις βάλεις το κουπόνι αλλάζει η αρχική τιμή και αντί να εφαρμοστεί η έκπτωση στα 95 ευρώ ανεβαίνει ως δια ...Κινεζικής μαγείας στα 102 κατι ...
Δεν με ενδιαφέρει (έχοντας το άψογο Zidoo x9s και πικρή εμπειρία απο την Beelink ...όπως και αρκετοί απο δω μέσα) το έγραψα απλά για τους βιαστικούς ...
Αν κρίνω απο την ανύπαρκτη έως μηδενική υποστήριξη στο παρελθόν της Beelink θα συνέστηνα να περιμένετε την κυκλοφορία και 2-3 μήνες μετα μήπως και αλλάξουν τακτική αλλιώς προβλέπω να γεμίζουν οι αγγελίες ...δράκους !!!
Με το Zidoo x9s να εχει παίξει στα 120-130 ευρώ κατά καιρούς δε το λες και ευκαιρία ιδιαίτερα αν οι Κινέζοι το πουλήσουν και μετα το παίξουν ...Κινέζοι !!!
vertical
15 November 2011
3,337
Μια πρώτη παρουσίαση. Φθηνή πλαστική κατασκευή και από όσο βλέπω βασίζεται αποκλειστικά σε Kodi. Εκτός και αν του ξέφυγε κάτι του τύπου ο οποίος γενικώς κάνει καλές σύντομες παρουσιάσεις. Ακόμη και στα λεφτά αυτά το θεωρώ κατώτερο του x8. Δεν συζητάω καν ότι οι θερμοκρασίες με σκληρό/ssd σε πλαστικό θα πηγαίνουν στο θεό.
vadergr
17 August 2007
27,457
Μεταμορφωση
Ειναι ομως και 35% φθηνότερο απο το X9s.
Αν παιζει καλα (23.976, HD Audio, αν εχει και auto frame rate switch θα ηταν ιδανικα) ειναι νορμαλ η τιμή του (και η κατασκευή επισης).
