[Επίσημο] OnePlus 5
airb
25 May 2008
15,110
Λιβαδειά
OnePlus | Specs | Price
Specification:
Display
Parameters
  • Size: 5.5 inches
  • Resolution: 1080P Full HD (1920 x 1080 pixels) 401ppi
  • Aspect Ratio: 16:9
  • Type: Optic AMOLED
  • Support sRGB, DCI-P3
  • Cover Glass:2.5D Corning Gorilla Glass 5
Features
  • Reading Mode
  • Night Mode
  • Lift Up Display
  • Ambient Display
Basic Parameters
Operating System
  • OxygenOS based on Android Nougat
CPU
  • Qualcomm Snapdragon 835 (Octa-core, 10nm, up to 2.45GHz)
GPU
  • Adreno 540
RAM
  • 6/8GB LPDDR4X
Storage
  • 64/128GB UFS 2.1 2-LANE
Notification Light
  • RGB LED notification light
Viberation
  • Haptic vibration motor
Sensors
  • Fingerprint, Hall, Accelerometer, Gyroscope, Proximity,
  • RGB Ambient Light Sensor, Electronic Compass, Sensor Hub
Ports
  • USB 2.0, Type-C,Support USB Audio
  • Dual nano-SIM slot
  • 3.5mm audio jack
Battery
  • 3300 mAh (non-removable)
  • Dash Charge (5V, 4A)
Buttons
  • Capacitive hardware keys and on-screen navigation support
  • Alert Slide
Audio
  • Bottom-facing speaker
  • 3-microphone with noise cancellation
  • Support AANC
  • Dirac HD Sound
  • Dirac Power Sound
Dimensions
  • 152.7 x 74.7 x 7.25 mm
Weight
  • 153gr
Material
  • Anodized Aluminum
Color
  • Midnight Black
  • Slate Gray
  • Soft Gold
Camera
Rear Camera Wide-angle
  • Sensor: Sony IMX 398
  • Megapixels: 16
  • Pixel Size: 1.12 µm
  • EIS: Yes
  • Autofocus: DCAF
  • Aperture: f/1.7
Rear Camera Telephoto
  • Sensor: Sony IMX 350
  • Megapixels: 20
  • Pixel Size: 1.0 µm
  • Autofocus: PDAF
  • Aperture: f/2.6
Flash
  • Dual LED Flash
Video
  • 4K resolution video at 30fps
  • 1080P resolution video at 60fps
  • 1080P resolution video at 30fps
  • 720P resolution video at 30fps
  • Slow Motion: 720p videos at 120fps
  • Time-Lapse
Rear Features
  • Portrait, Pro Mode, Panorama, HDR, HQ,
  • Dynamic Denoise, Clear Image, RAW Image
Front Camera
  • Sensor: Sony IMX 371
  • Megapixels: 16
  • EIS: Yes
  • Autofocus: Fixed Focus
  • Aperture: f/2.0
Front Video
  • Time-Lapse
Front Features
  • HDR, Screen Flash, Smile Capture, Face Beauty
Connectivity
LTE/LTE-A
  • DL 3CA/256QAM, UL CA/64QAM
  • Supports up to DL CAT12/ UL CAT13(600Mbps/150Mbps) depending on carrier support
  • depending on carrier support
Bands
  • FDD LTE: Band 1/2/3/4/5/7/8/12/17/
  • 18/19/20/25/26/28/29/30/66
  • TDD LTE: Band 38/39/40/41
  • TD-SCDMA: Band 34/39
  • UMTS(WCDMA): Band 1/2/4/5/8
  • CDMA EVDO: BC0
  • GSM: 850/900/1800/1900 MHz
SAR info
  • Head: 1.240 W/kg
  • Body: 0.850 W/kg
Wi-Fi
  • 2x2 MIMO
  • Wi-Fi 802.11 a/b/g/n/ac
  • 2.4G/5G
Bluetooth
  • Bluetooth 5.0,support aptX & aptX HD
NFC
  • NFC enabled
Positioning
  • GPS, GLONASS, BeiDou
Multimedia
Audio Supported Formats
  • Playback: MP3, AAC, AAC+, WMA, AMR-NB,
  • AMR-WB, WAV, FLAC, APE, OGG, MID, M4A, IMY
  • Recording: WAV, AAC, AMR
Video Supported Formats
  • Playback: MKV, MOV, MP4, H.265(HEVC), AVI,
  • WMV, TS, 3GP, FLV, WEBM
  • Recording: MP4
Image Supported Formats
  • Playback: JPEG, PNG, BMP, GIF
  • Output: JPEG
In The Box
  • 1x OnePlus 5
  • 1x Screen Protector (pre-applied)
  • 1x Dash Type-C Cable
  • 1x Dash Power Adapter
  • 1x SIM Tray Ejector
  • 1x Quick Start Guide
  • 1x Safety Information
23,738
Δεν φτάνει που το ακρίβυναν, μας κλέβουν και στην ισοτιμία. Ούτε καν το 1:1 δεν κράτησαν (που κι αυτό κλέψιμο είναι)
Τα 479 δολλάρια γίνονται 499 ευρώ. Συγχαρητήρια...... :slapface:
thankin
17 April 2009
5,923
thessaloniki
Copy paste η πλατη του αιφον! Το EIS που εχει ειναι για τα πανηγύρια. Η πλατη γραντζουνιζεται ευκολα.
500 ευρώ ειναι ακριβό. Με άλλα 80 παιρνεις το s8 .και μεχρι να κυκλοφορήσει θα εχουν ισοφαρίσει, αν κόβεις δε και τιμολόγιο ουτε για πλακα δεν το κοιτας. [FONT=helvetica, arial, sans-serif]
[/FONT]Ενα απο τα δυνατα του σημεια ο ήχος. Ρίχνει στα αυτια του αιφον. Α και η μπαταρία μιζέρια.
thankin
17 April 2009
5,923
thessaloniki
Πάντως αν δεν βιάζεσαι σε δυο τρεις μηνες παιρνεις το xiaomi mi6 plus με τον ιδιο επεξεργαστή και με 100 ευρω στην τσέπη
leo06
14 October 2007
6,732
Πάτρα
Ήδη κυκλοφορεί
Το EIS που το είδες ότι είναι για τα πανηγύρια? Το pixel της Google που επίσης έχει EIS είναι και αυτό για τα πανηγύρια?
avpap
30 September 2011
9,589
Αθηνα
ολα σχετικα ειναι. Σε ενα τηλεφωνο εχει τεραστια σημασια το λειτουργικο και η γενικοτερη "αισθηση χρησης". Xiaomi εχω και ειμαι ευχαριστημενος, αλλα η διαφορα χρηματων σε καποια σημεια "φαινεται". Στο oneplus ξερεις οτι θα παρεις σχετικα γρηγορα OTA update, στα xiaomi ειναι οποτε το θυμηθει η εταιρεια. Αλλιως ψαχνεσαι σε 5-6 διαφορετικα fora και κατεβαζεις οποια rom σε φωτισει ο θεος και ελπιζεις. Δεν εχω μετανιωσει (καθολου!) την αγορα του mi5s, αλλα αυτο δεν σημαινει οτι δεν εχει και αρνητικα η εταιρεια.
alextrela
28 November 2011
3,129
Στα 500+ πλέον έχει χάσει κάθε έννοια value for money.
Flagship killer ούτε για αστείο δεν είναι.
Ξαναζεσταμένο φαγητό ντιζάιν με τα οικόπεδα bezel να κατέχουν τα ηνία χωρίς καμία βελτίωση εκεί που υπήρχαν αρκετά περιθώρια(οθόνη,ήχο,ηχεια),κάτι τέλος πάντως να δικαιολογήσει τα 500+.
Ούτε καν OIS δώσανε.
Really only plus??
Το απόλυτο μηδέν.
Σε αυξήσεις τιμής είναι πρώτοι αλλά σε εμπλουτισμό με επιπλέον feature τσιπιδες σε μεγαλο βαθμό πχ μια αδιάβροχοποίηση,AOD κάτι τέλος πάντων.
Ούτε καν ακουστικά στην συσκευασία οι αθοεοφοβοι-ανεπρόκοποι δεν βάζουν όταν άλλοι βάζουν και πολύ ποιοτικά μάλιστα.
Το μοναδικο προσόν του το βούτυρο Android και για τους ανήσυχους να έχουν να παίζουν με custom rom.
Ουδέποτε είχε το WOW τώρα έχασε και το μοναδικό προσόν του value for money και του killer.
SoCiaL
26 September 2007
1,174
Ακολούθησαν την εύκολη λύση, ουσιαστικά βγάλανε ένα oppo r11 με καλύτερο επεξεργαστή και μνήμη.
Μόνο το λογισμικό τους σώζει.
thankin
17 April 2009
5,923
thessaloniki
Ήδη κυκλοφορεί
Άμα κάνεις τον κόπο να δεις το πιο πάνω συγκριτικό με το αιφον θα καταλάβεις γιατί είναι για τα πανηγύρια. Όταν το 3 είχε ois και το 5 δεν έχει τι συζητάμε... πισωγύρισμα αλλά η 500αρα 500αρα! Άπατο θα πάει με αυτή την τιμή εδώ.
23,738
Καλά για το ελλαντα κι ενα κομματι να μην πουλήσουν ουτε που θα το καταλάβουν...
Στην Αμερικη είναι τα φράγκα.
Και υπόψιν αλλη αξία τα "ελληνικά" 500 ευρώ και άλλο τα 480 δολλαριακια ή οι 450 λίρες για εναν αγγλο.
