[Επίσημο] Google Pixel 2 and 2 XL
airb
25 May 2008
15,099
Λιβαδειά
Pixel 2Pixel 2 XL
Operating system- Android 8.0.0, Oreo
- Minimum 3 years of OS and security updates
Display- Cinematic 127-mm display
- FHD (1920 x 1080) AMOLED at 441ppi
- 16:9
- 5.0 inches
- 2.5D Corning Gorilla Glass 5
- Always-on display
- 95% DCI-P3 coverage
- 100000:1, super contrast ratio
- True black level
- Full 24-bit depth or 16.77 million colours
- Fullscreen 152-mm display
- QHD+ (2880 x 1440) pOLED at 538ppi
- 18:9
- 6.0 inches
- 3D Corning Gorilla Glass 5
- Always-on display
- 100% DCI-P3 coverage
- True black level
Camera
Back
- 12.2 MP
- 1.4 μm
- Autofocus with laser + dual pixel phase detection
- Optical + electronic image stabilisation
- f/1.8 aperture
Front
- 8 MP
- 1.4 μm
- f/2.4 aperture
- Fixed focus
Back
- 12.2 MP
- 1.4 μm
- f/1.8 aperture
Front
- 8 MP
- 1.4 μm
- f/2.4 aperture
- Fixed focus
Camera
Video
Back
- 1080p @30fps, 60fps, 120fps
- 720p @30fps, 60fps, 240fps
- 4K @30fps
Front
- 1080p @30fps
- 720p @30fps
- 480p @30fps
Back
- 4K @30fps
Front
- 1080p @30fps
- 720p @30fps
- 480p @30fps
Processors- Qualcomm Snapdragon 835
- 2.35 Ghz + 1.9 Ghz, 64 Bit Octa-Core
- Adreno 540
- Security module
- Adreno 540
- Security module
Memory
Storage
- 4GB LPDDR4x RAM
- 64GB and 128GB Internal
- 4GB LPDDR4x RAM
Battery- 2700 mAh
- Up to 7 hours of go with 15 minutes of charge
- 3520 mAh
Wireless
Location
Wireless
- Wi-Fi 2.4G + 5GHz 802.11a/b/g/n/ac 2x2 MIMO1
- Bluetooth 5.0 + LE
- NFC
- eSIM
Location
GPS | GLONASS | BeiDou | Galileo
Wireless
- NFC
- eSIM
Location
Ports- USB-C
- 3.1 Gen 1
- Single nano SIM
- USB Type-C and USB-C are trademarks of USB Implementers Forum
- USB-C
- 3.1 Gen 1
- Single nano SIM
Sensors- Active Edge
- Proximity/Ambient light sensor
- Accelerometer/Gyrometer
- Magnetometer
- Pixel Imprint: back-mounted fingerprint sensor for fast unlocking.
- Barometer
-Hall effect sensor
- Android Sensor Hub
- Advanced x-axis haptics for sharper/defined response
- Active Edge
- Magnetometer
- Barometer
-Hall effect sensor
Media
Audio
- Stereo front-firing speakers
- Wireless HD audio with LDAC, Qualcomm AptX and AptX HD audio codecs supported
- USB-C port to use with your own USB-C digital headphones
- Headphone Adaptor to connect a 3.5mm jack to your Pixel
- 3 mics
- Noise suppression
- 3 mics
- Noise suppression
OtherDaydream readyDaydream ready
Colours- Just Black
- Clearly White
- Kinda Blue
- Just Black
- Black & White
Dimensions
weight
- 145.7 x 69.7 x 7.8 mm
- 143 gr
- 157.9 x 76.7 x 7.9 mm
- 175 gr
Materials- Aluminium unibody with hybrid coating
- IP67 water and dust resistant
- Corning Gorilla Glass 5
What's in
the box
- Pixel 2
- USB-C charger
- USB-C to 3.5mm headphone adaptor
- Quick Start Guide
- Quick Switch Adaptor
- Pixel 2 XL
- USB-C charger
- Quick Start Guide
SAR info- Head: 0.93 W/kg
- Body: 0.96 W/kg
- Head: -
- Body: -
Official page- Google
- Pixel Phone Help
airb
25 May 2008
15,099
Λιβαδειά
Download Google Pixel 2 Stock Wallpapers
https://drive.google.com/file/d/0B-EQqpEb645uY0YyYmpvOHE1TkE/view
https://drive.google.com/file/d/0B29Dh2QdbmxXQU84RG5KV1pGS0k/view
(Sent from Nexus 6P)
koupa
25 January 2014
1,111
Θα έρθουν Ελλάδα επίσημα; Είμαι απογοητευμένος από το τηλέφωνο μου και θα ήθελα να το αλλάξω όσο κρατάει ακόμα τιμή. Διαβάζω πάρα πολύ καλά πράγματα και έχω ενθουσιαστεί.
airb
25 May 2008
15,099
Λιβαδειά
"Secret Menu Button"
To Android Police ανακάλυψε πρώτο ένα μυστικό menu key, στο οποίο μπορεί να έχει κάποιος πρόσβαση από τη navigation
bar
του Pixel 2, κάτι που αργότερα επιβεβαιώθηκε από το CNET. Μπορείτε να έχετε πρόσβαση σ' αυτό, πατώντας το κάτω δεξί
μέρος της οθόνης, δεξιά από το recent apps button. Πατώντας το, θα νιώσετε μία απτική ανάδραση, σαν να πατάτε ένα
πλήκτρο από τη Nav bar.​
Το button λειτουργεί σαν τo menu key, ένα πλήκτρο που ήταν μέρος των navigation keys του Android πριν τα on-screen keys
παρουσιαστούν στο Samsung Galaxy Nexus και το Android Ice Cream Sandwich.
Όπως πάντως επιβεβαίωσε η Google, το button αυτό είναι στην πραγματικότητα ένα bug στο software που θα διορθωθεί
στο επερχόμενο OTA update.
[via] . [via] . [via]
FSword
1,238
Εκτός της οθόνης βέβαια, που έχει τα γνωστά θέματα των lg poled.
Πράγματι, το αναφέρουν διάφορα site, π.χ. εδώ:
https://www.cnet.com/news/pixel-2-xl-p-oled-screen-issue/
Βέβαια νομίζω είναι μόνο το XL. Η Google κάτι έχει αναφέρει για διορθωτικό patch αλλά δεν ξέρω κατά πόσο θα λυθεί μόνο με software update.
Ως προς το αν θα έρθουν Ελλάδα, επισήμως νομίζω πως όχι (μόνο σε λίγες χώρες είναι επισήμως διαθέσιμα).
koupa
25 January 2014
1,111
Gamoto αν δεν έρθουν. Το s8+ που έχω κατρακύλησε μέσα σε 3 μήνες 300 και τώρα έχει σταθεροποιηθεί στα 650 . Δεν είναι φτηνό αλλά αν πουλήσεις το παλιό σου το αγοράζεις άνετα. Έτσι έλεγα να έκανα και με αυτό. Αλλά αν δεν έρθει οι παραεισαγωγεις θα μείνουν στο θεό. Το pixel XL 1 έπεσε από το χιλιάρικο όταν ανακοινώθηκε το 2.
22 June 2006
34,725
NEO HRAKLEIO
τα προβληματα που εχει στην οθονη δε λυνονται με patch.
Ειδικα οι γωνιες θεασης και η ανομοιομορφια στο πανελ.
Τα "ψοφια" χρωματα ερχονται, αν δωσει η google την επιλογη για srgb OFF /ON.
ΥΓ... παντα για το XL2 λεμε, το απλο για μενα δεν αξιζει με τιποτα.
FSword
1,238
Ε ναι τώρα. Βάλε καλύτερα μια top LCD αν δεν μπορείς καλή OLED παρά τα ημίμετρα p-OLED με ανομοιομορφίες και τατοιαύτα.
airb
25 May 2008
15,099
Λιβαδειά
Φαινόμενο «burn-in» στην οθόνη του Google Pixel 2 XL. Τι απαντά η Google
Πολλοί έχουν κριτικάρει την οθόνη του Google Pixel 2 XL για προβλήματα όπως μία παράξενη μπλε απόχρωση ή η όχι τόσο
ικανοποιητική αναπαραγωγή χρωμάτων. Μία νέα αναφορά από τo Android Central υποστηρίζει ότι το Pixel XL 2 που είχαν
στην κατοχή τους είχε προβλήματα «burn-in» στην οθόνη του, κάτι που έχουν παρατηρήσει και άλλα τεχνολογικά sites,
όπως το The Verge και το 9to5Google στις δικές τους δοκιμές.​
Η Google ενημερώθηκε για το θέμα και έστειλε μάλιστα και επίσημη απάντηση στο The Verge. Όπως σημειώνεται από την
εταιρεία.
«Η οθόνη του Pixel 2 XL έχει σχεδιαστεί με προηγμένη τεχνολογία POLED, περιλαμβάνοντας ανάλυση QHD +, ευρεία γκάμα
χρωμάτων και υψηλή αναλογία αντίθεσης για φυσικά και όμορφα χρώματα και αποδόσεις. Περνάμε όλα τα προϊόντα μας από
εκτεταμένες δοκιμές ποιότητας πριν από το λανσάρισμα και στην κατασκευή κάθε μονάδας. Ερευνούμε το report».
Σίγουρα θα ακούσουμε και άλλα για το θέμα τις επόμενες μέρες, όπως και την επίσημη θέση της Google μετά τη διερεύνηση
του ζητήματος.
[via] . [via]
airb
25 May 2008
15,099
Λιβαδειά
Google: Μπορείς να κάνεις root στα νέα Pixel 2 χωρίς να χάσεις την εγγύηση!
Αν και οι βελτιώσεις των κατασκευαστών στο stock firmware και στο Android γενικότερα, έχουν απομακρύνει πολλούς
από το rooting, υπάρχουν χρήστες οι οποίοι θέλουν να προβούν σε μία σχετική διαδικασία στα smartphones τους.
Ειδικότερα στην περίπτωση των Pixel 2, σε αυτό βοηθά αρκετά και ο ξεκλείδωτος bootloader. Αλλά στις
περισσότερες περιπτώσεις χάνεις την εγγύηση αν κάνεις root.​
Όμως κάτι τέτοιο δε συμβαίνει με τα νέα Pixel smartphones, όπως ανέφερε πρόσφατα το τμήμα υποστήριξης
σε σχετική ερώτηση. Όπως φαίνεται και από τα screenshots που δημοσιεύθηκαν από μια συζήτηση ενός μέλους των
Android Forums με την υποστήριξη, η Google θα συνεχίσει την υποστήριξη. Συγκεκριμένα ο εκπρόσωπος ανέφερε:
«Η Google δεν είναι ενάντια στο rooting. Η Google θα υποστηρίξει το smartphone σου, αρκεί να το
γυρίσεις στην τελευταία σταθερή έκδοση του Android πριν το στείλεις για επισκευές στα πλαίσια
της εγγύησης».
Πρόκειται για μια σημαντική παρέκκλιση από την πολιτική που ακολουθούν σχεδόν όλες οι εταιρείες, όπου με το
rooting χάνεις την εγγύηση.
[via]
airb
25 May 2008
15,099
Λιβαδειά
Προβλήματα και με το "Android Auto"
Τελειωμό φαίνεται να μην έχουν τα προβλήματα στις συσκευές Google Pixel 2 και Pixel 2 XL, καθώς εκτός
από τα προβλήματα με την οθόνη και τον ήχο, πρόσφατα χρήστες ανέφεραν προβλήματα και με το Android
Auto.​
Η πρώτη αναφορά ήρθε από έναν χρήστη, ο οποίος συνέδεσε το Google Pixel 2 του σε ένα Ford Focus 2017,
το οποίο έρχεται με Ford SYNC 3. Σύμφωνα με την αναφορά του χρήστη, το smartphone κράσαρε αρκετές
φορές όταν έτρεχαν εφαρμογές όπως τα Google Play Music και Google Maps στο Android Auto.
Ο προσωρινός τρόπος διόρθωσης του προβλήματος ήταν να αποσυνδεθεί η συσκευή και να επανασυνδεθεί
με το σύστημα infotainment του οχήματος. Την αναφορά του ακολούθησαν κι άλλοι χρήστες.
Απ’ότι φαίνεται, το πρόβλημα συμβαίνει ανεξάρτητα από τη μάρκα του οχήματος, του λογισμικού ή του
hardware του κι ανεξάρτητα με το αν το Pixel 2 ή Pixel 2 XL τρέχει σε Android 8.0 Oreo ή στο Android
8.1 Oreo developer preview.
Μέχρι στιγμής, το πρόβλημα έχει αναφερθεί για τα: Kia Optima 2015, Honda Civic 2016, Chevrolet
Camaro 2SS, Ford Fusion 2017, Ford F-250, Kia Sorento, Volvo XC90 και Mitsubishi ASX. Τα συστή-
-ματα Infotainment περιλαμβάνουν κατασκευάστριες όπως οι Sony, Kenwood και Pioneer.
Ακόμη, φαίνεται ότι το Google Pixel δεν έχει πρόβλημα.
Από την πλευρά της η Google ζήτησε στο φόρουμ από τους χρήστες να αναφέρουν το πρόβλημα
προκειμένου να εντοπίσει από πού προέρχεται.
Να υπενθυμιστεί ότι τα Google Pixel 2 και Pixel 2 XL που πρόσφατα παρουσιάστηκαν έχουν επιδείξει
προβλήματα με τον ήχο και με την οθόνη τους.
[via] . [via]
airb
25 May 2008
15,099
Λιβαδειά
Η Google αναβαθμίζει το "Pixel 2 XL" με νέα Color Modes για την οθόνη
Η Google κινήθηκε αρκετά γρήγορα για να αντιμετωπίσει κάποιες “αστοχίες” όπως στα χρώματα της οθόνης στο Pixel 2 XL
καθώς και κάποια ζητήματα “burn-in” και τώρα ανέλαβε δράση υπό τη μορφή μίας ενημερωμένης έκδοσης λογισμικού, που
περιλαμβάνει αρκετές τροποποιήσεις που σχετίζονται με την οθόνη P-OLED της συσκευής της.​
Μεταξύ των αλλαγών εντοπίζονται τρία χρωματικά προφίλ – που αντικαθιστούν τη μοναδική επιλογή “Ζωντανά χρώματα” ή
“Vivid colors” που ήταν διαθέσιμη στο παρελθόν- τα “Boosted”, “Natural” και “Saturated”, αν και οι χρήστες δεν θα πρέπει
να περιμένουν συνταρακτικές αλλαγές. Η Google εξάλλου ήθελε να προσθέσει πρόσθετο εύρος και επιλογές, διατηρώντας
ωστόσο απείραχτη την υποστηριζόμενη χρωματική παλέτα της οθόνης. Όσον αφορά στην επιλογή “Boosted” ουσιαστικά
αντικαθιστά την επιλογή “Vivid colors”.
Άλλες βελτιώσεις έχουν στόχο να εμποδίσουν το λεγόμενο “burn-in” μειώνοντας την επιβάρυνση στην οθόνη που φέρνει η
μέγιστη φωτεινότητα για παράδειγμα (έτσι, μειώθηκε ελαφρώς η μέγιστη φωτεινότητα). Επιπλέον, πρόσθεσαν fade-out εφέ
στη μπάρα πλοήγησης (η οποία μετά από λίγη ώρα αδράνειας “ξεθωριάζει” στο παρασκήνιο).
Παρόλο που η ενημέρωση αφορά κυρίως το μεγαλύτερο από τα δύο μοντέλα της εταιρείας, το Pixel 2 XL, περιλαμβάνει και
ένα fix για ένα πρόβλημα που παρατηρήθηκε στο μικρότερο μοντέλο, το Pixel 2. Έτσι θα διορθωθεί το ζήτημα του “clicking
noise” που απασχόλησε τους κατόχους του Pixel 2. Τον Δεκέμβριο, η Google σκοπεύει να διαθέσει ένα security patch επίσης
που θα περιλαμβάνει πρόσθετες βελτιώσεις.
[via] . [via] . [via] . [via]
airb
25 May 2008
15,099
Λιβαδειά
Pixel 2 XL: Η ελαιοφοβική επίστρωση φεύγει από την οθόνη
Για την Google η κυκλοφορία των νέων Pixel 2, κάθε άλλο παρά καλή ήταν. Ειδικά το Pixel 2 XL, είναι αυτό που
έχει παρουσιάσει διάφορα προβλήματα με την οθόνη, με τον ήχο, ενώ παραδόθηκε ακόμη και χωρίς λειτουργικό
σύστημα μέσα.​
Επιπλέον, κάποιος χρήστης παρέλαβε την παραγγελία του παρά το γεγονός ότι το συγκεκριμένο κομμάτι είχε την
ένδειξη "cosmetic damage" όταν πέρασε για ποιοτικό έλεγχο.
Πολλοί κατασκευαστές αντιμετωπίζουν διάφορα προβλήματα όταν βγάζουν στην αγορά τα smartphones τους,
όμως στην περίπτωση της Google φαίνεται να είναι πολλά και δεν σταματούν.
Το νέο πρόβλημα αφορά και πάλι στην οθόνη του Pixel 2 XL από την οποία φεύγει η ελαιοφοβική επίστρωση
(oleophobic coating). Σχεδόν όλα τα Android smartphones έχουν την συγκεκριμένη επίστρωση στο γυαλί προ-
-κειμένου να φεύγουν οι δαχτυλιές πιο εύκολα. Ουσιαστικά αυτό που κάνει είναι να εμποδίζει την λιπαρότητα
των δαχτύλων σας να κολλήσει επάνω στην οθόνη και αν πέσει νερό, να σκουπίζεται πιο εύκολα.
Με τον καιρό η επίστρωση αυτή μπορεί να φύγει από την οθόνη, αλλά κάτι τέτοιο χρειάζεται μήνες ή και μερικά
χρόνια, αλλά δεν συμβαίνει το ίδιο με το κινητό της Google. Ορισμένοι κάτοχοι του Pixel 2 XL σε Google product
forums και Reddit, αναφέρουν ότι το oleophobic coating έφυγε μέσα σε λίγες μόλις εβδομάδες.
Όπως αναφέρει το 9to5Google, ίσως να πρόκειται για πρόβλημα της LG (από την οποία έρχεται η οθόνη),
μιας και το ίδιο πρόβλημα είχε προκύψει σε pre-production κομμάτια του LG V30.
Όταν φύγει η επίστρωση, δεν υπάρχει τρόπος να την επαναφέρεις στην αρχική κατάσταση, εκτός αν αλλάξεις
την οθόνη του κινητού. Σε μια περίπτωση η Google δέχτηκε να κάνει αντικατάσταση συσκευής στον χρήστη,
αλλά σε άλλη όχι.
[via] . [via]
qwerty1gr
23 February 2007
3,757
Γηραιά Αλβιώνα
Απαραδεκτη η G... Δε φτανει που χρεωνει τα 'νεα Νεξους' σε διπλη τιμη απο οτι παλιοτερα, αλλα σχεδον καθε χρονο φαινεται να εχει θεματα... Εχω διαβασει προβληματα κ με το Ν5Χ, και με το Ν6Π, ενω τα πρωτα Πιξελ δεν ειχαν καποια χαρακτηρηστικα που υπηρχαν σε αλλα flagship τηλεφωνα (πχ αδιαβροχοποιηση αν θυμαμαι καλα)... Θα μεινω με το Nexus 6 μου για οσο αντεξει μου φαινεται
airb
25 May 2008
15,099
Λιβαδειά
Αναφορές για μόνιμο κλείδωμα του bootloader
Τα Google Pixel 2 και Pixel 2 Xl μάλλον θα μείνουν στην ιστορία ως δύο από τα πιο προβληματικά smartphones που κυκλο-
-φόρησαν ποτέ. Η συχνότητα με την οποία εμφανίζονται προβλήματα στις συσκευές είναι πραγματικά ανησυχητική για την
αξιοπιστία της Google.​
Μέχρι στιγμής έχουν ακουστεί διαφόρων ειδών παράπονα και αναφορές σχετικά με δυσλειτουργίες των Pixel 2/Pixel 2 Xl.
Ένα εκ των κύριων ζητημάτων είναι η ευαίσθητη P-OLED οθόνη του XL μοντέλου, η οποία όχι μόνο είναι επιρρεπής σε
έντονη μπλε απόχρωση ύπο διαφορετικές γωνίες θέασης, μπορεί επίσης εύκολα να υποστεί burn-in. Επιπλέον, αρκετοί
χρήστες έλαβαν τα Pixel στα χέρια τους χωρίς το Android εγκατεστημένο. Το νεότερο ζήτημα, μέχρι πριν από λίγο,
αφορούσε την κάμερα, καθώς ο φακός των δύο Google smartphones αντιδράει κάτω από LED φωτισμό.
Δυστυχώς, εξακολουθούν να αναδύονται προβλήματα από τα Pixel 2 / 2 XL και αυτή την φορά αφορούν τον bootloader.
Στα forums των XDA developers υπάρχουν πάνω από 40 αναφορές (και αρκετές στα αντίστοιχα της Google) για μόνιμο
κλείδωμα του bootloader, καθιστώντας (για παράδειγμα) την πρόσβαση σε root λειτουργία αδύνατη. Επειδή πολλοί κάτ-
-οχοι των Pixel 2 μοντέλων δεν πρόκειται να ασχοληθούν ποτέ με αυτό το κομμάτι δυνατοτήτων του κινητού τους,
μάλλον οι bootloaders είναι κλειδωμένοι σε πολλές περισσότερες συσκευές, χωρίς την γνώση των κατόχων.
Το ζήτημα αφορά κυρίως την μικρή Pixel 2 έκδοση που κατασκεύασε η HTC (το Pixel 2 XL είναι προϊόν της LG). Λόγω του
σημαντικού ρόλου που παίζει η δυνατότητα ξεκλειδώματος του bootloader για όσους κατόχους εκδήλωσαν τα παράπονα
τους, η πλειοψηφία αυτών έχει επικοινωνήσει με την Google και ζητά επιστροφή χρημάτων. Τόσο ένας που αρέσκεται
στην πλήρη αξιοποίηση των δυνατοτήτων του Android smartphone του, όσο και ένας developer θέλουν να έχουν την
επιλογή του OEM Unlocking, αλλά παρά την σύμφωνη στάση της Google στο παρελθόν με την οικογένεια Nexus και
τα περσινά Pixels, φέτος φαίνεται πως κάτι δεν πάει καλά.
Ίσως η Google αλλάξει την κατάσταση με ενημέρωση λογισμικού, μπορεί όμως να είναι ήδη αργά για μια μερίδα χρηστών.
Η αλήθεια είναι πως τα Nexus και Pixel smartphones θεωρούνταν ανέκαθεν συσκευές φιλικές στους developers, οπότε η
σημερινή είδηση μοιάζει αλλόκοτη. Κατά πάσα πιθανότητα πρόκειται για άλλο ένα θέμα που το Menlo Park ξέχασε να ελέ-
-γξει, όπως και όλα τα ζητήματα που έχουν προκύψει για τους δύο φετινούς εκπροσώπους του. Πάντως τόσο το Pixel 2,
όσο και το Pixel 2 XL απαιτούν ένα τσουχτερό ποσό καταβολής για να γίνουν δικά σας…
[via] . [via]
