Ειμαι σε αναζήτηση κουτιού για σερβερ.
Το λειτουργικό ειναι το unRAID το οποιο υποστηρίζει ΜΕΧΡΙ 24 δίσκους, οποτε οσο πιο κοντά σε αυτο το νούμερο τοσο πιο futureproof.
ποια τα προτερήματα ενος rack mount, εκτός απο την εύκολη πρόσβαση στους δίσκους και το καλύτερο airflow λόγο μεγέθους;
αυτά που έχω βρει μέχρι τώρα ειναι τα nanoxia, ενω το πολύ ακριβότερο Lian Li PC-D8000 δεν έχει τις ευκολίες των nanoxia και μαλλον και την ποιότητα κατασκευής.
Nanoxia deep silence 1
Nanoxia deep silence 6
- υποστήριξη 14+ δίσκων
- αν εχει sata case για εύκολη πρόσβαση στους δίσκους ειναι θετικό, αλλα όχι απαραίτητο
- κόστος ~250
In the Deep Silence 1 Rev. B a total of 14 hard disk drives can be anti-vibration mounted. Three modular HDD-cages are available for this purpose. Two of the cages are designed for three 2.5 inch or 3.5 inch HDD and the third holds up to five 2.5/3.5 inch HDD/SSD. The hard disk capacity of the Deep Silence 1 Rev. B is expandable through the acquisition of additional HDD cages.
Alternatively, you can put the hard drive cages for two or three drives towards the power supply. Please note that this case no longer permits fan assembly on the bottom; the maximum depth of the power supply is about 200 mm. The hard drives are installed in special
mounting carriages, which are designed to accommodate both 2.5" HDD / SSD as well as 3.5" HDD.
The optical drives can be mounted without requiring tools. Two 5.25 inch to 3.5 inch adaptor are included to permit for example the installation of a card reader. If you want, you can use those to mount additional hard disk drives.
The massive tower is designed for a total of up to sixteen hard disk drives. By using the 5.25 inch to 3.5 inch adapters, you can even install a total of 18 data storage devices. The hard drives are installed in special mounting carriages, which are designed to accommodate both 2.5" HDD / SSD as well as 3.5" HDD. Screws with rubber suspension are used to hold the drives in place.
A special feature of the Deep Silence 6 Rev. B is the newly developed 2.5 inch mounting frame for up to six 2.5" HDD/SSD. For installation, the mounting frame will need three 3.5 inch bays. If you do not want to use this unique feature, sufficiently 3.5 inch mounting carriages are included to use all available slots.
The big tower also features a modular 3-bay HDD cage. The cage may be mounted at different positions on the case bottom.
This ensures that for example very thick radiators can be installed without space problems.
