Lenovo ThinkPad X1 [2016]
alextrela
28 November 2011
3,129
Μια ιδιαίτερα ανταγωνιστική πρόταση στην κατηγορία των 2 σε 1 έσκασε μύτη στην CES 2016 πριν λίγες ώρες.
ThinkPad X1 Tablet
The ThinkPad X1 Tablet has a 12-inch screen with a resolution of 2160x1440 pixels and an aspect ratio of 3:2. The Windows tablet offers processors all the way up to the 6th Gen Intel Core m7 vPro, which is supported by up to 16 GB LPDDR3 RAM. The biggest storage solution is a 1 TB PCIe NVMe-SSD and an LTE-A modem is optional. This is also the case for a ThinkPad keyboard. The tablet is 8.4 millimeters thin and tips the scale at 795 grams. The ports include one USB 3.0 and another USB Type-C port, a micro-SD slot and a stereo jack. The battery is supposed to last up to ten hours. The ThinkPad X1 Tablet will be available in the U.S. in February for $900.
The technology of the ThinkPad X1 Tablet is therefore solid, and it probably wants to compete with Microsoft's Surface Pro 4. The innovative part is the three optional modules, which can be attached to the bottom of the tablet. The first one is called the "Productivity Module", which can increase the battery runtime by five hours. It also offers an HDMI output as well as a OneLink+ port for $150. The second option is the "Presenter Module" for $280. It is equipped with a mobile presenter, which can create a 60-inch picture from a distance of two meters. It also includes one HDMI input and one output. The last module is the "3D Imaging Module" for $150. It uses the Intel RealSense camera to scan objects for graphics design and 3D printing.
https://www.youtube.com/watch?v=ta6C53Ule50
Specifications:
Up to Intel 6th Gen Core m7 vPro
Up to 1TB PCIe NVMe SSD
Optional LTE-A WWAN
WiGig docking
Up to 16GB memory LPDDR3
12 FHD+ 2K 2160x1440 (3:2) IPS
Tablet: 8.4mm (0.33”) With Keyboard: 13mm (0.51”)
Tablet: 795g (1.75lbs) With Keyboard: 1.1kg (2.4lbs)
USB Type-C
IR Camera (optional) WiGig, 1x USB 3.0, 1xUSB Type-C PD, mDP, micro SD, Audio, Nano Sim (also available via Modules: additional USB3.0, Full Size HDMI, OneLink+ docking port)
csm_10a_X1_Tablet_Productivity_Module_Black_Thin_Keyboard_Right_Hero_Shot0_f0921dfbe1.jpg
Lenovo’s ThinkPad X1 Surface clone can add camera, projector or battery modules
The ThinkPad X1 tablet could have copied the Surface Pro 4 and called it a day, but instead it built in more versatility.
http://www.pcworld.com/article/3018...-add-camera-projector-or-battery-modules.html
http://www.cnet.com/products/lenovo-thinkpad-x1-tablet/
alextrela
28 November 2011
3,129
Re: Lenovo ThinkPad X1 Tablet PC
Αποκαλυπτικές φωτογραφίες με τα διαφορετικά configuration που μπορεί να πάρει το συγκεκριμένο tablet απο την Lenovo με την χρηση των διαφόρων αξεσουάρ.
http://microsoft-news.com/lenovo-an...-modular-design-and-10-hours-of-battery-life/
Επιγραμματικα παρακάτω αναλυτικά τι προσφέρουν.
At CES, Lenovo today unveiled its newly expanded X1 portfolio which includes ThinkPad X1 Carbon Ultrabook, ThinkPad X1 Yoga and ThinkPad X1 tablet. ThinkPad X1 Tablet with its unique modular design and Intel Core m7 Processor reaches 10 hours’ battery and unique modules add functionality.
The modular design of the ThinkPad X1 Tablet offers something no other tablet can – adding functionality through simple clip-on optional modules:
· Need more battery? The Productivity Module increases use up to 15 hours total
· Ready to present? The Presenter Module includes a pico projector and HDMI port
· Creating in 3D? Add the 3D Imaging Module with its rear-facing Intel RealSense camera
alextrela
28 November 2011
3,129
Πάνε να χτυπήσουν την microsoft στα 2in1 tablet που είναι της μόδας αυτο τον καιρό.
Άρχισαν να ξυπνάνε απο το λήθαργο οι OEM θα ελεγα διοτι βλέπουν οτι η MS παει να καταλάβει όλο και μεγαλύτερο μερίδιο στην αγορά σε αυτήν την ταχέως αναπτυσσόμενη κατηγορία στο mobile computing.
Καλό για εμάς τους καταναλωτές να έχουμε παραπάνω επιλογές.
evanfotis
26 March 2008
5,469
Απάντηση: Lenovo ThinkPad X1 Tablet PC
Πολύ ωραία η σύλληψη του modular back αλλά έπρεπε να είχαν εκει και μια έκδοση με μια κάρτα γραφικών της προκοπής nvida ικανή να τρέξει απαιτητηκές εφαρμογές.
Yperion
21 June 2006
43,515
BVR (Beyond Visual Range)
Λίγο τον σχεδιασμό πρέπει να προσέξει παραπάνω η Lenovo , είναι κρίμα να βγάζει καλά προϊόντα που φαίνονται προχειροφτιαγμένα.
alextrela
28 November 2011
3,129
Η αλήθεια ειναι οτι τα Thinkpad δεν φημίζονταν τοσο για το ντιζάιν αλλα που προορίζονται για πιο business friendly καταναλωτικό κοινό με διαφορετικά features και χαρακτηριστικά.
Ειναι αλλη η κατεύθυνση και η φιλοσοφία τους σε σχέση με πιο consumer device.
Μπορεί να φαίνονται προχειροφτιαγμένα αλλα δεν ειναι στην πράξη οταν τα πιάσεις και προπαντώς τα δουλέψεις.
Πολυ ποιοτικά προϊόντα με εξαιρετικό premium feeling.
Και προσφέρει κατω απο το brand Thinkpad απο τις 10 εως 15 ίντσες προτάσεις για όλα τα γούστα/απαιτήσεις και όλα τα βαλάντια.
rotsikas
27 March 2013
571
Η σειρά carbon μόνο προχειροφτιαγμένη δεν είναι. Με το ανάλογο αντίτιμο πάντα :)
alextrela
28 November 2011
3,129
Καλοδεχούμενο βέβαια οτι η Lenovo θα παρέχει το πληκτρολόγιο σε 3 διαφορετικά χρωματα για όλα τα γούστα :p
sokos
19 January 2007
2,316
docking station έχει? Οχι με USB...εγώ θέλω να μπαίνω γραφείο και το ακουμπάω (οπως τώρα τα Surface Pro έχουν)
alextrela
28 November 2011
3,129
Θα προσφέρει wireless dock.
http://shop.lenovo.com/us/en/tablets/thinkpad/x1-tablet/
ThinkPad WiGig Dock (40A60045) Coming Soon
Improve usability with simple 802.11ad wireless docking. Eliminate cable restriction and get instant, seamless connection from your laptop to your other devices over the 60GHz band. Supports two displays, mouse, keyboard, webcam, and more, including I/O speeds as high as those available from USB 3.0. Up to ten times faster than WiFi. Includes hibernation support and standby.
Και το Productivity Module
The ThinkPad X1 Tablet has a modular design that lets you add modules to take your 2-in-1 tablet well beyond the average hybrid. The Productivity Module boosts battery life an additional 5 hours, resulting in up to 15 hours unplugged. It also gives you a range of additional ports that extend your connectivity, including USB 3.0, full-sized HDMI, and a OneLink+ docking port.
alextrela
28 November 2011
3,129
Τιμές ξέρουμε? το 12" κανα 1500;
Μόνο τιμές Αμερικής ξέρουμε που ξεκινάνε από 899 δολάρια για το entry-level m3/4/128 και ανάλογα το παραπάνω configuration θα υπάρχει χρέωση προς τα πάνω.
Για τα αξεσουάρ τα παρακάτω.
ThinkPad X1 Tablet will be available starting February from $899.
The Productivity Module will be available starting February from $149
The Projector Module will be available starting May from $279.
The 3D Imaging Module will be available starting May from $149.
Μένει να μάθουμε τιμές για το πληκτρολόγιο και αν η γραφίδα περιλαμβάνονται στη συσκευασία μαζί με το tablet η θα πάει και αυτό extra.
Τέλη του μηνός αρχές Φλεβαρη θα γνωρίζουμε περισσότερα η και όλα στα της πρότασης με κάθε λεπτομέρεια.
thankin
17 April 2009
5,923
thessaloniki
Δυστυχώς αυτές οι τιμές δεν απευθύνονται για την ελληνική αγορά πλέον, εμείς απλά θα τα χαζεύουμε.
Yperion
21 June 2006
43,515
Σαν μηχάνημα μπορεί να είναι άψογο , σχεδιαστικά όμως και να μου το χάριζαν που λέει ο λόγος θα το σκεφτόμουν. Όσο το βλέπω τόσο μου μοιάζει με laptop 10ετίας.
