Panasonic LX10-LX15
kbouk
8 January 2010
22,197
ΠΕΙΡΑΙΑΣ
Διέρρευσε στο 43rumors το δελτίου τύπου για την νέα compact Panasonic LX10 με αισθητήρα 1in (μαλλον αντικαθιστα την LX100 που είχε βεβαια μεγαλύτερο αλλά κροπαρισμένο αισθητήρα 4/3) :
Panasonic also announces the release of two powerful point-and-shoots, the DMC-LX10 and DMC-FZ2500. The Lumix DMC-LX10 characterizes itself with a large 1β€³, 20.1MP sensor, along with UHD 4K recording capabilities, a Leica 3x Vario-Summilux lens, and a 3.0β€³ 1.04m-dot tilting touchscreen........
Looking more in-depth at the LX10, this sleek, pocketable camera sports a 20.1MP 1β€³ MOS sensor, which affords a high native sensitivity to ISO 12800, expandable to ISO 25600, and fast stills performance throughout the camera system for shooting up to 50 fps with an electronic shutter, 10 fps with a mechanical shutter, or 6 fps with continuous autofocus. UHD 4K video recording is also supported at 30p and 100 Mbps, along with Full HD 1080p/60, and the 4K capabilities further avail a trio of 4K Photo Modes for shooting 8MP stills at up to 30 fps. Balancing speed and sensitivity, a 3x zoom Leica DC Vario-Summilux f/1.4-2.8 lens is featured, which covers a 24-72mm equivalent focal-length range, and includes a series of aspherical and low-dispersion elements to minimize spherical and chromatic aberrations throughout the zoom range. Five-axis HYBRID O.I.S.+ image stabilization is also employed to reduce the appearance of camera shake when working in dim light, and built-in focus-stacking capabilities along with a Post Focus mode afford a pair of features to ensure sharply focused imagery. The compact body of the camera incorporates a 3.0β€³ 1.04m-dot LCD touchscreen, which tilts 180° upward for taking selfies. Built-in Wi-Fi is available too, for wireless image sharing and remote camera control from mobile devices.
Περιμένω να δώ μεγεθος και αν τελικά βγει μικροτερη απο την LX100 θα είναι πολύ ενδιαφέρουσα πρόταση.
kbouk
8 January 2010
22,197
ΠΕΙΡΑΙΑΣ
Απάντηση: Re: Panasonic LX10
Το concept μου θυμίζει την C5050 που ειχα για πολλά χρόνια και με πέρασε απο την Νικον στην OLYMPUS την εποχή των πρώτων ψηφιακών γύρω στο 2003, την είχα χρυσοπληρωσει τοτε στα 850 περίπου , ειχε φωτεινο φακό 1.8 στα 35mm (μετα εβγαλε και την 5060 με ευρυγώνιο) που ξυριζε , η μηχανή ήταν τόσο καλή που φωτογράφος του National Geographic την χρησιμοποιούσε επι σειρα ετών μέχρι και πρόσφατα παραλληλα με τον υπόλοιπο εξοπλισμό του.
καπου θα κυκλοφορει LX10 και και καπου LX15 , οι πρωτες φωτό Που διέρευσαν site της Nokishita.
tiniakos
7 August 2007
16,146
Τήνος / Ελλάς
Re: Panasonic LX10
Η μεγάλη ένσταση των περισσοτέρων θα είναι η έλλειψη evf.
Σαν κάτοχος εδώ και καιρό της RX100iii και έχοντας τη δυνατότητα του evf το οποίο δεν είχα στο πρώτο μοντέλο μπορώ να πω ότι δεν μου είναι απαραίτητο.
Το 95% των φωτογραφιών το τραβάω με τη χρήση της οθόνης και αυτό έχει να κάνει με το μέγεθος και το χαρακτήρα της μηχανής.
Μια compact μηχανή είναι επί το πλείστον μια point and shoot επιλογή λόγω μεγέθους και ευχρηστίας έτσι η οθόνη βολεύει περισσότερο.
Η χρήση evf απαιτεί ένα μεγαλύτερο σώμα με καλύτερο κράτημα ώστε η τοποθέτηση της μηχανής στο μάτι να έχει μεγαλύτερη φυσικότητα.
Το καλό είναι ότι 4Κ ποια είναι αυτονόητο στις νέες μηχανές και το βίντεο δεν είναι απλά ένα πρόσθετο χαρακτηριστικό.
kbouk
8 January 2010
22,197
ΠΕΙΡΑΙΑΣ
Θα συμφωνήσω 100% σε αυτο που είπες Παναγιώτη, το είδα και εγω στην πράξη όταν αλλαξα την GM1 με την GM5 που ειχε EVF, ηταν η πρώτη μηχανή που εγώ που σουτάρω κατα 80% με EVF δεν έβαζα το μάτι μου στο σκόπευτρο και αυτό ειχε να κάνει αποκλειστικά με το μέγεθος της μηχανής. Η μηχανούλα αν τα πάει καλά στο ευρυγώνιο (και βγει σε γηινη τιμή) δείχνει καλή πρόταση ως μελλοντικό <δώρο> - αλλαγης της GF7+12-32- στην γυναίκα μου (σιγά μην το χάψει αλλά με την οθόνη selfie ίσως να πειστει ...:music-smiley-005:).
tiniakos
7 August 2007
16,146
Τήνος / Ελλάς
Re: Panasonic LX10
Γενικά σε φουλ ήλιο και σκληρό φως δεν τραβάω φωτογραφιες.
Αν όμως χρειαστεί δίνοντας μια κλίση στη σπαστη οθόνη μπορείς να μετριάσεις την αντανάκλαση.
kbouk
8 January 2010
22,197
ΠΕΙΡΑΙΑΣ
Τα χαρακτηριστικά της μηχανής:
Sensor: 1.0-inch effective 20.1 million pixel high-sensitivity MOS sensor (the total number of pixels 20.9 million pixels)
Lens: LEICA DC VARIO-SUMMILUX 8.8-26.4mm F1.4-2.8, equivalent focal length: 24-72mm (3: 2), 26-78mm’4: 3), 25-75mm (16: 9), 31- 93mm (1: 1)
Lens construction: 9 groups 11 sheets (4 aspherical lens, 2 aspherical ED lens, one UHR lens)
Camera shake correction: 5-axis hybrid camera shake correction
Rear LCD: 3-inch 1.04 million dot touch panel tilting (180 degrees possible tilt above)
Video: 4K 30fps, FHD 60fps
4K Photo: 30fps, up to 15 minutes
Minimum focusing distance: 30cm (normal), 3cm (AF macro wide-angle)
Shutter speed: 60-1 / 4,000 (mechanical shutter), 1-1 / 16,000 (electronic shutter)
ISO Sensitivity: 125-12800 (extended ISO: 80,100,25600)
Wi-Fi built-in (IEEE 802.11b / g / n)
USB charging
Media: SD / SDHC / SDXC (UHS-I compatible)
Size: 105.5 x 60 x 42 mm
Weight: 280g (body only), 310g (including battery · SD card)
απο το Digicameinfo
karamela
6 November 2013
10,551
Re: Panasonic LX10
Ξεκάθαρος ανταγωνιστής της Rx100...συμφωνώ με τον Κώστα-Παναγιώτη ότι το σκόπευτρο σε τόσο μικρό σώμα δεν προσφέρει και πολλά, άλλα εντάξει δεν μας χαλάει αν υπάρχει...γενικότερα έχουμε και Touch οθόνη και ποιο φωτεινό φακό στο ευρυγώνιο από την rx100...αν έχει καλή τιμούλα θα πάει αρκετά καλά και θα σκεφτώ να την αποκτήσω μιας και η rx100IV που γλυκοκοιτάζω είναι απλά πανάκριβη!!
Υ.Γ. Βασικά σαν αντικαταστάτης της παλιάς lx7 είναι και όχι της lx100...ξέρει κανείς αν θα δούμε lx200?? Δηλαδή με στιβαρό σώμα, μεγάλο σκόπευτρο και αισθητήρα m4/3 έστω και σε crop?
cacau
7 June 2008
20,330
Re: Panasonic LX10
Όταν (και αν) κυκλοφορήσει και η σειρά DL της Nikon, θα έχουμε πολυκοσμία στην κατηγορία - επιτέλους! Η μηχανή δείχνει πολύ ενδιαφέρουσα, με βασικό ερωτηματικό την απόδοση του φακού μια και λογικά ο αισθητήρας θα είναι ο ίδιος. Η πρόσφατη ιστορία με κάνει αισιόδοξο, βέβαια ο ψυχοπαθής μέσα μου έβγαλε την μεζούρα και είδε ότι η νεοαφιχθείσα είναι 3 χιλ. πιο μακριά, 2 πιο ψηλή και το κυριότερο 1 χιλ. πιο χοντρή από τις sony rx100 III-IV. Όσοι έχετε προσπαθήσει να χώσετε μια στην τσέπη του παντελονιού καταλαβαίνετε τι εννοώ... :flipout:
kbouk
8 January 2010
22,197
ΠΕΙΡΑΙΑΣ
Αν δεν πάθεις δεν θα μαθεις ...:worshippy: οκ υπαρχουν και τα εργοταξιακό παντελόνια με τις φαρδιές τσέπες :Banane0:
cacau
7 June 2008
20,330
Re: Panasonic LX10
Κώστα τα τζιν μου φαρδιά τα φοράω και χωράει η rx, αλλά η εμφάνισή μου μετά δημιουργεί το κλασσικό ερώτημα: "κουβαλάς σιδερικό ή χάρηκες που με είδες?" :flipout::flipout::flipout:
kbouk
8 January 2010
22,197
ΠΕΙΡΑΙΑΣ
:worshippy::worshippy:
atari4
18 September 2013
4,557
Anfield
Re: Panasonic LX10
Αντε καλα, ας περιμενουμε και αυτη μαζι με τις dl μπας και απολυθει ο στρατιωτης xz2 πουχει λιωσει...
_tzo_
Banned
18 November 2007
11,985
Re: Panasonic LX10
Αν είναι να κυκλοφορήσουν στην αγορά από τον νέο χρόνο, βάλε και 3-4 μήνες να πέσει λίγο η τιμή φτάνουμε Απρίλη '17.
Θα πρέπει να γίνει σύγκριση τότε με την τρέχουσα τιμή της ανταγωνίστριας RX100III, αφού κι εκείνη με τη σειρά της θα πέσει αφού θα έχει κυκλοφορήσει λογικά η V.
Πάμφθηνη δεν θα είναι ούτε η LX10 ούτε οι DL, οπότε μιλάμε για premium compact.
Premium compact χωρίς EVF προσωπικά δεν θα ξαναγόραζα. Μπορεί στην πράξη να χρησιμεύσει μια στις πέντε φορές, αλλά σώζει.
atari4
18 September 2013
4,557
Anfield
Re: Panasonic LX10
Έχεις δίκιο, ολες αυτες θα ξεκινησουν απο ψηλα σε τιμη, το θεμα ειναι τι ψαρια θα πιανουν και ποσο γρηγορα θα πεσει και η τιμη τους σε σχεση με τον ανταγωνισμο. Για να δουμε...
cacau
7 June 2008
20,330
Re: Panasonic LX10
Κάπως έτσι, αλλά η canon G7X είχε βγει απευθείας σε ανταγωνιστική (χαμηλότερη) τιμή, με + το extra reach του φακού και μείον την έλλειψη σκόπευτρου. Απλά δεν "σάρωσε" λόγω υποδεέστερου φακού και βέβαια γιατί η sony - κακά τα ψέματα - έχει πλέον μια ιστορία στην κατηγορία...
kbouk
8 January 2010
22,197
ΠΕΙΡΑΙΑΣ
Εχουν μπει σχεδόν όλα όσα έχουν τα m43 σώματα απο καλούδια στην μηχανή:
http://www.43rumors.com/panasonic-lx15-press-text-leaked/
Επιπρόσθετα διακρίνω εκτος απο την δυνατότητα macro περαιτερω αξιοποίηση της λειτουργίας post focus:
Panasonic has also integrated a new Post Focus Stacking function into the LUMIX LX15, which enables users to take multiple images of the same frame with different areas in focus, then combine all or selected focus areas into one image.
Και δεν λειπει και η δυνατοτητα slow motion : 120fps high speed video recording
High speed video recording at 120fps (NTSC / FHD) or 100fps (PAL / FHD) enables enthusiasts to create beautiful slow-motion videos capturing spur-of-the-moment action in great detail.
