GearBest special offers only for Greece !!!
  • Αγαπητοί φίλοι και φίλες.
Gearbest
7 February 2017
1,601
Original Xiaomi M365 Folding Electric Scooter - BLACK
$399.99 with Coupon: GBM365 For 200 times
Gearbest
7 February 2017
1,601
Original Xiaomi Bluetooth 4.2 Speaker - SILVER
Flash Sale Price $23.99
\\\\Brand: Xiaomi
Design: Mini,Portable
Compatible with: iPhone,iPod,Laptop,Mobile phone,MP3,MP4,MP5,PC,Tablet PC
Supports: Bluetooth,Hands-free Calls,Microphone
Connection: Wireless
Interface: AUX,Micro USB
Audio Source: Bluetooth Enabled Devices,Electronic Products with 3.5mm Plug
Speaker Impedance: 3 ohm
Color: White
Technical Parameters
Bluetooth Version: Bluetooth V4.2
Protocol: A2DP,AVRCP,HFP
Transmission Distance: W/O obstacles ≤10m
Number of Speakers: 2
Power Output: 5W
Freq: 100Hz-18kHz
Other Parameters
Charging Voltage: 5V
Battery Capacity: 1200mAh
Charging Time: 3 hours
Working Time: 10 hours
Gearbest
7 February 2017
1,601
Xiaomi mijia 1080P Smart IP Camera - WHITE
Flash Sale Price $32.99
1080P FHD resolution, get high-quality image and video
130 degree wide angle FOV, detect wide area
Support WiFi connection, realize 10m remote control
Dual-band WiFi: 2.4GHz / 5GHz
Built-in mic and speaker, support two-way intercom
Support night vision, IR distance is up to 10m
Motion detection, up to 15m distance
Partition hierarchical detection, reduce the nuisance alarms
Floating windows of the APP, convenient for watching
WDR and BSI technology
Smart recognition, automatically sleep
Gearbest
7 February 2017
1,601
GS320 Non-contact Digital IR Infrared Thermometer - YELLOW
Temperature Testing Instrument with Data Hold Function
Flash Sale Price $7.39
Main Features:
● Precise non-contact IR thermometer, safe and easy to use
● Simply point to an object and read its temperature
● Laser sight allows accurate targeting
● Consist of optics, temperature sensor, signal amplifier, processing circuit and LCD display
● Laser on / off switch, auto power off, temperature data hold
● 20 seconds auto power off
● Celsius and Fahrenheit switchable
● Lightweight and compact
Specifications:
Temperature range: -50 to 360 Deg.C ( -58 - 680 Deg.F )
Accuracy: 1.5 Deg.C
Resolution: 0.1 Deg.C or 0.1 Deg.F
Repeatability: 1 Deg.C
Response time: 500ms
Spectral response: 8 - 14um
Emissivity: 0.95 preset
Distance to spot size: 12 : 1
Operating temperature: 0 - 40 Deg.C ( 32 - 104 Deg.F )
Storage temperature: -20 - 60 Deg.C ( -4 - 140 Deg.F )
Power supply: 2 x 1.5V AAA batteries ( not included )
Gearbest
7 February 2017
1,601
Xiaomi Redmi Note 4 4G Phablet - GLOBAL VERSION GRAY
3GB RAM 32GB ROM Snapdragon 625 MIUI 8
$139.99 with Coupon:GBGR27 30 pieces
Display: 5.5 inch FHD screen
CPU: Snapdragon 625 Octa Core 2.0GHz
System: MIUI 8 OS
RAM + ROM: 3GB RAM + 32GB ROM
External Memory: 128GB
Camera: rear camera 13.0MP with AF and flashlight + front camera 5.0MP
Bluetooth: 4.2
Navigation: GPS, A-GPS, GLONASS
Sensor: Gravity Sensor, Proximity Sensor, Ambient Light Senor, Hall Sensor, Accelerometer
SIM Card: dual SIM dual standby, one is micro SIM card, the other is nano SIM card
Network:
2G: GSM B2/3/5/8
3G: WCDMA B1/B2/B5/B8
4G: FDD-LTE B1/3/4/5/7/8/20 TD-LTE B38/40
Gearbest
7 February 2017
1,601
Alfawise Z28 Pro Smart TV Box - 2G RAM + 16G ROM EU PLUG
RK3328 Cortex-A53 Quad Core + Android 7.1 + H.265 4K x 2K
$43.99 with coupon:GBZ28P16
Z28 Pro RK3328 Smart TV Box
Z28 Pro TV box comes with RK3328 CPU 4-core Cortex-A53 1.5GHz, which is perfect for 4K video solution with its Penta-core Mali-450 Graphics GPU. With the Android 7.1 version, tons of SNS applications can be downloaded from online. Users can also browse all video websites with the box. It is a practical home product, turn your TV into smart TV, you can enjoy all your favorite movies, food shows and entertainment programs.
Main Features:
● RK3328 CPU with 4-core is rapid and stable, it can give you a high-speed feedback and smooth response
● Optional: 1G RAM + 8G ROM / 2G RAM + 8G ROM / 2G RAM + 16G ROM
● The high-end version ( 2G RAM + 16G ROM ) has gigabit interfaces, with dual-band 2.4G + 5.8G WiFi and Bluetooth 4.0
● New Android 7.1 version provides you the benefit of using all the latest updates and having access to all the tools, games, and Apps at the play store smoothly
● Supports 4K x 2K video, gives you high-quality video experience
● Support full video format decoding. Support H.265 hardware decoding. H.265 and H.264 decoding will offer you high definition pictures and movies
● Can be connected to the Internet, watching video online
● The remote control is powered by 2 x AAA batteries ( not included )
