Olympus OMD EM1X Φωτογραφία
kbouk
8 January 2010
22,204
ΠΕΙΡΑΙΑΣ
Διέρευσαν από σήμερα στο photorumors τα πλήρη χαρακτηριστικά της μηχανής οπότε ανοίγω και το σχετικό νήμα, υπάρχει η σύντομη έκδοση και η πιο πλήρης , ακολουθεί η σύντομη και στο τέλος υπάρχει link για την πλήρη έκδοση :
Olympus E-M1X camera specifications (short version)
High-speed performance and excellent image quality
Speed and image quality of the new E-M1X are fueled by a 20.4 MP Live MOS sensor with a new coating in order to deliver improved sensitivity as well as two TruPicVIII high-speed image processors improving fundamental performance factors such as start-up time and recovery time from sleep mode. The dual processor design not only contributes to a faster camera, but also allows the support of two high-speed UHS-II SD card slots and enables the latest shooting functions such as Handheld High Res Shot, Live ND, and Intelligent Subject Detection AF.
Advanced Image Stabilisation
Olympus have introduced a redeveloped gyro sensor - the camera allows for the world’s best compensation performance. In combination with a M.Zuiko IS PRO lens, this technology enables the 5-axis sync IS to compensate for approx. 7.5 shutter speed steps1, eliminating the need for a tripod and enabling free-hand shooting in various conditions.
Super-fast AF
With locked AF, the E-M1X features high-speed sequential shooting at a maximum of 60 fps to capture split-second moments that the human eye cannot see. With AF/AE tracking, a maximum of 18 fps may be reached. The camera’s Pro Capture Mode records up to 35 frames retroactively from when the shutter button is released during shooting.
High-Res Shot functionality
In addition to high-resolution maximum 80 MP images that can be captured in Tripod High Res Shot, a Handheld High Res Shot functionality is now available on the OM-D E-M1X: designed for photographers who don’t want to be limited by using a tripod, this function generates a single high-resolution shot equal to that captured with a 50 MP sensor – without any signs of blur caused by handshake.
Live ND functionality
A new Live ND functionality incorporates slow shutter speed effects as though using an ND filter. The scene can be reviewed in the viewfinder and the effect edited before users take the photo. Effects can be set in five levels: ND2 (equivalent to one shutter speed step), ND4 (2 steps), ND8 (3 steps), ND16 (4 steps), and ND32 (5 steps).
Movie capabilities
In addition to professional-quality photos, the new E-M1X is a master at movie-making. It features all the extras videographers need to capture moments as they happen. With the ultra-high Cinema 4K (C4K, 4096 x 2160) movie format, videographers not only have the highest recording resolution to date, but also more flexibility when it comes to post production. 120 fps high-speed movies are also now supported in Full HD resulting in the capability to shoot cinematic movies with slow-motion perception.
The powerful 5-axis IS and electronic stabilization enable refined handheld 4K and C4K video recording with three selectable levels of movement compensation depending on the photographer’s posture and movement.
Log shooting
To counteract changing lighting conditions typical during documentary and nature shooting, the E-M1X supports log shooting. OM-Log400 delivers movies without loss of details in shadows or highlight blowouts, and greater freedom over video creativity through colour grading.
Anti-flicker shooting feature
With an anti-flicker shooting feature, the camera detects the flicker frequency of artificial light sources and activates the shutter at peak brightness to minimize uneven exposures and coloring between sequential frames (via PR). Flicker scan suppresses striped patterns that can occur when using Silent Mode (electronic shutter) and when shooting movies, so that users can fine tune the shutter speed.
Connectivity
A new Wi-Fi capture allows tethered shooting without a cable and makes it possible to transfer images wirelessly to a computer with the β€œOlympus Capture” camera control software.
GPS
The OM-D E-M1X contains a built-in GPS sensor, temperature sensor, manometer and compass, collectively known as ‛field sensors’. In addition to location information such as longitude and latitude, these sensors detect and record the temperature, elevation, and direction of the camera for adding detailed shooting information to images.
Weight 997g
Body (WxHxD) 144.4 x 146.8 x 75.4mm
Effective Resolution 20.4 megapixels
Continuous Shooting Speed 18 fps
The Olympus E-M1X features world class image stabilisation and stand out new capabilities including 50mp Hi-Res Shot handheld with new built-in ND filters. A new vertical grip houses two batteries for extended use and a deep finger rest for both horizontal and vertical positions gives a more comfortable grip. New twin processors take high-speed performance to another level for both image processing and a re-developed intelligent autofocus system. The magnesium alloy body is fully IPX1 weather resistance tested.
New features include:
’World’s best Image stabilisation: In combination with a M.Zuiko IS PRO lens, this technology enables the 5-axis sync IS to compensate for approx. 7.5 shutter speed steps
50 MP Handheld High Res shot functionality. Building on the HiRes innovation on the E-M1 MK II where a tripod was required, the E-M1X can now take a 50mp HiRes shot hand held. Using a tripod it can now produce 80mp images.
’Totally Re-developed AF system with various AF target modes and settings and intelligent subject tracking
Live ND feature for slow shutter effects without external filter
Dust, splash, & freezeproof. Weatherproofing maintained even when connecting microphone, earphone or remote control cable
’Integrated field sensors to add detailed metadata to pictures and video
’Two UHS-II SD card slots for high speed responsiveness
’Two batteries in innovative cartridge system and USB charging capabilities
Key β€œOM-D Movie” video capabilities: 4K and C4K, OM-Log400, Different levels of IS, 120 fps high-speed shooting in Full HD
Anti-flicker shooting capabilities
The sensor dust reduction system now features an improved Super Sonic Wave Filter (SSWF) with special coating which vibrates 30,000 times per second further reducing the possibility of dust or dirt ruining photos and equipment by factor 10
’Capture up to 2,580 images before having to recharge. Featuring USB Power Delivery (USB-PD) from up to 100 W power sources, both batteries in the camera body can be fully charged in approximately two hours.
’A new Wi-Fi capture allows tethered shooting without a cable and makes it possible to transfer images wirelessly to a computer with the β€œOlympus Capture” camera control software.
Read more: https://photorumors.com/2019/01/22/full-olympus-e-m1x-camera-specifications-leaked/#ixzz5dMe7Acwv
22 June 2006
34,774
NEO HRAKLEIO
Olympus EM1X
4κ είχε και η προηγούμενη...το θέμα είναι αν έχει 4κ 60p 10 bit. Δεν το αναφέρει, αλλά ειναι πιθανό.
Φυσικα και τι εστίαση θα έχει στο βίντεο.
Δε νομιζω να ενδιαφέρει πάντως το κοινό της αυτό.
karamela
6 November 2013
10,559
Re: Olympus EM1X
Μόνο εμένα μου έκανε εντύπωση ότι έχει EVF ''μόνο'' 2.36 m dots την στιγμή που ο ανταγωνισμός έχει πάει στα 3.7. Επίσης πάλι 0,75 μεγέθυνση στο σκόπευτρο, περίμενα μεγαλύτερη.
Καλά για την οθόνη δεν θα πω τίποτα, απλά ντροπή, βγάζεις τέτοιο σώμα τέτοιου μεγέθους, πόσο δύσκολο είναι να βάλεις μια οθόνη μεγαλύτερη από 3ίντσες και υψηλότερης ανάλυσης?
Για τα βίντεο specs δεν γνωρίζω ας τα κρίνουν οι ιδικοί, για μένα είναι τούμπανο σε αυτό τον τομέα, ειδικά με το απίστευτο IBIS που θα έχει, έτσι και αλλιώς αυτή η μηχανή απευθύνεται σε φωτογράφους κυρίως και όχι σε βιντεολήπτες.
Για μένα πάντως το μεγάλο στοίχημα είναι ο αισθητήρας, τι απόδοση θα έχει, το dynamic range του, το iso και γενικά πόσο θα κλείσει την ψαλίδα με τις FF μηχανές, καλά τα καλούδια και οι γκατζετιές άλλα από τον αισθητήρα κρίνονται όλα και για το αν θα ''περπατήσει'' στην αγορά και θα πείσει τους επαγγελματίες να την πάρουν. Για μας τους υπόλοιπους περιμένουμε την νέα Em5III.....
karamela
6 November 2013
10,559
Re: Olympus EM1X
Σοβαρά; Χαμηλής ανάλυσης EVF βάλανε;! Απίστευτο!
Δεν πάνε καλά, ακόμα και η αρχαία Fuji X-T1 που έχω έχει μεγαλύτερο σκόπευτρο και ίδια ανάλυση.
''''Format: eye-level type liquid crystal viewfinder, about 2.36 million dots
field of view / magnification: 100% / about 1.48 times'''
_tzo_
Banned
18 November 2007
11,985
Re: Olympus EM1X
Το handheld βίντεο με supertele το προμοτάρουν οι ίδιοι ως πλεονέκτημα της μηχανής και γενικά του φορμά.
Δεν χωράει πια η δικαιολογία ότι το κοινό της μηχανής και της μάρκας γενικά είναι φωτογράφοι.
kbouk
8 January 2010
22,204
ΠΕΙΡΑΙΑΣ
Απάντηση: Re: Olympus EM1X
Στα αναλυτικά για το ΕVF βρήκα αυτό :
High magnification, high speed viewfinder
viewfinder has newly designed its optical system and realizes the industry's top class finder magnification of 0.83 (* 35 mm format conversion). Moreover, it is clearly displayed to the four corners without distortion by the four-piece composition using an aspherical lens or glass with a high refractive index.
Οι μεγενθύνσεις στο σκόπευτρο όπως παρουσιάζονται στα specs πολλές φορές δεν είναι ανηγμενες πάντα στον ίδιο παρονομαστή, καλό επίσης είναι το μεγάλο μέγεθος αλλά το σημαντικότερο κατά τη γνώμη μου είναι η καθαρότητα που θα έχει και σε αυτή παίζει ρόλο και το οπτικό που το συνοδεύει ώστε να μην το βλέπεις παραμορφωμένο.
karamela
6 November 2013
10,559
Re: Olympus EM1X
Α μακάρι Κώστα, πάνω πάντως γράφουν αυτό ''about 1.48 times to about 1.65 times (50mm lens · ∞ · -1m-1)''' πολύ διφορούμενο μου ακούγεται, βέβαια η ανάλυση του σκοπεύτρου παραμένει ''χαμηλή'' για τέτοια μηχανή.....
kbouk
8 January 2010
22,204
ΠΕΙΡΑΙΑΣ
Πάντως βλέπω εκτός από το χεράτο 50αρι hires αρχείο και χεράτο τριπλό mode HDR μέχρι 4 δευτερόλεπτα, ανοίγονται άλλοι ορίζοντες στον φωτογράφο. Αυτός ο αυτόματος ανιχνευτής flickering και σε φωτό και σε βίντεο άλλο φρούτο. Το έχει και η ΕΜ1.2 αλλά χειροκίνητα και δεν ξέρω αν καλύπτει τό ίδιο εύρος συχνοτήτων. Μεγάλη ευκολία το πένταπλής διαβάθμισης ND από ΝD2 -32 , δεν βλέπω όμως να αναφέρει κάπου οτι μπορεί να δουλεψει στο βίντεο.
Aλλο ένα ενδιαφέρον χαρακτηριστικό το οποίο εν μέρη γινόταν στην ΕΜ1.2 (μόνο σε jpeg) και το ονόμαζε keystone function βλέπω το έχει επεκτείνει σε εύρος σημαντικά και μπορεί να μετατρέψει κάθε φακό σε shift :
[FONT=&quot]Live digital shift: shootingρ digital shift shooting available. Live view confirmation possible. ± 20 step correction in V direction, H direction possible, simultaneous in V direction, H direction[/FONT]
22 June 2006
34,774
NEO HRAKLEIO
Re: Olympus EM1X
Αν δε δουλέψει στο βίντεο, είναι εντελώς fail....
Εκεί το χρειάζεσαι περισσότερο.
Θα ήθελα κι εγώ πάντως μεγαλύτερο σκόπευτρο και μόνιτορ...πήξαμε πια στις 3 ίντσες.
