Olympus OMD EM5 Mark III
  • Αγαπητοί φίλοι και φίλες.
cacau
7 June 2008
20,263
Ανακοινώθηκε σήμερα τελικά, με χαρακτηριστικά 99% ίδια με την EM-1 mkII, πλην του μεγέθους φυσικά. Εδώ https://www.getolympus.com/us/en/digitalcameras/omd/e-m5-mark-iii.html μπορείτε να τα δείτε αναλυτικά από την ίδια την εταιρεία, μια και οι φήμες ήταν διϊστάμενες.
Τιμή στα 1200$/ για το σώμα.
Tyler_Durden
3 June 2011
130
Sensor: Live Mos 4/3, 17.4 x 13 mm, 20.4 Mpxl, 4/3 format
Max Definition: [4/3] 5,184 x 3,888
Video definition: C4K (4096 x 2160 pixels, 24p, IPB at 237 Mbps), 4K UHD (3840 x 2160 pixels, 30p, 25p, 24p), 1080p (100p, 50p, 60p, 30p, 25p, 24p), stereo sound
Frame: Micro 4/3
Multiplier coefficient: 2x
Stabilizer: 5 axes on sensor stabilization
Sensor cleaning: Yes, ultrasonic filter (Super Sonic Wave Filter)
Case protection: Anti-dust, anti-run-off, -10 ° C
Wi-Fi & Bluetooth: with OI Share app; connected shooting with Olympus Capture Wireless
GPS / Manometer / Compass: –
Sensitivity: 200-25,600 Iso (Low extension to 64 and 100 Iso)
File formats: Jpeg, Raw (ORF, 12 bit), MOV and AVI (video)
Color space: AdobeRGB, sRGB43rumors
Focusing: Dual Fast AF: 121 points / cross points for phase detection AF; 121 points / AF with contrast detection. All targets, single target (normal / small), group target (5 zones / 9 zones / 25 zones), custom target 1-4 (AF area and adjustable increment)
Exposure mode: PASM, artistic filters
Exposure metering: Multi-zone Evaluative (324 zones), Center-weighted, Spot, Spot Highlights, Spot Lowlights; correction on +/- 5 EV by 1/3, 1/2 or 1 EV
Speeds: shutter with focal plane: 1/8 000 to 60 s, B, T, sync at 1/320 s; electronic shutter: 1/32 000s to 60 s
Burst: 10 fps (AF-C, mechanical shutter)
Self-timer: 2 or 10 s
Miscellaneous: artistic filters, HDR, timelapse, B-exposure with continuous visualization, Raw editing, focus peaking, Live Composite, focus stacking, high resolution
Flash: – (FL-LM3 external flash supplied)
Flash plug: Claw and sync socket
Flash control: Auto, red-eye, backlight, slow sync first or second curtain, manual, wireless flash control; correction on +/- 3 IL
Viewfinder: Oled 2.36 Mpts, 100%, 0.69x, 27mm clearance, brightness and color temperature correction, anti-flicker
Monitor: LCD multi-directional touchscreen 1.04 Mpts
Storage: SDXC / UHS-II 43r
Interfaces: USB 2.0, micro-HDMI, WiFi, microphone input, headphone output,
Supplied accessories: strap, USB cable, flash, battery, flash FL-LM3
Power supply: Li-Ion battery BLS-50 (about 310 images according to CIPA standards)
Dimensions W x D x H: 125.3 x 65.2 x 49.7 mm
Weight: 414 g (SD and rechargeable)
Ανοίγω το thread γιατι δεν βλέπω να έχει γίνει κάποια αναφορά. Σε γενικές γραμμές, πολύ λίγες ευχάριστες εκπλήξεις (ελαφρύτερη, oled evf, και - high res). Σχεδον σε όλα τα άλλα, μιλάμε για τα βασικά specs που μοιράζονται ήδη 2 κάμερες (em1 mk ii και em1 X). Δεν ξερω τι σκοπό έχει μια "νεα" κίνηση το 2019 με σχεδόν τα ίδια specs με την Em1 mkII του '16. Στο μόνο που ελπίζω είναι να πέσουν κάπως οι τιμές της EM1 mkII μήπως και είμαι σε θέση να την πάρω κάποια στιγμή. Κατα τα άλλα, πραγματικά έχω περιεργεια να δω πότε θα βγει και τι παραπάνω μπορεί να δώσει ένας επιτέλους νεος mft αισθητήρας (για την em1 mkIII υποθέτω)
karamela
6 November 2013
10,453
Τα κλειδιά της υπόθεσης είναι ότι θα έχεις μια Em1II σε μικρότερο και ελαφρύτερο κέλυφος, με νέο επεξεργαστή (καλύτερο αρχείο, πιο γρήγορη λειτουργία, καλύτερη εστίαση) και χεράτο HR με μία από ότι φαίνεται συμπαθητική αρχική τιμή....προφανώς δεν έκανε κάτι εντυπωσιακό, άλλα σαν πακέτο φαίνεται αρχικά πλήρες.
tiniakos
7 August 2007
16,146
Τήνος / Ελλάς
Τα έχουμε ξαναγράψει και γινόμαστε γραφικοί.
Τίποτα νέο ή εντυπωσιακό τελευταία από τις φωτογραφικές εταιρίες , τη στιγμή που στην κινητή τα δίνουν όλα όλοι και όποιος αντέξει.
Προσωπικά έχω 2 χρόνια την Χ-Τ20 και δε βρίσκω λόγο να τρέξω στις νέες Fuji, αντίστοιχα και οι κάτοχοι olympus δε θα βρουν λόγο να σκάσουν τα υπερβολικά χρήματα που ζητάει η νέα E-M5.
Tyler_Durden
3 June 2011
130
Συμφωνω σε όσα λες, εκτός μάλλον απο το καλύτερο αρχείο, που δεν νομιζω να ειναι πραγματικα αξιοσημειωτα καλύτερο. Και εκεί ειναι που κάπως επισημαίνω τη στασιμότητα του mft αυτή τη στιγμή. Στο αρχείο που είναι αποτελεσμα της στασιμότητας αναπτυξης νεου αισθητήρα τα τελευταια 3 χρόνια (στασιμα megapixels, dynamic range, bit αρχειου). Βεβαια για να ειμαι ειλικρινής, απο τη στιγμή που δεν είδα φρεσκο αισθητήρα στην πρόσφατη EM1X, δεν περίμενα απο την σειρα των EM5 να είναι αυτή που θα φέρει νεο σένσορα. Σε γενικες γραμμες παντως εννοειται οτι υπερκαλύπτει το μέσο ενθουσιώδη χρήστη
karamela
6 November 2013
10,453
Re: Απάντηση: Olympus E-M5 Mark III
Ισχύει αυτό που λες Παναγιώτη, απλά η Olympus μέχρι τώρα δεν είχε ένα σώμα (όπως η Fuji) που να συνδυάζει όλη της την τεχνολογία σε ένα μαζεμένο και μικρό σώμα με μια σχετικά λογική τιμή, και ακριβώς αυτή την τρύπα πάει να κλείσει η νέα em5III.....προφανώς δεν έχει κάτι νέο και επαναστατικό από την άλλη.
karamela
6 November 2013
10,453
Απλά αν δεις π.χ. παρακάτω θα παρατηρήσεις ότι η em1II ελάχιστες διαφορές έχει σε απόδοση αρχείου π..χ με την Sony A6400...και ίσως η νέα em5III κλείσει την ψαλίδα εντελώς ή και ίσως να προσπεράσει....αυτό που θέλω να πω είναι ότι συνολικά υπάρχει στασιμότητα στο θέμα των αισθητήρων από όλες τις εταιρίες....
https://www.dxomark.com/Cameras/Compare/Side-by-side/Olympus-OM-D-E-M1-Mark-II-versus-Sony-A6400___1136_1281
tiniakos
7 August 2007
16,146
Τήνος / Ελλάς
Απάντηση: Re: Απάντηση: Olympus E-M5 Mark III
H τιμή αγγίζει FF σώμα όμως που όπως και να το κάνουμε στη θεωρία και στην πράξη υπερέχει ξεκάθαρα.
kbouk
8 January 2010
21,939
ΠΕΙΡΑΙΑΣ
Ακαιρο να γινει οποιαδήποτε περαιτέρω συζήτηση στο νήμα γιατι απλά δεν ξέρουμε τα πραγματικά specs της μηχανής , κανονικά πρέπει να διαγράψω το νήμα αφου ολα όσα ακολουθούν ως συζήτηση δεν ξέρουμε καν αν είναι εντός θέματος. Εως τότε ο σχολιασμός των πιθανών χαρακτηριστικών της μηχανής συνεχίζει να γίνεται εδώ
Αυτος είναι και ο λόγος που ΠΟΤΕ δεν ανοίγουμε νήμα αν δεν έχουν εξακριβωθεί τα specs 200% ή δεν έχει γινει επίσημα η παρουσίαση. Είναι κάτι που τηρείται εδώ και καιρό απο τη συντονιστική ομάδα της κατηγορίας μας και αφορά τα μοντέλα όλων των εταιριών. Αφήνω το νήμα μόνο και μόνο για να διαβαστεί αυτο απο όλους για μία ακόμη φορά και το κλειδώνω έως ότου ισχύσουν επαρκώς οι ανωτέρω προυποθέσεις.
Για ενημέρωση και μόνο θυμίζω όταν ποστάρουμε στοιχεία για μηχανή ή κάνουμε γενικότερα αναφορά σε κάτι απο το διαδικτυο πάντα αναφέρουμε το link με την ιστιοσελίδα που πήραμε τις πληροφορίες. Αν αυτο δεν τηρηθεί, η Δ.Ο. σβήνει απευθείας ολο το post.
kbouk
8 January 2010
21,939
ΠΕΙΡΑΙΑΣ
https://www.getolympus.com/us/en/e-...ail_etprm&utm_medium=email&sfmc_sub=133379004
Μόλις ανακοινώθηκε, ανοίγει και το νήμα προς περαιτέρω σχολιασμό.
Σημεια που ίσως ενδιαφέρουν :
  1. Stabilization Performance : 5.5 EV , * Based on CIPA measurement conditions. When using M.ZUIKO Digital ED 12-40mm F2.8 PRO (focal length =40mm (35mm equivalent: 80mm))
  2. 6.5 EV, * Based on CIPA measurement conditions. When using M.ZUIKO Digital ED 12-100mm F4.0 PRO (focal length =100mm (35mm equivalent: 200mm)), halfway release image stabilization Off
  1. Shutter Type
    Focal-plane shutter : 1/8000 - 60 sec., with selectable EV adjustment steps (1/3, 1/2, 1)
    Live Bulb / Live Time: selectable exposure time (1 / 2 / 4 / 8 / 15 / 20 / 25 / 30 min.), with 8-min. default setting. Live Composite: maximum shooting time 3 hours
    Electronic first curtain shutter (Anti-shock mode) : 1/320 - 60 sec.
    Electronic shutter (Silent mode) : 1/32000 - 60 sec.
    (still) Flicker scan: 1/7634 - 1/50.0 sec.
    (movie) Flicker scan: 1/250 - 1/30.0sec. *50fps movie: 1/50.0 sec., 60fps movie: 1/60.0sec., High speed video: 1/120.0sec.
  1. Finder Type
    Eye-level electronic viewfinder (OLED), approx. 2.36M dots
  2. Field of View / Viewfinder Magnification
    Approx. 100% / Approx. 1.20x[*1] - 1.37x[*2] (-1m-1, 50mm lens, Infinity)
    * 1: Finder Style 1, 2 (aspect ratio 4:3)
    * 2: Finder Style 3 (aspect ratio 4:3)
  3. Eye Point / Diopter Adjustment Range
    Approx. 27mm (-1m-1, Distance from rear lens surface) / -4 ~ +2m-1
Sequential shooting H]γ€€approx. 10 fps with selectable 5 -10 fps
[Sequential shooting L]γ€€approx. 6fps with selectable 1-6 fps
[Anti-shock sequential shooting L]γ€€approx. 5.5 fps with selectable 1-6 fps
[Silent sequential shooting H]γ€€approx. 30 fps with selectable 15, 20, 30 fps
[Silent sequential shooting L]γ€€approx. 10 fps with selectable 1-10fps
[Pro Capture H]γ€€approx. 30 fps with selectable 15, 20, 30fps
[Pro Capture L]γ€€approx. 10 fps
[*] sec.
Sequential shooting H 10fps] RAW: Max. 150 frames, JPEG (LF): Until card is full
[Sequential shooting L 6fps] RAW, JPEG (LF): Until card is full
[Silent sequential shooting H 30fps] RAW: Max. 23 frames, JPEG (LF): Max. 26 frames
[Silent sequential shooting L 10fps] RAW: Max. 152 frames, JPEG (LF): Until card is full
Metering Range
  1. EV -2 - 20 (ISO approx.100, with a F2.8 lens
Scene
Portrait, e-Portrait, Landscape + Portrait, Night + Portrait, Children, Night scape, Sport, Hand-held Starlight[2], Fireworks, Light trails, Sports, Panning, Landscape, Sunset, Beach & Snow, Backlight HDR[1], Candlelight, Silent, Macro, Nature Macro, Documents, Multi Focus Shot
*1 4 images automatically shot and combined into a single image composite
*2 8 images automatically shot and combined into a single image composite
Flash Synchronization Speed
  1. 1/250 sec.
    *When using Super FP: 1/125-1/8000 sec.
    *When using electronic shutter: 1/50 sec. up to ISO6400, 1/20 sec. for ISO 8000 and higher, and 1/20 sec. for ISO bracketing
  1. Focus Stacking Mode
    8 shots are taken at different focus points and automatically composited together into a single imageAngle of view becomes slightly smaller
  1. Compatible with:
    M.ZUIKO Digital ED 60mm F2.8 Macro
    M.ZUIKO Digital ED 40-150mm F2.8 PRO
    M.ZUIKO Digital ED 30mm F3.5 Macro
    M.ZUIKO Digital ED 7-14mm F2.8 PRO
    M.ZUIKO Digital ED 8mm F1.8 Fisheye PRO
    M.ZUIKO Digital ED 300mm F4.0 IS PRO
    M.ZUIKO Digital ED 12-100mm F4.0 IS PRO
  1. Live Bulb / Live Time
    Update Interval Time - 0.5 sec – 60 sec
  2. Live Composite
    Update Interval Time / composite method – 0.5 sec – 60 sec / Lighten Mode (Bright area prioritization)
  3. Interval Shooting
    Interval Time 1 sec. - 24 Hours, Max 999 frames.
    Sutomatic creation of time-lapse movies possible
  4. Multiple Exposure (number of pictures / function)
    2 frames / Auto gain, exposure on recorded picture (RAW)
  5. Fisheye Compensation
    Available (angle : 1-3)
  6. High Res Shot
    Equivalent to 50 megapixels / 25 megapixels (8 shots combined into a single JPEG using sensor shift)
    Available in P/A/S/M mode, RAW+JPEG or JPEG.
    JPEG: 8160 x 6120(50M) 5760 x 4320(25M) / RAW: 10368 x 7776
    RAW data can be developed in-camera. Olympus Workspace required to develop on a PC.
  7. Keystone Compensation
    Available (can be confirmed in Live View)
    *Horizontal and vertical compensation can be performed simultaneously.
  1. Video Recording Format MOV(MPEG-4AVC/H.264)
    Movie Mode / Frame Rate / Compression Method
  1. 4096Γ—2160(C4K) / 24p / IPB(approx.237Mbps)
    3840Γ—2160(4K) / 30p, 25p, 24p / IPB(approx.102Mbps)
    1920x1080(FHD) / 30p, 25p, 24p / ALL-I (A-I), IPB(SF, F, N)
    1920x1080(FHD) / 60p, 50p / IPB(SF, F, N)
    1280x720(HD) / 60p, 50p, 30p, 25p, 24p / ALL-I (A-I) , IPB(SF ,F ,N)
    60p: 59.94 fps
    50p: 50.00 fps
    30p: 29.97 fps
    25p: 25.00 fps
    24p: 23.98 fps
    C4K 24.00 fps
    FHD ALL-I(A-I : ALL-Intra/approx.202Mbps)γ€€FHD IPB(SF : SuperFine / approx.52Mbps, F : Fine / approx.30Mbps, N : Normal / approx.18Mbps)
    HD ALL-I(A-I : ALL-Intra / approx.102Mbps)γ€€HD IPB(SF : SuperFine /approx.26Mbps, F : Fine / approx.14Mbps, N : Normal / approx.10Mbps)
    *Frame rates may drop when particular Art Filters and Movie Effects are used.
    *Class 10 or higher SD card is recommended for shooting movies.
    *UHS-II or UHS-I U3 card is recommended for 4K,C4K,ALL-I shooting.
  2. Maximum Video Recording Time
    Approx. 29min 59sec
cacau
7 June 2008
20,263
Και εδώ μια ενδιαφέρουσα και πολύ παραστατική σύγκριση δίπλα - δίπλα με την προκάτοχο: https://www.ephotozine.com/article/...d-e-m5-mark-ii-comparison---what-s-new--34122
και το πρώτο field test - χρήση σε πραγματικές συνθήκες από το image resource: https://www.imaging-resource.com/PRODS/olympus-e-m5-iii/olympus-e-m5-i
...που κλείνει ως εξής: "Καταλήγοντας, η πολυαναμενόμενη Olympus E-M5 Mark III διαμορφώνεται ως ένα εξαιρετικό μέλος της οικογένειας OM-D, παρέχοντας ένα σημαντικό αριθμό αναβαθμίσεων σε σχέση με τη γερασμένη E-M5 Mark II. Σε σχέση με τα υπάρχοντα μέλη της γραμμής OM-D, ειδικά τις E-M1 II και E-M1X, η E-M5 Mark III ίσως να μην αισθάνεται σαν μια πρωτοποριακή φωτογραφική μηχανή, διατηρώντας τον ίδιο αισθητήρα, τον ίδιο επεξεργαστή, ουσιαστικά το ίδιο υβριδικό σύστημα AF , και συνολικά ένα πολύ παρόμοιο σύνολο χαρακτηριστικών λήψεων. Αυτό βλέπω ότι είναι κάπως απογοητευτικό για μερικούς, ειδικά για εκείνους που ίσως ήλπιζαν για ένα νέο αισθητήρα Four Thirds, καθώς το τσιπ 20MP είναι μαζί μας εδώ και αρκετό καιρό.Από την άλλη πλευρά, δεν έχω βρει πολλά για να παραπονεθώ όταν πρόκειται για την ποιότητα της εικόνας ή την απόδοση αυτής της κάμερας ή άλλων φωτογραφικών 20MP. Κατά κάποιον τρόπο, είναι σαν μια κατάσταση "αν δεν έσπασε, μην το διορθώσετε". Επιπλέον, δεδομένης της ιστορίας της Olympus με την παροχή σημαντικών αναβαθμίσεων του υλικολογισμικού (fw) που προσθέτει νέα χαρακτηριστικά και βελτιώσεις στην απόδοση, η νέα E-M5 III δείχνει σαν μια φωτογραφική μηχανή που θα διαρκέσει για τα επόμενα χρόνια. "
(google translate with some human help :) ).
kbouk
8 January 2010
21,939
ΠΕΙΡΑΙΑΣ
Δεν βρήκα πληροφορίες για τα έξτρα γκριπ ακόμη, εννοώ την μπαταριοθηκη κάτω από το κατακόρυφο έξτρα γκριπ
ECG-5 Dedicated External Grip (New, Sold Separately)Compatible ECG-5 dedicated external grip for an expanded, sure grip, equipped with a shutter release and control dial.
μια ελαφρύτερη και φθηνότερη ΕΜ1.2 βλέπω για την ώρα με έξτρα Bluetooth, Oled viewfinder και Usb charging , με χειρότερη όμως μπαταρία, γκριπ, εργονομία, ποιότητα κατασκευής και με αρκετά ειδικά χαρακτηριστικά της EM1.2 (ριπές, Procapture, focus bracketing κλπ) επίσης απομειωμενα για να μην κάψει το επαγγελματικό σώμα.
απο το dpreview hands on : The EVF refresh rate is also locked at 60 fps, compared to 120 fps on the E-M1 II and the difference between the two is noticeable when trying to follow fast action
cacau
7 June 2008
20,263
Βλέπω πολύ δύσκολη πορεία - στην χώρα μας τουλάχιστον - αν ξεκινήσει στα 1200 , με την EM-1 mkII στα 1300 και τις panasonic GX9 στα 600 από Ελλάδα, και G90 στα ~850 από Ευρώπη. Εντάξει, νέο μοντέλο μεν αλλά έχοντας την GX9 δεν βλέπω απολύτως κανέναν λόγο να σπρώξω 800 (επιεικώς) για την "τράμπα". Φαντάζομαι περίπου τα ίδια λ7 χρειάζεσαι (πάλι επιεικώς) αν θες να αναβαθμιστείς από την EM5 mkII. Δηλαδή κρατάς ότι έχεις και παίρνεις και μια G90... :bigcry:
edit: για να μην αναφέρω τι παίρνεις εκτός m4/3...
cacau
7 June 2008
20,263
Τες πα, ας έρθει να την δούμε από κοντά γιατί ως γνωστόν, άλλο τα ξερά χαρακτηριστικά κι άλλο η πραγματική εμπειρία χρήσης. Παράλληλα ελπίζω να κάνει κάποια κίνηση η εδώ αντιπροσωπία - το συνηθίζει...
karamela
6 November 2013
10,453
Βασικά απογοήτευση για μένα. Πρώτων έβαλαν μικρότερο σκόπευτρο και ίδιας ανάλυσης με της em5II (μόνο και μόνο για αυτό για μένα απορρίπτεται σαν αγορά). Μάλιστα το σκόπευτρο είναι πιο μικρό και από τις em10III (WTF????!!!)...το σώμα είναι πλαστικό πλέον (επίσης WTF????!!!). Η οθόνη είναι επίσης η ίδια 3 ιντσών και μέτριας ανάλυσης της em5II. Το χεράτο HR δεν μπήκε, η μπαταρία παρέμεινε μικρή, δεν έχει 4Κ 60p, Ούτε slog, ακόμα και το ibis έχει μόλις 0,5 stop διαφορά από της em5ΙΙ (5 stop vs 5,5 stop), ε οκ πιο πολύ σαν μια καλή αναβάθμιση της em10III είναι παρά της em5III....Βασικά έπρεπε να λέγεται em10IV με τιμούλα 800-900 ευρώ το πολύ....κρίμα.
Υ.Γ. Δημήτρη όπως τα λες είναι....μην ξεχνάς και τις προσφορές που έπαιζαν στα Amazon στο χιλιάρικο και πιο κάτω ακόμα για την G9....αν θέλει κάποιος Olympus απλά παίρνει την em1II στα ίδια λεφτά και αν δεν τον ενδιαφέρει το βίντεο απλά χτυπά μια em5II ή μια παλιά em1 και είναι μια χαρά....κρίμα και πάλι κρίμα...βέβαια με γλίτωσε από έξοδα!!
kbouk
8 January 2010
21,939
ΠΕΙΡΑΙΑΣ
Απάντηση: Re: Olympus E-M5 Mark III
Γιατί η ΕΜ1.2 θα είναι ακριβότερη και βαρύτερη και τα περισσότερα έξτρα χαρακτηριστικά της δεν αφορούν τους ερασιτέχνες
η τιμή της είχε πέσει καπως αλλά νομίζω οτι τώρα θα μείνει κοντά στο 1.5 χιλιάρικο
Το σκόπευτρο δεν θα το καταδίκασα πριν το δω, έτσι έλεγαν και για το σκόπευτρο της Penf που ήταν Oled και εγώ δεν είχα κανενα πρόβλημα όταν άλλαζα μηχανή από ΕΜ1.2 σε Penf, επίσης υπογράμμισα τα 27mm απόσταση από το γυαλί του, αυτό αφορά την καθαρότητα από άκρη σε άκρη και χωρίς παραλάξεις στις γωνιές για σωστή γεωμετρία. Περισσότερο με ενοχλεί η ταχύτητα ανανέωσης αν ρυθμίζεται σε υψηλότερο frame rate που διάβασα στο dpreview οτι δεν το βρήκαν. Φυσικά θα ήθελα στα specs ένα σκόπευτρο σαν της G9 αλλά όχι τόσο στην ΕΜ5.3 όσο στην ΕΜ1.2 που είναι το βασικό επαγγελματικό σώμα.
ΥΣ
Μάλλον δεν υπάρχει έξτρα μπαταριοθηκη , προσπαθώ να δω το κατακόρυφο γκριπ σε φωτό αν έχει λαστιχένια τρύπα υποδοχή για έξτρα οριζόντιο γκριπ ή είναι τρύπα για να μπαινοβγαζεις την μπαταρία, δεν το έχω καταφέρει να το βρω ακομη
22 June 2006
34,697
NEO HRAKLEIO
κωστα την em1 II την βρισκεις ελλαδα στα 1200 !
Και σιγα το πολυ βαρος που εχει.... ουτε γι αστειο δεν θθα επαιρνα την EM5 III
και μονο για το μικρο EVF που βαλανε, τη μικρη μπαταρια, πλαστικη κατασκευη, ελλειψη headphone jack κλπ ουτε που θα την κοιταγα!
karamela
6 November 2013
10,453
Re: Απάντηση: Re: Olympus E-M5 Mark III
ΥΣ
Ναι Κώστα άλλα πλαστικό σώμα και σκόπευτρο πιο μικρό και από της em10III??? Πραγματικά τι σκέφτονταν εκει στην Olympus?? Τουλάχιστον έβαλαν υβριδική εστίαση και σώζεται κάπως το γλυκό. Επίσης δεν έχει σχεδόν τίποτα ιδιαίτερο και σχεδόν τίποτα που να μην το έχει ήδη η em1II 3+ ετών...κρίμα και πάλι κρίμα....προτρέχω άλλα μην παραπονιέται μετά η Olympus ότι έπεσαν οι πωλήσεις της με τέτοιες κινήσεις. Το ξαναλέω για μένα αυτή η μηχανή είναι μια Em10IV...έτσι θα πρέπει να υπολογίζεται....
karamela
6 November 2013
10,453
Την em1II την είχα πάρει από Ελλάδα μαζί με τον 12-40 σε προσφορά που έτρεχε παλιότερα στα 1.550 ευρώ αν θυμάμαι καλά, είχα δώσει τον φακό 450 ευρώ και μου είχε βγει το σώμα 1.100 καινούριο σφραγισμένο από Ελλάδα!!!
Προφανώς με αυτή την τιμή σχεδόν κανένας δεν θα πάρει την em5III....ίσως αναθεωρήσουν την τιμή της πάντως...
Καλά για το βάρος μιλάμε για 150 γρ. διαφορά από την em1II....τρίχες, μόνο και μόνο το καλύτερο grip της em1II αξίζει να έχεις μηχανή 150 γρ. παραπάνω..έτσι και αλλιώς και η em5III θα θέλει έχτρα grip για να την δουλέψεις σοβαρά.
Βασικά είναι μηχανή με τιμή 800-900 ευρώ max αρχική...κάπου εκει έπρεπε να κάνει....να το ξαναπώ πλαστικό σώμα στην σειρά em5 και σκόπευτρο μινιατούρα??? Πάνε καλά???
Y.Γ. Καλά την Pl10 την είδες??? Μας κάνουν πλάκα??? Σχεδόν καμία διαφορά από την pl9??
