Mini LED οπίσθιος φωτισμός για τις LCD τηλεοράσεις : Neo QLED,QNED Mini LED...κ.λ.π.
xavito
29 October 2008
8,975
- Mini LED backlighting LCD tvs -
-Mini-LED is here: How smaller lights could lead to big TV improvements...https://www.cnet.com/news/mini-led-is-here-how-smaller-lights-could-lead-to-big-tv-improvements/
-Can miniLED backlight transform LCDs?...https://www.displaydaily.com/article/display-daily/can-miniled-backlight-transform-lcds
-[Research article]...High dynamic range liquid crystal displays with a mini-LED backlight...https://pdfs.semanticscholar.org/c17a/6ee3eb4a77d3fd87c64d90443e0bc2e5c7fc.pdf
-TCL showcases miniLED-based LCD TVs...https://www.flatpanelshd.com/news.php?subaction=showfull&id=1536217274
-X10S Mini LED TV 65"...https://avclub.gr/forum/showthread....p-2019?p=1058322490&viewfull=1#post1058322490
-TCL X10 (8 Series) 4K Mini LED TV Detailed: 768 Zones; 15360 LEDs!...https://avclub.gr/forum/showthread....p-2019?p=1058342577&viewfull=1#post1058342577
-TCL unleash 75-inch 8 Series 4K Mini LED TV: 1000 Zones, QLED, $2999...https://avclub.gr/forum/showthread....p-2019?p=1058366181&viewfull=1#post1058366181
-TCL 8-Series (Q825) 4K Mini LED TV Review: Is It An OLED Killer?...https://avclub.gr/forum/showthread....p-2019?p=1058392884&viewfull=1#post1058392884
[Display Dynamics] Comparing the LCD TV, dual cell LCD TV, mini LED backlight LCD TV, QLED LCD, and OLED TV...https://technology.ihs.com/617765/d...tv-mini-led-backlight-lcd-tv-qled-and-oled-tv
source:[technology.ihs.com]
σημ:Ο όρος Mini-LED αναφέρεται στην τεχνολογία του οπίσθιου φωτισμού(backlight) του LCD.
Χωρίζονται σε δύο κατηγορίες:
1.Passive Matrix (PM)
2.Active Matrix (AM)
xavito
29 October 2008
8,975
Re: - Mini LED backlighting LCD tvs -
WitsView (research division TrendForce) research firm sees mini LED direct-lit backlighting LCD tv market expansion ahead...https://hdguru.com/23114-2/
source:[hdguru.com]
xavito
29 October 2008
8,975
Αν και monitor είναι άξιο αναφοράς λόγω mini led οπίσθιου φωτισμού.
We review the Asus ProArt PA32UCX-P 4K HDR monitor,
featuring a 32-inch screen,
Mini LED backlighting with 1152 full-array local dimming (FALD) zones,
a quoted peak brightness of 1200 nits
& Rec.2020 coverage of 89%,
as well as support for HDR10, HLG & Dolby Vision.
source:[hdtvtest.co.uk]
IPS panel - RGB LCD
WCG_quantum dot
48x24=1152
Native ANSI blacks was 0.13 cd/m2(nits) ,if peak white was set at 120 cd/m2 with local dimming disabled,giving native contrast ratio 923:1.
With local dimming enabled (dynamic dimming) ANSI blacks was 0.03 cd/m2(nits), if peak white was set at 120 cd/m2.
Strongly recommend using some sort of biased lighting.
50/60Hz = motion resolution came in at the sample and hold baseline of 300 lines.
HDR peak light output : 1494 cd/m2 on a 10% window after calibration to D65 white point.
DCI-P3 color gamut coverage :99% uv
Rec.2020 color gamut coverage :89%
Asus PA32UCX-PK test,calibration...https://hdtvpolska.com/czy-mamy-zlo...dla-ekspertow-ze-studia-filmowego/?showfull=1
source:[hdtvpolska.com]
xavito
29 October 2008
8,975
Re: -Samsung TV Line-up 2020-
Several reports have all but confirmed that Samsung will launch its first Mini LED TV among its 2021 QLED TV lineup. The first is an online presentation given by Mr Bob O'Brien, Co-Founder & President of DSCC (Display Supply Chain Consultants), at the OLED World Summit 2020 earlier this week.
papasouzakias
13 May 2009
4,523
Η Samsung και η LG θα κυκλοφορήσουν Mini LED LCD τηλεοράσεις το 2021.
Η Samsung θα κυκλοφορήσει 4K Mini Led τηλεοράσεις στις 55, 65, 75 και 85 ίντσες.
Η LG θα κυκλοφορήσει Mini Led τηλεοράσεις στις 70", 4Κ και 8Κ με την επωνυμία NanoCell και θα απευθύνεται στο High End επίπεδο της αγοράς.
Αναμένεται και οι υπόλοιπες κινέζικες εταιρείας όπως η TCL, Konka και Skyworth να κυκλοφορήσουν τις δικές τους υλοποιήσεις
Επίσης η LG θα προμηθεύσει την Apple με τις νέες Mini Led Backlit LCD οθόνες για τα νέα iPad, MacBook και iMac του 2021
http://www.thelec.net/news/articleView.html?idxno=1814
Ducksong
11 July 2013
4,984
The Dutch Mountains
Η λέξη forsake σημαίνει "εγκαταλείπω"
Δηλαδή, κατείχε η Samsung την τεχνολογία παραγωγής OLED τηλεοράσεων και αποφάσισε να την αφήσει πισω?? :flipout::flipout::flipout:
sosimple
15 April 2007
835
Ναι. Έχει βγάλει τηλεόραση με oled. Οπως και ταμπλετα με 12αρα συν κινητά. Έχει εργοστάσιο oled (διαφορετικης αρχιτεκτονικής απο της Lg). Αν θέλει κανει μαζική παραγωγή και τηλεοράσεων με oled. Ενα διάστημα βγήκε είδηση οτι θα το κανει. Το παραπάνω μάλλον δείχνει οτι δε θα το κάνει, αλλά ακομα ολα ειναι ρευστά.
xavito
29 October 2008
8,975
Περιπαικτικά το λέει ο Ducksong,φαντάζομαι.
xavito
29 October 2008
8,975
Mini LED TV has been forecast to surpass OLED TV in terms of premium TV market share after 2024, according to a press release issued by Korean market research and consultancy firm UBI Research.
We discuss the company's predictions, while taking the opportunity to clear up a couple of myths regarding Mini LED TVs.
Original press release here:http://ubiresearch.com/mini_ledtv/
xavito
29 October 2008
8,975
papasouzakias
13 May 2009
4,523
Οι αρχικές τιμές των Mini LED της Samsung είναι 25% ακριβότερες από τις OLED.
Samsung Mini LED TV is 25% more expensive than LG OLED TV, and
TV consumers are likely to choose'price sensitive' OLED ↑
OLED TV sales expected to be 5.6 million units this year
Ολόκληρο το άρθρο: https://translate.google.com/transl...e/data/html_dir/2021/02/26/2021022601899.html
jazzu4ia
28 June 2006
135
outer space
...τι λέτε ρε παιδιά...
...γιά τις miniled θα μιλάμε ;
...έρχονται πλέον οι nanoled, πιό καλές απ' τις OLED και πιό φτηνές απ' τις microled...
...όλες οι άλλες ωχριούν...
