- 18 August 2006
- 16,589
https://www.apple.com/airpods-pro/
Σχετικά απότομα εμφανίστηκαν
Και λένε και άμεσα διαθεσιμα
Σχετικά ενδιαφέρον (αν και όχι πρωτότυπος) ο σχεδιασμός με τα εναλλάξιμα ακροφύσια (ελπίζω σε κάποιο που να
μην απομονώνει πλήρως (με το οποιο κόστος φυσικά στην αποτελεσματικότητα του noise cancelling) καθώς κάτι
τέτοιο με ενοχλεί)
Αστείο επίσης κοντόχοντρο σουλούπι
Audio Technology | - Active Noise Cancellation - Transparency mode - Adaptive EQ - Vent system for pressure equalisation - Custom high-excursion Apple driver - Custom high dynamic range amplifier |
Sensors | - Dual beamforming microphones - Inward-facing microphone - Dual optical sensors - Motion-detecting accelerometer - Speech-detecting accelerometer - Force sensor |
Chip | - H1-based System in Package |
Controls | • Press once to play, pause or answer a phone call •• Press twice to skip forwards ••• Press three times to skip backwards — Press and hold to switch between Active Noise Cancellation and Transparency mode Say “Hey Siri” to do things like play a song, make a call or get directions |
Sweat and Water Resistant | - Sweat and water resistant (IPX4) |
Size and Weight | AirPods - Height: 30.9 mm - Width: 21.8 mm - Depth: 24.0 mm - Weight: 5.4 grams Charging Case - Height: 45.2 mm - Width: 60.6 mm - Depth: 21.7 mm - Weight: 45.6 grams |
Charging Case | - Works with Qi-certified chargers or the Lightning connector |
Battery | AirPods - Up to 4.5 hours of listening time with a single charge (up to 5 hours with Active Noise Cancellation and Transparency off) - Up to 3.5 hours of talk time with a single charge AirPods Pro with Wireless Charging Case - More than 24 hours of listening time - More than 18 hours of talk time - 5 minutes in the case provides around 1 hour of listening time7 or around 1 hour of talk time |
Connectivity | Bluetooth 5.0 |
Accessibility | - Accessibility features help people with disabilities get the most out of their new AirPods Pro. - Live Listen audio |
In the Box | - AirPods Pro - Wireless Charging Case - Silicone ear tips (three sizes) - Lightning to USB-C Cable - Documentation |
Price | 279 στην Ευρώπη |
Web Page | Apple |
