AVClub.
  • Login:
1 9 12345 ...
1 10 85
  1. #1
    Sony KD AG8 : Reviews - -
    service Sony A8F.
    , 2019.
    test...
    5% .
    antroit oreo 8. 2 .
    . 2014 .
    https://www.sony.gr/electronics/tileoraseis/ag8-series
    Sony KD AF8 (2018).
    KD AG8BAEP : 55",65"
    OLED panel (CF+WOLED by LG Display 2019 version),
    QFHD (3840 x 2160) ,X1 Extreme,WCG (aka Triluminos Display) ,100/120Hz + black frame insertion,HDR10/HLG/Dolby Vision,IMAX Enhanced certification,
    Speaker Position Front + Down Firing,2.2ch Actuator (29 x 42mm) x2,Woofer (38 x85mm) x2,Acoustic surface,40W (10+10+10+10)
    Android TV (Nougat 7.0) & upgradable to Android tv 8.0 Oreo) ,
    DVB-T2 HD (H.265/HEVC) x2,DVB-S2 x2.
    HDMI x4 (ARC -HDMI 3)
    USB x3 (USB 3.1 x1)
    Headphone/Speaker Link:Yes (Subwoofer Out)
    PVR Ready
    Screen mirroring support : Yes
    Bluetooth : A2DP ,.
    Reversible two-way stand
    Calman app (CalMAN for BRAVIA)...https://calmankb.groovehq.com/help/s...r-series-guide
    SoC
    Platform : Sony BRAVIA ATV3
    MediaTek MT5891
    Core Architecture: 4x ARM Cortex-A53
    CPU Cores: 4
    Installed RAM : 2 GB
    GPU Renderer : Mali T-860
    GPU Cores : 2
    --FAQ- -iMANUAL--FIRMWARE
    [sony.gr]...KD-AG8 series...https://www.sony.gr/electronics/supp...roid-/kd-65ag8
    XBR A8G...http://www.sonypremiumhome.com/premi...vision/A8G.php
    Specs:
    XBR-55A8G...http://www.sonypremiumhome.com/pdfs/...eet_012819.pdf
    XBR-65A8G...http://www.sonypremiumhome.com/pdfs/...eet_012819.pdf
    Dimensions:
    XBR-55A8G...http://www.sonypremiumhome.com/pdfs/55A8G_Cut_Sheet.pdf
    XBR-65A8G...http://www.sonypremiumhome.com/pdfs/55A8G_Cut_Sheet.pdf
    Made in Slovakia.
    Sony XBR65A8G teardown,disassebly
    Service manual GN5TR Chassis 9-888-769-01
    Self Diag. Quick Reference (LED blinking)
    Smart Core RED LED blinking count
    2x : <B/G> Main 12V over voltage [MAIN_POWER]
    3x: <B/G> Main 5.0V failure [DC_ALERT]
    3x : <B/S/G> Audio amp. protection [AUD_ERR]
    4x : <T/B>TCON internal error/TCON I2C communication error[LD_ERR]
    5x : <P/T/G/B> Panel ID EEPROM I2C No ACK
    (Also panel power failure is a suspect) [P_ID_ERR]
    <T/B>Data corruption in EEPROM[P_ID_ERR]
    6x : <G/B> G board error[BACKLIGHT]
    7x : <B/P> Over temperature protection [TEMP_ERR]
    <B> Temp. sensor I2C No ACK [TEMP_ERR]
    8x : <B> 4KBE Error (4KBE WDT)
    <G>: Power supply board,
    <B>: Main board,
    <T>: T-con board,
    <LD>: LD board,
    <P>: Panel module,
    <S>: Speaker
    Self Diagnosis service menu
    Entry (Self Diagnosis Display) - Go to the standby by a remote.
    Push the buttons sequentially: <Display><5><Vol-><Power>
    Exit
    If you want to finish service mode app, do AC OFF/ON →*Service mode app is disable perfectly
    if you want to move home menu, push <HOME>button →*Service mode app do background(not disable perfectly)
    How to confirm
    - Panel ON time
    - Panel Refresh times
    Enter Self Diagnosis Display.
    Then Push Green button on remote controller.
    Then display upper right corner.
    Panel ON time[hour] /Panel Refresh times[times]
    Ex) 100 / 20
    SERVICE ADJUSTMENT
    When finished the operation of service mode , please AC Plug OFF/ON the TV set
    *If you dont do AC plug OFF/ON, remain the Service Mode App and user can see the Service Mode after RC ON.
    How to Enter Service Mode
    From Standby Mode
    1.Go to TV standby condition by remote commander.
    2.Press “Display or i+ (info)”, “5”, “Volume+” then “TV power” on remote.
    3.You can see Service menu on display.
    Reviews - tests :
    65"...[lesnumeriques.com]...Sony KD65AG8 test...https://avclub.gr/forum/showthread.p...post1058352699
    65"...[lcdtvthailand.com]...Sony KD65A8G review...https://avclub.gr/forum/showthread.p...post1058357739
    65"...[homecinemamagazine.nl]...Sony KD-65AG8 review,calibration settings...https://avclub.gr/forum/showthread.p...post1058385356
    55"...[rtings.com]...Sony XBR55A8G review...https://www.rtings.com/tv/reviews/sony/a8g-oled
    Calibration settings...https://www.rtings.com/tv/reviews/so...-oled/settings
    55"...[avforums.com]...Sony KD55AG8BU review,calibration...https://avclub.gr/forum/showthread.p...post1058355802
    55"...[tvtest.pl]...Sony KD55AG8 test...https://avclub.gr/forum/showthread.p...post1058382460
    55"...[tweakers.net]...Sony KD55AG8 review...https://avclub.gr/forum/showthread.p...post1058414415
    - ...https://avclub.gr/forum/showthread.p...post1058300728
    KD65AG8 : 3.399
    KD55AG8 : 2.399
  2. #2
    , oled .
    burn in A8F pc .
    video .
    , tv ( ) - .
  3. #3
    Re: Sony KD AG8 : Reviews - -
    antroid 9.
    ... antroid 7 , (apk) . 7 AF8.
    Sony ... Cortex A53 ARM Mali T860 gpu . Sony, , .https://tweakers.net/nieuws/160894/s...android-9.html
    1) , , .
    2) .
    3) , . ... standard Sony (monitors)
    , (H264) 2GB player ARCHEOS.
  4. #4
    Oct 2018
    115
    H Android 9 Pie Dolby Atmos V ( DD+) , pass eARC DOLBY ATMOS , DD+.
  5. #5
    dts 7.
    Sony Atmos .( 9)
    ... soc
    8... Android.
  6. #6
  7. #7
    videoclip .
    1) player store ( apk) Sony , player.
    , ... videoclip pixel ... .
    ... Sony - Sony-player Sony.
    80 GB A8f (Android 7-8) player ( Dolby dts .
    . HDR .
  8. #8
    55AG8 , Sony kd 49xf9005! burn in OLED ! 5 !
    Sony burn in ?
  9. #9
    Jan 2014
    165
    . . ' , burn in.
  10. #10
    play station panel 3 4 !!
Users Browsing this Thread
1 . (0 1 )
Bookmarks
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Back to top
