Να το τολμησω ?
ΚΩΣΤΑΣ.Κ
8 February 2019
8
ΙΩΑΝΝΙΝΑ
Καλησπερα στο φορουμ.
Μπαινω κατευθιαν στο θεμα.
Εχωενα ζευγος ηχεια και συγκεκριμενα τα JBL TLX-14 σε αριστη κατασταση με τα εξης χαρακτηριστικα
JBL TLX14 Specifications
Type: 2 way, 2 driver loudspeaker system
Recommended Amplifier: 10 to 100W
Crossover Frequency: 3000Hz
Impedance: 8Ω
Sensitivity: 90dB
Bass: 1 x 210mm polymer laminate cone
Tweeter: 1 x 25mm titanium dome
Το ερωτημα μου ειναι το εξης
Αν τα συνδεσω στο παρακατω συστημα προενισχυτη /ενισχυτη με χαρακτηριστικα τα εξης
PARASOUND NewClassic 2100 2.1 Channel Preamplifier / Features Specs
Frequency Response
10 Hz - 100 kHz, +/- 3 dB
THD Distortion
< 0.008% at 20 Hz
S/N Ratio
> 105 dB, input shorted, IHF A-weighted
> 95 dB, input shorted, unweighted
Crosstalk
> 75 dB at 20 kHz
Input Impedance
30 k Ω
Output Impedance
< 60 Ω
Input Sensitivity
250 mV for 1 V output
Total Gain: 12 db
Maximum Output: 6.5 V
AC Power Requirement
110-250 V, 50 - 60 Hz
Voltage is automatically selected
5 watts standby; 10 watts when turned on
και
Parasound NewClassic Model 2125 2channel power amplifier
specs
Continuous RMS Power Output
20 Hz - 20 kHz, Both Channels Driven
125 watts x 2, 8 Ω
200 watts x 2, 4 Ω
200 watts x 2, 2 Ω
20 Hz - 20 kHz, Bridged Mono
400 watts, 8 Ω
400 watts, 4 Ω
Current Capacity
35 amps peak per channel
Frequency Response
20 Hz - 50 kHz, +0/-3 dB, 1 watt
Dynamic Headroom
1.3 dB
Total Harmonic Distortion
0.025% at full rated output
0.015% at average listening levels
IM Distortion
0.05 %
Transient IM Distortion
Not measurable
S/N Ratio
114 dB at rated output, IHF A-weighted
106 dB at rated output, unweighted
93 dB at 2.828 V output, IHF A-weighted
84 dB at 2.828 V output, unweighted
Input Impedance
33 k Ω
Input Sensitivity
1 V in for 28.28 V out, THX standard
Inter-Channel Crosstalk
85 dB, 1 kHz
73 dB, 10 kHz
67 dB, 20 kHz
Damping Factor
Over 150 at 20 Hz
Auto Turn On - DC
9 - 12V, 15 mA
Auto Turn On - Audio
1.2 mV - 12 mV, adjustable
15 minute turn off delay
110 - 120 V / 220 -240 V, 50 - 60 Hz
3 watts standby; 550 watts full output
θα εχω προβλημα με καποιο απο τα δυο η με τα ηχεια η με τον ενισχυτη ?
ευχαριστω πολυ και περιμενω τα φωτα σας
ΚΩΣΤΑΣ.Κ
ika
20 September 2010
4,864
Αν ως πρόβλημα εννοείς το αν καούν τα ηχεία αν βάλεις τέρμα τα γκάζια, θα ακούσεις το woofer να διαμαρτύρεται πριν γίνει κάτι και θα προλάβεις να το χαμηλώσεις.
Στις άλλες περιπτώσεις δεν θα έχεις κάποιο πρόβλημα εφόσον προσέξεις την στάθμη του σήματος που τροφοδοτείς τον προ, ο οποίος έχει ευαισθησία εισόδων 250mV για 1V έξοδο.
Αν πχ βάλεις επάνω ένα CDp με 2V έξοδο, θα παίρνεις το 1V και συνεπώς και τα 125W αρκετά πριν τερματίσει το VOLUME του προ.
Ως γνωστόν "Μεγάλος ενισχυτής καίει woofer, μικρός καίει tweeter"
To ζόρισμα του woofer θα το ακούσεις, το συνεχές που θα κάψει το tweeter όχι.
ΚΩΣΤΑΣ.Κ
8 February 2019
8
ΙΩΑΝΝΙΝΑ
Ευχαριστω για τις απαντησεις σας
1ον για καλυτερα ηχεια δεν παιζει γιατι το συστημα ειναι δευτερευον δεν ειναι κυριο
2ον τερμα γκαζια δεν υπαρχει περιπτωση αφ'ενος γιατι δεν ακουω σε υπερβολικα μεγαλες εντασεις και αφ'ετερου λογο γειτονων.
και μια διευκρινηση σε αυτο που ανεφερες ika1961 δηλαδη επειδη εχω συνδεμενο για μουσικη (flac) κυριως και μπλου ρει ταινιες το DUNE BD PRIME 3.0 ΘΕΛΕΙ ΠΡΟΣΟΧΗ ?
υ.γ με ενα ζευγος B&W DM640 (150 watt 8ohm )που εχω και καθονται αχρησιμοποιητα ταιριαζει καλυτερα σαν συνολο ?
vlad66
29 October 2017
15,032
Αγιοι Αναργυροι
μαγαζί έχεις φίλε μου;; :laugh:
αν αυτά είναι σε δευτερεύον, στο πρωτεύον τι έχεις;;; :laugh:
τα 640 θα τα προτιμούσα στο σετ
ika
20 September 2010
4,864
Αφού δεν ακούς δυνατά δεν υπάρχει πρόβλημα.
Δεν ξέρω πόσα V δίνει το DUNE (φαντάζομαι εννοείς ότι έχεις συνδέσει στο audio out δηλ L-R), θα το γράφει το εγχ χρήσης του, αλλά σαν CD άντε να βγάζει επίσης 2V.
Συνεπώς θα ακούγεται πιο δυνατά από όσο θεωρητικά θα έπρεπε στη θέση που είναι το volume.
john gabriel
Φιλε μου καλε τα ενισχυτικα που εχεις φτανουν και περισευουν δεν εχεις να φοβάσαι τιποτα !! τα ενισχυτικα που εχεις υπερ καλυπτουν τα ηχεια απλως το μονο που χρειαζεσαι είναι να τα οδηγήσεις σωστα! :2thumb22sup:
ika
20 September 2010
4,864
Αφού τα έχεις και κάθονται, τι σε εμποδίζει να τα βάλεις στον ενισχυτή σου (που παίρνει 2 ζεύγη ηχείων) και να κάνεις συγκριτικό Α <-> Β να δεις τι σου αρέσει?
ΚΩΣΤΑΣ.Κ
8 February 2019
8
ΙΩΑΝΝΙΝΑ
Πρωτευον ειναι αναγκαστικα vlad66 οχι γιατι ειναι καλυτερος ποιοτικα αλλα γιατι ειναι πιο συμμαζεμενος, καθ'οτι ολοκληρομενος o (ΥΑΜΑΗΑ Α-501-S), λογο χωρου δηλαδη.
Οσο για το τι με εμποδιζει να τα βαλω στον ενισχυτη φιλε ika1961 και να τα συγκρινω ειναι η μετακινηση,ειδικα για τα B&W , δυστιχως δεν ειναι ολα στον ιδιο χωρο.
ευχαριστω για τις απαντησεις σας.
