- 29 October 2008
- 8,978
-Samsung TV Line-up 2021-
-The first 2021 Samsung QLED LCD tvs have been certified in Korea...https://www.hdblog.it/tv/articoli/n530659/samsung-qled-tv-2021-certificati/
source:[hdblog.it]
-Model codes of the Samsung 2021 QLED mini LED LCD tvs (QA90A, QA80A, QA70A ...)...https://www.4kfilme.de/modellcodes-samsung-2021-qled-mini-led-tvs-qa90a-qa80a-qa70a/
source:[4kfilme.de]
-On closer inspection, we can notice the following division into series:
The QNA90 and QNA85 will be high-end models that could use the aforementioned miniLED backlight.
We can notice that we find the letter "N" in the name. According to some speculation, Samsung could differentiate these series from others under the trade name QLED Neo, but the use of other, recently registered trademarks such as QLED +, QLED Z or QLED Premium is not excluded.
The QA70A and QA60A will most likely be mid-range models with standard LED backlighting, which are also used in this year's QLED TV.
It is not clear why Samsung added "A" after the letter "N" (current generations bear the shorter names Q70T and Q60T). At the same time, it is strange that the generation designation after the model name does not continue with the letter "U" or "V", but starts with "A".
The remaining names then probably refer to LCD TVs without Quantum Dot technology, such as the successor to The Frame lifestyle models.
source:[tvfreak.cz]
-Samsung TV Line-up 2020-
