[Φήμες] Samsung Galaxy A72 / A52 / A42
Status
Not open for further replies.
Blue08
24 April 2008
23,334
Utopia..
Ένα από τα νέα κινητά που αναμένουμε να δούμε μέσα στους πρώτους μήνες του 2021 από την Samsung
είναι το νέο A72 το οποίο θα υποστηρίζει και 5G.
Τα μέχρι τώρα στοιχεία που φαίνεται να έχει το νέο κινητό της Samsung αναφέρουν:
Network Technology : GSM / CDMA / HSPA / EVDO / LTE / 5G
- 2G bands GSM 850 / 900 / 1800 / 1900 - SIM 1 & SIM 2 (dual-SIM model only)
CDMA 800 / 1900
- 3G bands HSDPA 850 / 900 / 1900 / 2100
HSDPA 850 / 900 / 1700(AWS) / 1900 / 2100
CDMA2000 1xEV-DO
- 4G bands LTE
- 5G bands SA/NSA/Sub6
- Speed HSPA 42.2/5.76 Mbps, LTE-A, 5G
Launch Announced Not announced yet
Status Rumored
Body
- Dimensions 165 x 77.4 x 8.1 mm (6.50 x 3.05 x 0.32 in)
- Weight -
- SIM Single SIM (Nano-SIM) or Hybrid Dual SIM (Nano-SIM, dual stand-by)
Display : Type Super AMOLED Plus
- Size 6.7 inches, 108.4 cm2 (~84.9% screen-to-body ratio)
- Resolution 1080 x 2400 pixels, 20:9 ratio (~393 ppi density)
- Protection Unspecified
Platform : OS Android 11, One UI 3.0
Memory : Card slot microSDXC (uses shared SIM slot)
Internal 128GB 8GB RAM
UFS
Main Camera : Quad 64 MP, f/1.8, 26mm (wide), 1/1.72", 0.8Βϴm, PDAF
12 MP, f/2.2, 123˚ (ultrawide)
5 MP, f/2.4, (macro)
5 MP, f/2.2, (depth)
Features LED flash, panorama, HDR
Video 4K@30fps, 1080p@30/240fps, 1080p@960fps; gyro-EIS
Selfie camera : Single 32 MP, f/2.2, 26mm (wide), 1/2.8", 0.8Βϴm
Features HDR
Video 4K@30fps, 1080p@30fps
Sound :
- Loudspeaker Yes
- 3.5mm jack Yes
Comms :
- WLAN Wi-Fi 802.11 a/b/g/n/ac, dual-band, Wi-Fi Direct, hotspot
- Bluetooth 5.0, A2DP, LE
- GPS Yes, with A-GPS, GLONASS, GALILEO, BDS
- NFC Yes (market dependent)
- Radio Unspecified
- USB USB Type-C 2.0, USB On-The-Go
Features :
Sensors Fingerprint (under display, optical), accelerometer, gyro, proximity, compass
ANT+
Battery :
-Type Li-Po, non-removable
- Charging Fast charging 25W
Misc :
Colors Black, Blue, White, Violet
Models SM-A726B
Price About 490 EUR
Via:
Blue08
24 April 2008
23,334
Utopia..
Re: Samsung A72
Samsung Galaxy A72 5G: Τα πρώτα renders, έρχεται με τετραπλή κάμερα
https://techblog.gr/mobile/samsung-galaxy-a72-5g-ta-prota-renders-erchetai-me-tetrapli-kamera/
Είναι το κινητό που έχω βάλει στο μάτι για να περάσω στο 5G! :cool:
Μιά χαρά από τα χαρακτηριστικά που βλέπω! :a0210:
- Σε σχέση με το S20 FE έχει καλύτερη Camera και Video 1080p@960fps !!
* Btw "σκοτώνουν" τώρα τα τελευταία αποθέματα του Α71 στα 399 ευρώ..
Lobo10
23 May 2012
3,882
Re: Samsung A72
Ο επεξεργαστής του s20fe είναι Snapdragon όμως..
Blue08
24 April 2008
23,334
Utopia..
Re: Samsung A72
Δεν έχουν μπει ακόμη τα στοιχεία για τον επεξεργαστή του A72..
Θα δούμε..
Κάτι πληροφορίες που βρίσκω για Snapdragon λένε..
αν και το S20 FE έχει καλύτερο...
Chipset Qualcomm Snapdragon 765G - 7 nm
CPU Octa-core (2x2.2 GHz Kryo 470 Gold & 6x1.8 GHz Kryo 470 Silver)
GPU Adreno 620
vadergr
17 August 2007
27,437
Μεταμορφωση
Re: Samsung A72
Θα δούμε..
GPU Adreno 620
Έχει ακουστεί για snapdragon 720g 5g
Lobo10
23 May 2012
3,882
Re: Samsung A72
Εδώ τα βρήκα εγώ :
https://specifications-pro.com/en/samsung-galaxy-a72/
To 71 είχε :
OS
Android 10, One UI 2.5
ChipsetQualcomm SDM730 Snapdragon 730 (8 nm) - Global
Qualcomm SDM730 Snapdragon 730G (8 nm) - Philippines
CPUOcta-core (2x2.2 GHz Kryo 470 Gold & 6x1.8 GHz Kryo 470 Silver)
GPUAdreno 618
O Snap 865 του S20FE ήταν ο top επεξεργαστής του 2020,καλύτερος του exynos των note20ultra/s20ultra.
Αυτοί που λέτε είναι midrange , καμία σχέση..
Blue08
24 April 2008
23,334
Utopia..
Re: Samsung A72
Δεν αντιλέγουμε ότι το S20 FE είναι σε άλλη κατηγορία, και στην κορυφαία σειρά της Samsung.. :cool:
Αλλά πάντως έχει κάποια χαρακτηριστικά το A72 που του ρίχνει!! :cool:
π.χ κάμερα 64 Mp vs 12 Mp !! :cool:
Αν το S20 FE είχε την κάμερα του A72 θα το χτύπαγα και πάνω από τα 700.. (μαζί με δωράκι..) :p
Όταν θα του κάνουν καλή έκπτωση θα αξίζει πιο πολύ!
Lobo10
23 May 2012
3,882
Re: Samsung A72
- Αν το S20 FE είχε την κάμερα του A72 θα το χτύπαγα και πάνω από τα 700.. (μαζί με δωράκι..) :p
Δεν παίζουν ρόλο μόνο τα mp σε ένα φακό να ξέρεις..
Οι κάμερες του p40 είναι λιγότερα mp από του note 20 ultra και τραβάνε καλύτερες φωτογραφίες..
Blue08
24 April 2008
23,334
Utopia..
Re: Samsung A72
Ναι, παίζει και αυτό..
Και το θέμα της τιμής βέβαια συνολικά..
Εμένα πιο πολύ με χάλασε που δεν βγάζει 1080p@960fps ..
θέλω να δω αυτό το χαρακτηριστικό στο νέο κινητό που θα πάρω..
Yperion
21 June 2006
43,515
BVR (Beyond Visual Range)
Re: Samsung A72
Τα κινητά της Samsung δεν συμφέρουν σαν αγορά εφόσον σε πολύ χαμηλότερη τιμή προσφέρουν ανάλογες αν όχι καλύτερες συσκευές η Xiaomi και η Realme.
Αν είχε 300-350 ευρώ (το πολύ) να το συζητάγαμε. Τώρα πληρώνεις 200 ευρώ πάνω το σήμα της Samsung.
songless_bird
8 May 2013
11,110
Νότια Μακεδονία
Απάντηση: Re: Samsung A72
Αν η 64αρα είναι σαν του note 20 μην ενθουσιάζεσαι.
Δηλαδη δεν θα το αγοραζα με βάση αυτό σαν κριτήριο. Θεωρώ το s10 lite με τον 855 καλύτερο τηλέφωνο στα ίδια χρήματα. Εκτός αν χρειάζεσαι το 5g...
Blue08
24 April 2008
23,334
Utopia..
Re: Samsung A72
Δεν θέλω να πάω σε κινέζικα.. :cool:
Έχω πάρει κάτι για τους δικούς μου.. δεν μου αρέσουν.. :p
Μετά το Tab S7+ θα μείνω Samsung λέω, με καμιά καλή προσφορά έστω.. :cool:
Ναι, είναι πρώτη επιλογή το 5G για να πάω σε νέο κινητό τώρα..
Το έχω 3-4 χρόνια το SONY που έχω τώρα.. :p
Blue08
24 April 2008
23,334
Utopia..
Re: Samsung A72 / A52 / A42
Λοιπόν, είπα να γράφω για όλη την νέα σειρά A της Samsung εδώ..
και να σας πω ότι βάλανε το νέο Samsung Α42 - 5G που κυκλοφορεί εδώ και λίγο καιρό,
με έκπτωση στα 299 ευρώ.
Χαρακτηριστικά:
https://www.gsmarena.com/samsung_galaxy_a42_5g-10412.php
Ενώ περιμένουμε την κυκλοφορία του Samsung A72 - 5G,
παράλληλα περιμένουμε και την κυκλοφορία του νέου Samsung A52 - 5G
https://www.gsmarena.com/samsung_galaxy_a52_5g-10631.php
Yperion
21 June 2006
43,515
Κινητό 300 ευρώ με οθόνη 720p το 2021...Έχει και 4 GB RAM που και αυτό είναι μεγάλο foul για την τιμή του.
Δυστυχώς το αγόρασε ένας φίλος μου που δεν πρόσεξε ότι έχει τόσο χαμηλής ανάλυσης οθόνη και το είδα και απο κοντά. Δεν είναι άσχημο αλλά η οθόνη και η RAM το σκοτώνουν τελείως.
Blue08
24 April 2008
23,334
Utopia..
Όντως αυτό πιστεύω και εγώ ότι είναι το μεγαλύτερο φάουλ στο νέο A42..
To A41 είχε 1080x2400 pixels οθόνη..
https://www.gsmarena.com/samsung_galaxy_a41-10138.php
Όπως φαίνεται κάνει κάτι τέτοια αρνητικά η Samsung στα νέα μοντέλα της ίδιας σειράς..
Blue08
24 April 2008
23,334
Utopia..
Status
