iphone video recorder...
nikolis9
2 November 2007
889
To install this application on your iPhone, you must know how to jail-break the iPhone and install the software needed. The following sites provides excellent information on this topic.
http://www.hacktheiphone.com/
http://hackint0sh.org/forum/showthread.php?t=3284
Install Method 1: installer.app method
Please add iPhone Video Recorder source http://www.iphone-recorder.com/install2 to your iPhone installer.
How-To: Add third-party sources to your iPhone's Installer.app
iPhone Video Recorder Source: http://www.iphone-recorder.com/install2
After refresh your installer source, you will find iPhone Video Recorder in Multimedia category, install it.
Install Method 2: PXL package method
Download the PXL package below and use with Breezy (mac), iBrickr (windows) or using the PXL MobileSafari plug in to install it.
Download iphonevideorecorder.pxl (1.0MB)
Supports firmware 1.0.x, 1.1.x (All known versions) iPhone
nikolis9
2 November 2007
889
3, Where can we find the recorded files?
For firmware 1.1.2 or below: /private/var/root/Media/iPhoneVideoRecorder
For firmware 1.1.3 and 1.1.4: /private/var/mobile/Media/iPhoneVideoRecorder
7, How to transfer it to my computer?
You can send it out by email, and then you can receive it on any computer.
nikolis9
2 November 2007
889
Full ...YES..
UPDATE FOUND A CRACK!!!! UNLIMITED RECORDING THANKS TO SOMEONE AT HACKINT0SH.ORG
Replace @ with an a
http://[email protected]/?5rbnew1mf1t
Install the original one from the installer. Then SSH to the iphone, go inside the VideoRecorder.app application, replace the iphonerecorder binary with the link provided.
johny1989
17 December 2007
2,573
καλο.ισως δουμε και με πιο μεγαλη αναλυση βιντεο.
framerate?στα 320*416?
Blackjim
13 June 2007
93
Re: Απάντηση: iphone video recorder...
Λιγα :(
Δες info απο μερικα video.
Code:
General #0
Complete name        : C:\Users\Anthony\Desktop\Cam-2008-05-11 13-16-14.mp4
Format               : MPEG-4
Format/Info          : ISO 14496-1 Base Media
Format/Family        : MPEG-4
File size            : 528 KiB
PlayTime             : 12s
Bit rate             : 361 Kbps
StreamSize           : 2.65 KiB
Encoded date         : UTC 1970-01-01 00:00:00
Tagged date          : UTC 1970-01-01 00:00:00
Video #0
Codec                : MPEG-4 Visual
Codec profile        : Simple Profile/Level 1
Codec settings/BVOP  : No
Codec settings/QPel  : No
Codec settings/GMC   : 0
Codec settings/Matri : Default
PlayTime             : 12s
Bit rate             : 334 Kbps
Width                : 320 pixels
Height               : 416 pixels
Display Aspect ratio : 0.769
Frame rate           : 6.083 fps
Minimum frame rate   : 3.333 fps
Maximum frame rate   : 10.000 fps
Resolution           : 8 bits
Chroma               : 4:2:0
Interlacement        : Progressive
StreamSize           : 489 KiB
Audio #0
Codec                : AAC LC
Codec/Info           : AAC Low Complexity
PlayTime             : 11s 648ms
Bit rate             : 26 Kbps
Channel(s)           : 2 channels
Channel positions    : L R
Sampling rate        : 8000 Hz
Resolution           : 16 bits
StreamSize           : 36.6 KiB
Code:
General #0
Complete name        : C:\Users\Anthony\Desktop\Cam-2008-05-11 13-13-37.mp4
Format               : MPEG-4
File size            : 783 KiB
PlayTime             : 12s 700ms
Bit rate             : 505 Kbps
StreamSize           : 3.92 KiB
Video #0
Bit rate             : 478 Kbps
Width                : 320 pixels
Height               : 240 pixels
Display Aspect ratio : 4/3
Frame rate           : 11.654 fps
Minimum frame rate   : 5.000 fps
Maximum frame rate   : 20.000 fps
Resolution           : 8 bits
Chroma               : 4:2:0
StreamSize           : 740 KiB
Audio #0
Codec                : AAC LC
PlayTime             : 12s 416ms
Bit rate             : 25 Kbps
StreamSize           : 38.2 KiB
Code:
General #0
Complete name        : C:\Users\Anthony\Desktop\Cam-2008-05-11 11-38-46.mp4
Format               : MPEG-4
File size            : 1.65 MiB
PlayTime             : 32s 500ms
Bit rate             : 425 Kbps
StreamSize           : 5.38 KiB
Video #0
Bit rate             : 396 Kbps
Width                : 320 pixels
Height               : 416 pixels
Frame rate           : 6.031 fps
Minimum frame rate   : 2.222 fps
Resolution           : 8 bits
Chroma               : 4:2:0
StreamSize           : 1.54 MiB
Audio #0
Codec                : AAC LC
PlayTime             : 32s 128ms
Bit rate             : 28 Kbps
StreamSize           : 108 KiB
johny1989
17 December 2007
2,573
ε γιατι διακοσμιτηκη?
καλο βιδεο τραβαει σε σχεση με καποια αλλα κινητα πολυ καλυτερο
Blackjim
13 June 2007
93
αμα λεω οτι ειναι διακοσμητικη η κάμερα του Iphone δε με πιστευει κανείς...
Το οτι δε γραφουν σοβαρο software δε σημαινει οτι το hardware ειναι για πεταμα.
Ελπιζω καποιος να γραψει ενα σοβαρο προγραμμα και να εχουμε καλο video recording.
johny1989
17 December 2007
2,573
με 600mhz cpu μπορει να τραβιξει σε ποιοτητα dvd .σιγουρα θα γινει καποια στιγμη
Φρα.Πε.
6,443
Ελευσίνα
ee καλα τωρα, βρειτε κανενα κινητομε 2mp (αν υπάρχουν ακομα)και συγκρινετε, χωρια που δεν εχει και φλας...
Οκ περιμενω σοβαρο software να δω....
H cpu ειναι χρονισμενη στα 420Mhz
johny1989
17 December 2007
2,573
σε εμενα δεν δουλευει η καμερα βιδεο βγαζει μαυρη οθονη γιατι?
johny1989
17 December 2007
2,573
EINAI EΠIKYNΔINO;ΣBHNONTAI OΛA AKOMA KAI OI EΠAΦEΣ E;ΔEN NOMIZΩ NA ΦTAEI TO THΛ ΓIATI EINAI ENTEΛΩΣ KAINOYPΓIO,TI ΣTO KAΛO;
Φρα.Πε.
6,443
Ελευσίνα
ολα ειναι επικυνδυνα, ο takeda ειναι μανα στα restore για να σε βοηθήσει.. εγω ακομα δε χρειάστηκε να κανω εμαθα να ζώ έτσι.. με τα κουσούρια του..
johny1989
17 December 2007
2,573
σκεφτομαι να κανω οταν βγει η 2 εξαλου το videorecorder μπορει να βγαλει εκδοση που να λειτουργει/
οταν ειναι θα τον ρωτησω πως
ευχαριστω
tfd1978
8 April 2008
18
Full ...YES..
Replace @ with an a
ΕΙΣΑΙ ΤΕΛΕΙΟΣ!!!!!!!!!!!!! ΑΠΛΑ ΤΕΛΕΙΟΣ!!!!!!!!!!!!!! :firstprize:
