Τεχνολογικά νέα, καινοτομίες .... από τη Pentax - Ricoh
racer
2 February 2009
2,911
Rotterdam
Re: PENTAX news??
Είμαι περίεργος να δω αν αυτά θα είναι επίσημα brochures..
NtinNton
8 September 2008
3,281
Re: PENTAX news??
Εκτός από το όνομα που χάνει την γερμανόφωνη αγορά αν έχει πάλι τον ίδιο αισθητήρα είναι αυτοκαταστροφική κίνηση. Εκτός αν είναι καμμία τόσο μελλοντική ανακοίνωση
NtinNton
8 September 2008
3,281
Re: PENTAX news??
Από pentaxforums. News or Rumors θα δείξει
One of our forum members recently posted a leak from a French Pentax forum about the Pentax K30, which is rumored to be the new intro-level DSLR replacement for the Pentax K-r. This would seem to be the first rumor which is more than just plain speculation, as a credible photo of the camera has appeared in a French catalogue that has not yet been published. This leads us to suspect that the camera will be made available this summer, rather than at Photokina, as Pentax typically informs retailers about their products no earlier than 1-2 months before launch.
The camera's name change may suggest a departure from convention, as this new Pentax is weather sealed, has additional external buttons, and has two e-dials: a first in an intro-level Pentax DSLR. On top of that, it seems to have been redesigned quite significantly, meaning that this camera will be much less of a derivative than its two predecessors. Like the K-m/K-x/K-r, however, the Pentax K30 will not have a top LCD.
The launch price is rumored to be higher than that of the K-r: 799 euros for the kit, or some $900 in the US.
The preliminary Pentax K30 specifications are as follows:
* 16 Megapixel sensor (likely inherited from the K-5)
* Full HD video recording (framerate unknown, likely same as the K-01)
* Weather sealed body
* 3-inch LCD
* Uses AA or rechargeable batteries
* 4FPS shutter (slower than in the K-r, but will we see a bigger buffer to compensate?)
* ISO range: 100-25,600
The introduction of weather sealing in a budget DSLR body may make this camera a success. We remain hopeful that it will launch sooner rather than later!
Πάλι με τον συγκεκριμένο αισθητήρα??? Περίμενα κάτι διαφορετικό
Θετικότατο το WS body λίγο πιο ακριβή από το συνηθες η τιμή μεγάλο ερωτηματικό και πάλι η βελτίωση στο af
NtinNton
8 September 2008
3,281
Re: PENTAX news??
Ανακοινώθηκε και υπόσχεται τελείως διαφορετικό και βελτιωμένο σύστημα AF ειδικά σε κινούμενα θέμα και σε LV καθως και βελτιωμένο processor σε σχέση με K-5 και K-01. Αναμένεται τον επόμενο μήνα οπότε θα δούμε και περισσότερα. Πάντως αν πράγματι βελτιώσαν το AF είναι σημαντικότατη βελτίωση με συμπαθητική για τα όσα προσφέρει τιμή. Αναμένω με "αγωνία" και τον αντικαταστάτη της Κ-5 που θα περιλαμβάνει πιθανότατα όλες τις βελτιώσεις συν νέο καλύτερο αισθητήρα καθώς και τους νέους φακούς που θα "κρίνουν" την πληρότητα του συστήματος και την αντοχή του στον ανταγωνισμό (ο νέος 50αρης στα ~200 δεν είναι ελκυστικός για τους παλιους κατόχους όσο γρήγορος και αν ειναι σε φοκους IMHO)
peperr
25 May 2011
1,532
Marathon Lake
Re: PENTAX news??
Κάτι νέο ετοιμάζει Η Pentax. Φημολογείται ότι θα είναι μια φθηνή έκδοση της Κ-01
racer
2 February 2009
2,911
Rotterdam
Μη μας το κάνεις αυτό Pentax, δε θα αντέξω τόση ομορφιά μαζεμένη.. :p
cacau
7 June 2008
20,326
Re: PENTAX news??
Κάτι τέτοια ακούω, συν την τιμή της "μικρής" Nikon FF στα 1500-1600 και με βλέπω να φορτώνομαι κανένα κιλό και βάλε ευγενή μέταλλα και κρύσταλλα...
peperr
25 May 2011
1,532
Marathon Lake
Re: PENTAX news??
Φίλε Δημήτρη δεν με ενοχλεί το φόρτωμα του FF κιλού, αρκεί στην ούγια να γράφει Pentax! Προσωπικά μπήκα στο τρένο του μάρκετινγκ των κανονίκον και σύντομα την έκανα με πλάγια πηδηματάκια....
NtinNton
8 September 2008
3,281
Re: PENTAX news??
Αν "τολμήσει" να βγεί σε τέτοια τιμή θα πάει άπατη.
NtinNton
8 September 2008
3,281
Re: PENTAX news??
Βασικά πιστεύω ότι η φιλολογία για pentax FF σώμα υπάρχει ώστε να ανεβαίνουν οι τιμές των παλιών primes που έτσι και αλλιώς είναι καλοί. Μου φαίνεται δύσκολο να εμφανίσει σώμα και να έχει μόνο 4 AF primes να το συνοδεύσει.
Ας βγάλει το κροπ σώμα που θα αντικαταστήσει τη Κ-5 σε τιμή που να έχει λογικό gap με την K-30 και το μερίδιο που θα πάρει θα είναι μεγάλο
