Ta naim ειναι απ οσο ξερω φτιαγμενα να παιζουν κοντα στον τοιχο.
Επισης τα audio note δες αυτο¨:
In common with our more conventional ported speakers, the Zero AZ Series speakers
are designed to be placed very close and at an angle to a rear wall or preferably with
the rear horn mouth firing assymetrically into a corner close to the side walls, this
positioning has been chosen because being a horn it improves bass response and low
frequency cut off for reasons already discussed.
It is vitally important to understand that the proximity of the AZ-Three to the rear wall
or corner, if you experience problems with the bass, try moving the speaker closer to
the wall, or try to change the angle of the speaker.
The best performance is achieved by corner placement and if placed in a corner, the
AZ-Three should be angled so that the on-axis line of the drive units crosses about 1 - 2
meters in front of you, with the back corner of each speaker almost touching the side
wall (see diagram 1). Even in a hotel room it is possible to reduce to boom and bass
