Οθονη DNP Supernova για θεαση με φως ημερας!
takisot
Μέλος Δ.Σ.
27,852
Παλλήνη
Λετε να ειναι η λυση?
DNP Supernova Screen for Daytime Viewing
November 30th, 2006
The sun shines just as brightly in Denmark as it does anywhere else, and Danish engineers have created a new projector screen that allows for viewing in the brightest of environments, especially during the daytime. DNP’s Supernova screen sports an amazing 2.0 gain and a 20:1 contrast, which is ten times that of a normal projector screen and comes in a wide variety of sizes and aspect ratios - from a 45 inch 4:3 screen to a 150 inch 2.35:1 Cinemascope screen. DNP claims that the Supernova screen will work with any projector, but you’ll have to match up the screen size with the throw ratio on the projector for best reasults. Still, such a powerful screen doesn’t come cheap: approximately $849 for the most inexpensive model.
[via Engadget]
Browser
10,575
H εταιρια εχει εξελιξει κι αλλο τα υλικα της, κι εχει κατασκευασει οθονες και για χρηση σε οικιακο κινηματογραφο.
Supernova 08-85 screen material
This ISF-certified screen material features true deep black levels, high contrast and extreme viewing angles. It is especially well-suited to use in low-light environments but can also be used in bright rooms when combined with a more powerful projector. ISF (Imaging Science Foundation) certification defines the very highest quality of displays. Available for: Supernova One, Supernova Core, Supernova Epic, Supernova Infinity, Supernova Flex and Supernova Flex Classic. Supernova Mobile uses Supernova 08-85A screen material optimized for table-mounted projectors.
http://www.dnp-screens.com/DNP08/Products/Front-projection/Screen-materials.aspx
Η "φτηνη" σειρα Supernova Core I και η πιο ακριβη Supernova Core IΙ οσον αφορα τις σταθερες οθονες-καδρα.
Τα specs της οθονης.
http://www.dnp-screens.com/DNP08/Products/Front-projection/Fixed-screens/dnp-Supernova-Core.aspx
Browser
10,575
7 layers - 7 times more contrast
Standard front screens passively reflect the projected image – and all ambient light – back in all directions. Supernova goes beyond the limitations of standard front screens by using an active optical system. Made up of 7 high-tech layers to enhance the image for optimum viewing.
Layers include
Unique optical lens film to reduce the impact of ambient light
Technologically advanced reflection layer for revolutionary half-gain angles up to +/- 85˚
Black colour layer that sets new standards for colour reproduction
Hard surface coating for screen scratch resistance and a no-shimmer image
http://www.dnp-screens.com/DNP08/Products/Front-projection/About-dnp-Supernova.aspx
takisot
Μέλος Δ.Σ.
27,852
Παλλήνη
Εγώ αναγκαστικά στρεφομαι σε ηλεκτρική 120', οποτε supernova flex classic; Τους ρωτησα για τιμή και περιμενω την ψυχρολουσια.. :p
Browser
10,575
Αν κανω τετοια κινηση με βλεπω να πεταω την τηλεοραση απο εκει και να παω σε σταθερη !
Περιμενω νεα σου :ernaehrung004:
takisot
Μέλος Δ.Σ.
27,852
Παλλήνη
Αν ειχα option για σταθερή, θα ψηνομουν παααρα πολύ δεδομενης και της "φθηνής" core..
Browser
10,575
Aυτα "ψαρεψα" απο το αγγλικο avs σε ποστ του 2011.....
SuperNova Core (2.35:1) 0.8 & 23/23 GAIN
100" SNS Core £2,100
114" SNS Core £2,300
128" SNS Core £3,600
Black Diamond 0.8 (2.40:1) 0.8 & 1.4 GAIN
92" BD £2800
100" BD £2950
106" BD £3100
119" BD £3450
a 16.9:1 DNP Flex Classic 84" electric retractable screen with remote is £2850.00 inc vat and delivery
a 16.9:1 DNP Supernova Core 84"fixed frame is £1555.00 inc vat and delivery.
Anyway back on track the price of the DNP Supernova One 84" 16.9:1 screen with 23/23 Silver Aluminium frame would be £1910 inc vat & del.
....no comments.....
spcav
18 August 2006
16,597
Re: Απάντηση: Οθονη DNP Supernova για θεαση με φως ημερας!
Booiiinggg.... Απο τι ειναι φτιαγμένη, φύλλα χρυσου; :p
Οχι αλλα μαλλον πληρωνεις το R&D.
Κατι σαν την Apple ας πουμε :p
takisot
Μέλος Δ.Σ.
27,852
Παλλήνη
Αυτό θα ίσχυε αν ήταν λιγο πιο ακριβή από τον ανταγωνισμό.. Εδώ μιλάμε πως η Stewart είναι κελεπουρι μπροστά της! :p
spcav
18 August 2006
16,597
Αυτό το ''λιγο'' χρηζει αναλυσης...:p
Παιζει ρολο παντως και το ποσες μπορούν να πουλήσουν / ποσες γενικα οθόνες πωλούνται.
Θελω να πω, προφανως, αναγκαστικα ισως, προσπαθουν να βγαζουν το κερδος απο λίγα κομματια.
Browser
10,575
Τουλαχιστον εντυπωσιακο.
Κι αυτος που εκανε το review, αν μη τι αλλο ειναι γνωστης. Εχω διαβασει παρα πολλα αρθρα του στο παρελθον και δεν αφηνει τιποτα να πεσει κατω.
Επισης ενδιαφερον εχει το θεμα με τo screen noise που προεκυψε απο τον βαμενο τοιχο, κατι που δεν ειχε ουτε απο τη supernova ουτε απο το matte white δειγμα.
Browser
10,575
Απάντηση: Re: Οθονη DNP Supernova για θεαση με φως ημερας!
Δεν ειναι μονον αυτο. Περα απο το r&d υπαρχει και το θεμα κατασκευης. Ουτε μπορω να φανταστω πως φτιαχνεται αυτη η οθονη με τοσα ειδικα layers !
spcav
18 August 2006
16,597
Re: Απάντηση: Re: Οθονη DNP Supernova για θεαση με φως ημερας!
Η αληθεια ειναι οτι δεν εχουμε εικόνα τι ακριβώς ''ειναι'' οπότε δυσκολο να εκτιμηθει και το κοστος.
Σε καθε περιπτωση παντως, ότι και να ναι, αν μιλουσαμε για πιο μαζικη παραγωγη, μαλλον το κόστος (και σίγουρα η τιμή πώλησης) θα επεφταν δραματικα.
Browser
10,575
Υπαρχουν στοιχεια στο site της εταιριας ωστε να εκτιμησεις :p
spcav
18 August 2006
16,597
Ψιτ, αυτά στον Γκάλη, όχι σ εμένα, νταξ; :p :p :p
Από το review:
The Supernova is layered screen technology. Seven layers to be exact. Seven layers of which there secret is known to only a few dnp employees. What Manfred did know he was happy to share though. The bottom layer is a high reflective layer and the subsequent layers vary between translucent layers and contrast filter layers.
Read more: http://www.hometheatershack.com/for...18759-dnp-supernova-review.html#ixzz2S8ATZkyj
35,671
Απάντηση: Re: Απάντηση: Οθονη DNP Supernova για θεαση με φως ημερας!
Από το review:
Ναι, ο Γκάλης εσένα περίμενε το 2013 για να ανακαλύψει την Supernova!!:p
Έχει και άλλα αρθράκια το site....ξέρεις για βαφές, μπογιές κ.λ.π. και τις κόντρες τους με σούπερ ντούπερ οθόνες!!:p
spcav
18 August 2006
16,597
Α, ρε Νικο, ησαν παντα τοσο μπροστα....
(εξαιρούνται τα προβολικά (και τα σεξουαλικά) σου γούστα)
:p :p :p
35,671
:p :p :p
Περίμενα να μου απαντήσεις:
''Α, πολύ ωραία θέματα έχει αυτό το site!! Θα διαβάσω σίγουρα για τις ουδέτερες οθόνες, τα gain, τις βαφές, τα φινιρίσματα, τα συγκριτικά κ.λ.π.''
αλλά...φευ. Έμεινες μόνο στον σχολιασμό ενός αστεϊσμού.-bye-
