Αγαπητοί φίλοι και φίλες.
Back to J113.
I run some drain current tests with various resistors and various voltages today.
Results suggest:
For:
5-10mA IDSS (less likely to find in current production J113) keep the same 270 Ohm R4 R7 R8 value
10-20mA IDSS use 560 Ohm R4 R7 R8
>20mA IDSS use 750 Ohm R4 R7 R8
When having few samples from different IDSS ranges, use the appropriate resistor value to each sample's position.
J1 corresponds to R4
J2 corresponds to R7
J3 corresponds to R8
Prefer the lowest IDSS samples for J3 when its for 5V rail set regs.
Sorting J113s for IDSS takes a semiconductors tester or to put them on a breadboard and connect G+S pins together. Use +15V with a milliamper meter between +V and D (drain) pin in series. 0V to S pin. That is the datasheet's test voltage. Using a 9V battery will give bit less IDSS but still indicative.
Test the samples replacing one by one in the rig. Measure carefully to avoid accidental shorts that can break the mA measuring DMM's fuse. Note their results on paper. Place each sample next to its mA note.
Because J113 is 35V rated don't use higher than 28VAC transformer.
Thus the Ubib's suggested max output shortens to 33VDC for good enough Vin-Vout margin when using this JFET type.
Although PF5102 and J113 are brothers, in general I prefer the PF5102 due to its lower more predictable IDSS range and 5V higher official spec. Seems like that type is a subset of J113 production with more controlled characteristics. While coming from the same chopper JFETs family it is alternatively described as low frequency low noise amplifier in the manufacturer's website.
Δεν έχω τα 2SK369BL και έκανα μία σκέψη να χρησιμοποιήσω στη θέση τους τα 2SK170BL που έχω μερικά ταιριασμένα ακόμα ή αν είναι δυνατόν τα 2SK389GR που επίσης έχω. Υπάρχει αυτή η δυνατότητα αλλαγής και με τι διαφορές στις αντιστάσεις πάνω κάτω απ αυτά;
Σπύρο ποιος το προτείνει το j113 αντί του pf5102;
θα πρέπει να ξανα υπολογήσεις τις αντιστάσεις για να έχεις το ίδιο κέρδος. Βέβαια γίνεται εύκολα αφού ούτως 'η αλλλως θα βάλεις διακόπτες.
Η διαφορά του 113 με το 112 ?
Έχω αρκετά καθώς κάποτε ήθελα να φτιάξω το Η2 του Pass.
Αυτό το quote για J113 είναι από το νήμα του Ultrabib. Χρειάζεται να υπάρχουν θέσεις source resistors για να έρθουν σε λογαριασμό με τα χαμηλότερου IDSS PF5102 που αντικαθιστούν (συγγενείς). Στο 1.3S τροφοδοτικό υπάρχουν Rs θέσεις, αλλά στο Q7 του φόνο όχι. Εκεί εναλλακτικά βάλε κοντινού αρκετά IDSS ανά κανάλι 2SK117GR η ακόμη και 2SΚ170GR στην ανάγκη.
Αρχικά στα Q1 Q2 θα δοκιμάσω Κ170BL που έχω πρόχειρα
Θα έχεις προβλήματα, θα βγει λάθος το φόνο.
