AVS JVC DLA-RS1 Review...
takisot
Μέλος Δ.Σ.
27,853
Παλλήνη
O Jason Turk του Avsforum εκανε το καθιερωμενο του review για τον πολυαναμενομενο Jvc Rs1, με πολλα κολακευτικα σχολια:
http://www.avsforum.com/avs-vb/showthread.php?t=812816
takisot
Μέλος Δ.Σ.
27,853
Παλλήνη
"Onto the measurements. ........................................................................... At one of my settings, I was able to achieve over 18000:1 on/off contrast! Now that is impressive. To date, I have not tested a projector that comes even close to this level (in fact, the closest I got to this before was less than ½ that result). The unit has good brightness as well. I was able to achieve as high as 632 lumens (at D65 remember) from the RS1. Though not considered a light-cannon, this is plenty of output for most theater applications.
Alright, now it was time to put in some source material and fire up an image. In a word…gorgeous. The first thing anyone will notice is the deep black levels. They are black. In fact, when I was measuring for contrast I had to get my meter very, very close to the lens to even get it to take a reading. This translates directly to the image. This is the first projector I would comfortably put up against a CRT in this arena. Yes, the black levels are that good. This in turn aids in making the colors absolutely pop. All the colors were extremely rich and saturated, but not to the point of being “cartoonish”. They still remained very natural looking. The unit is capable of excellent sharpness. In fact, this is by far the sharpest projector in this general technology class (DILA, LCOS, SXRD, and LCD). I do find that DLP still has a tad of an edge in this regard, but not by much anymore and the gap I’m sure will close with future versions of this. I tested this on my 103” Vutec Silverstar, and the image just jumped off the screen....
takisot
Μέλος Δ.Σ.
27,853
Παλλήνη
MEASUREMENTS:
As I mention in other reviews, I keep these to a relatively non-technical level. I find that though many are into the specs and measurements, not everyone has a good understanding, nor is even interested in the real technical stuff. That being said, I did take some measurements for those who are interested. Remember, my room is not an ideal setup for measuring. So the projector is really capable of better results in a perfect testing environment. Rather my results are what you might expect to get in a typical theater when properly setup. The below numbers are calibrated (D65) results as well.
On/Off Contrast-Max Throw: ~18772:1
On/Off Contrast-Min Throw: ~14346:1
ANSI Contrast-Max Throw: ~314:1
ANSI Contrast-Min Throw: ~274:1
Light Output-Max Throw: ~486 lumens (High Lamp), ~384 lumens (Low Lamp)
Light Output-Min Throw: ~632 lumens (High Lamp), ~531 lumens (Low Lamp)
takisot
Μέλος Δ.Σ.
27,853
Παλλήνη
CONCLUSIONS:
The RS1 is an amazing piece in any regard. But pair it with the low retail pricing, and it is going to be hard to beat. The unit will outperform virtually anything to date in the lower price category, and even outperforms many of the higher end price point units. With the best available on/off contrast levels, D65 calibration out of the box, excellent sharpness, and vibrant colors, you have to look into this piece if you are considering front projection. Personally, this is the unit by which I will compare others for some time..
Mihalis S.
3,497
Εμένα αυτό με ανησυχεί: "The vertical offset is +/- 80% of screen height, and horizontal offset is +/- 36% of width" περισσότερο για το οριζόντιο. Με τον +/- 50% του Epson είμαι οριακά.
Babis K.
28,653
Δεν πολυκατάλαβα.....
Τι σε ανησυχεί στην οριζόντια μετακίνηση Μιχάλη; Σε σχέση με την οθόνη που έχεις τοποθετήσει τον προβολέα;
Mihalis S.
3,497
Ναι Μπάμπη, δηλ. αν είναι αρκετή η οριζόντια μετακίνηση του φακού ώστε να υπάρχει μεγαλύτερη ευκολία στην τοποθέτηση του προβολέα σε σχέση με το πανί. Αν φυσικά αντιλαμβάνομαι σωστά το +/- 36%....
Το είχαμε συζητήσει για τον DILA θυμάσαι;
Babis K.
28,653
Kατάλαβα...
Mιχάλη, νομίζω οτι αν κάποιος θέλει να τοποθετήσει τον προβολέα του έτσι ώστε να μην είναι υποχρεωμένος να τον κεντράρει ακριβώς στην οθόνη, αν πχ θέλει να αποφύγει ένα πολύφωτο στο ταβάνει που παρεμβάλλεται μεταξύ πανιού και προβολέα, μπορεί άνετα να το κάνει, και μάλιστα χωρίς κάποιο πρόβλημα στην εικόνα του.
Αν τώρα κάποιος θέλει να τον τοποθετήσει εκτός των ορίων του πανιού του αυτό όντως δεν γίνεται αλλά είναι λίγο υπερβολικό και μάλλον σπάνιο αυτό το setup.
spcav
18 August 2006
16,598
Re: Απάντηση: AVS JVC DLA-RS1 Review...
Όπως είναι γνωστό, το lens shift καλό είναι να αποφεύγεται σε κάθε περίπτωση.
Εντάξει, το κάθετο πολλές φορές είναι δύσκολο να το αποφύγεις (καθώς εξαρτάται και από την γωνία υπό την οποία ο κάθε προβολέας προβάλει στην οθόνη), η χρήση όμως και του οριζόντιου lens shift είναι η ντροπή κάθε σοβαρού χρήστη :p
Σοβαρά πάντως εμένα με αγχώνει λίγο το +/- 80 του κάθετου (καθώς δεν θυμάμαι πόσο είμαι με τον Epson τώρα). Aλλά από την άλλη πόσο να ζητήσει κανείς; +/- 5 οθόνες; :p
Mihalis S.
3,497
Τάσο εκεί ακριβώς είναι το πρόβλημα το δικό μου!
Μπάμπη μάλλον έχω πέσει στο σπάνιο setup. Για να καταλάβεις, δεν μου πολυαρέσει η τοποθέτηση του προβολικού στο ταβάνι. Εκτός κι αν είναι κρυμμένος, άρα ιστορίες με γυψοσανίδες και τέτοια. Προς το παρόν δεν είναι εφικτό. Επί του δικού μου setup για να καταλάβεις τον έχω τοποθετήσει στα 4 μέτρα απόσταση από την οθόνη και ευθυγραμμισμένο αλλά στην δεξιά πλευρά της οθόνης. Το vertical του Epson είναι +/- 100% και το horizontal +/- 50%. Ετσι όπως είναι τώρα σεταρισμένος, μπορεί να μετακινηθεί η εικόνα οριζόντια ακόμη 5 εκατοστά μετά γιοκ. Και ο φακός του Epson είναι και τέρμα αριστερά. Φαντάσου λοιπόν αν η οριζόντια μετακίνηση περιορίζεται στο +/-36%. Αυτό είναι το πρόβλημα ώστε να μπορέσω να διατηρήσω παρόμοιο setup έτσι; Αυτό εννοώ. Είναι ένα πρόβλημα.
Mihalis S.
3,497
Απάντηση: Re: Απάντηση: AVS JVC DLA-RS1 Review...
Γιατί βρε φίλε να αποφεύγεται; Εγώ που το οριζόντιο shift το έχω σχεδόν τερματίσει, τουλάχιστον στην γεωμετρία είμαι... άψογος. Τώρα πως θα τα καταφέρεις να μην κάνεις χρήση του κάθετου shift αν τον έχεις κρεμασμένο στο ταβάνι δυσκολεύομαι να το αντιληφθώ. Και υπό γωνία; ποια γωνία; προβάλει κανένας υπό γωνία;;
spcav
18 August 2006
16,598
Kατάλαβα...
Αν δεν κάνω λάθος (αν κάνω διορθώστε με), το lens shift είναι μετατόπιση του φακού και όχι αλλαγή της γωνίας του (κάτι το οποίο θα οδηγούσε και σε τραπεζοειδή προβλήματα).
Αν λοιπόν κατάλαβα καλά αυτό που λέει Μπάμπης, στην περίπτωση που αναφέρει (φωτιστικό ενδιάμεσα προβολέα και οθόνης) το πρόβλημα δεν λύνεται με το lens shift καθώς (πιθανότατα) πάλι η δέσμη θα ‘’πέφτει’’ στο φωτιστικό.
Ο μόνος τρόπος να αποφύγεις (σίγουρα) το φωτιστικό σε τέτοια περίπτωση είναι η αλλαγή γωνία προβολής (με ότι προβλήματα αυτό συνεπάγεται στην παραμόρφωση της εικόνας) και όχι η χρήση του lens shift.
Φυσικά η ισχύς των παραπάνω έχει να κάνει με την ακριβή γεωμετρία του όλου setup (προβολέας, φωτιστικό, οθόνη) και τις μεταξύ τους αποστάσεις, long / short throw του προβολέα κλπ.
spcav
18 August 2006
16,598
Re: Απάντηση: Re: Απάντηση: AVS JVC DLA-RS1 Review...
Τα πιθανά προβλήματα έχουν να κάνουν όχι τόσο με την γεωμετρία όσο με άλλα θέματα.
Ρίξε και μια ματιά εδώ (όλη τη σελίδα – όχι μόνο τα πρώτα post – o Μπάμπης γράφει κάτι ενδιαφέρον παρακάτω):
http://www.avclub.gr/forum/showthread.php?t=2291&page=19
Αυτό είπα και εγώ (για την περίπτωση του JVC όμως – διάβασε το παρακάτω quote).
Ναι.
Και (ανάλογα το μοντέλο φυσικά) μπορεί να μιλάμε για πολύ μεγάλη γωνία (η ευθεία του φακού φτάνει περίπου στο κάτω (ή πάνω - αν μιλάμε για τοποθέτηση στο ταβάνι) μέρος της προβαλλόμενης εικόνας).
Μερικά παραδείγματα που ξέρω σίγουρα (από προσωπική εμπειρία):
- EPSON TW 600
- NEC HT1000
Mihalis S.
3,497
Απάντηση: Re: Απάντηση: Re: Απάντηση: AVS JVC DLA-RS1 Review...
- EPSON TW 600
- NEC HT1000
Αντε βρε φίλε και μας μπέρδεψες... αυτό που περιγράφεις δεν είναι προβολή υπό γωνία. Αλλο πράγμα υπό γωνία, (δηλ. ο φακός του προβολέα δεν είναι ευθυγραμμισμένος με την οθόνη άρα προβάλει υπό γωνία) και άλλο αυτό που γράφεις τώρα.
Τώρα στο link που μου παραθέτεις δεν κατάλαβα τι θέλεις να δώ.
Babis K.
28,653
spcav, δές το σχήμα, θεώρησε στον κόκκινο κύκλο σαν φωτiστικό, και θα δείς τι εννοώ.
spcav
18 August 2006
16,598
Η γωνία μπορεί να είναι στον οριζόντιο ή στον κάθετο άξονα.
Πχ έτσι:
Πριν μιλούσα για υπό γωνία οριζοντίως καθώς μιλούσαμε γι αυτό που είπε ο Μπάμπης (δες παρακάτω).
Μπορείς να διαβάσεις σχόλια αναφορικά με το πως επηρεάζει το lens shift την ποιότητα της εικόνας.
Έχω καταλάβει τι εννοείς.
Γι αυτό γράφω πριν:
Πχ κοίτα στην ακόλουθη φωτό μία αλλαγή (το φωτιστικό πιο κοντά στην οθόνη ήπχ ο προβολέας πιο μακριά) στο setup και θα καταλάβεις τι εννοούσα.
Με λίγα λόγια το οριζόντιο lens shift δεν μπορεί να λύσει πάντα το πρόβλημα.
Babis K.
28,653
Καλά, αυτό εννοείται... Είπαμε, αυτό βοηθάει σε κάποιες περιπτώσεις, δεν λύνει όλα τα προβλήματα.
Αν είναι τόσο κοντά στην οθόνη το φωτιστικό την έκατσες, δεν υπάρχει σωτηρία.
