AZBOX PREMIUM HD
optex
31 August 2008
302
νομιζω καποιο περιοδικο για σατ τον εχει τεστακι αυτο το μηνα
nakata
11 June 2007
2,309
var/etc/home
τα τεχνικα χαρακτηριστικα του δεκτη ειναι
  • Linux as the operating system
  • PVR (recording) internal or external
  • WLAN (wireless to Internet)
  • NG RACE GoGo List (online station list update)
  • Webradio
  • Support video portals such as YouTube and other video
  • Audio & Music portals
  • RSS feeds
  • SIGMA processor SMP 8634 LF
  • SIGMA CHIP specification DTV-8634 pdf
  • 32 MB FLASH MEMORY
  • EEPROM 256 KB
  • SD RAM 256 MB
  • Smart Tuner Support
  • DVB-S2 / S, DVB-T2 / T (DVBs2 and DVB-T from thefactory) (8psk HD Turbo Code Tuner)
  • DVB-C2 / C, ISDB-T
  • GO GO List function (Intelligent Channel sorting)
  • MPEG4 HD and fully DVB compatible
  • 11 digit VFD display
  • 9 Front panel buttons (Power, OK, channel up, channel down, volume up, volume down, Menu, Exit, OK)
  • 7 day EPG 7 day EPG
  • Fuktion timeshift (pause and play live TV, time-recording of programs)
  • Receiver streaming (audio / video and radio)
  • Video On Demand
  • Wireless Wifi and RJ45 connection Wirelessly over WLAN and via RJ45 connection
  • Web interface for remote control of the receiver's
  • Update on the Internet, USB and serial port for update
  • Web browser
  • RSS newsreader
  • E-mail client (POP Only)
  • Audio formats: MP3, WAV, AIFF, WMA, Ogg Vobis
    Image: JPEG, BMP, TIFF, GIF, PNG
  • Video: MPEG1, MPEG2, MPEG4, DivX, XviD, MKV, AVI SSF (incl support subtitles)
  • Video-Audio Aüflösung: MPEG-2/MPEG-4 Part 10 AVC/H.264 HD, [email protected] 1920x1080 @ 50Hz (MPEG-2 transport stream specification ISO/IEC13818)
  • Input: max 90 MB /sec
  • Aspect ratio: 4:3, Letterbox, 16:9, Pan & Scan
  • 2 slots for Common interface
  • 2 Smart Card Reader
  • 2 x USB 2.0 (rear and front panel)
  • HDD LAN via Samba
  • IDE hard disk can be installed internally
  • Dolby Digital Optical output
  • HDMI port
  • 2x Scart
  • YUV / YUV Component Out / Component output
  • UHF connection
  • Size: 340x220x65mm Size: 340x220x65mm
  • Working Temperature: 0 ° C ~ 60 ° C
  • Storage Temperature: -20 ° C ~ 75 ° C
  • Power: 90 VAC ~ 240 VAC power switch
  • Max 40 Watt
  • Internal security
οντως παιζει ολα τα φορματ που αναφερουν και με υποτιτλους μπορει α τρξει το mbox as client και το κυριοτερο δεν χρειαζεται καμια ρυθμιση για να βρει ολους τους κοινοχρηστους φακελους σε τοπικο δυκτιο συνδεεται στο youtube και εχει υπεροχη εικονα καλυτερη απο τον DM800 και το κυριωτερο προσφερει εικονα 1080p
τωρα τι δεν δουλευει
δεν δουλευουν προς το παρον? τα ci
δεν δουλευει το diseq 1.2
τους υποτιτλους στα HD καναλια τους βγαζει σε πρασινο χρωμα
σε γενικες γραμμες ειναι ενα πολυ καλο μηχανημα που αξιζει τα λεφτα του μεχρι και την τελευταια δεκαρα που αν εχει και την αναλογη υποστηριξη απο διαφορες ομαδες τοτε θα ειναι το ΜΗΧΑΝΗΜΑ
Αλλα ας μην ξεχναμε οτι ειναι ενα beta
john 78
Banned
29 December 2008
1,684
Φανταζομαι φιλε οτι τον εχεις.Το μοτερ δηλαδη δεν το κινει καθολου?Δεν δουλευει δηλαδη το DiseqC 1.2,αλλα το usals?To cardreader του?Δοκιμασες καποια καρτα?Με το CI τι προβλημα υπαρχει ?
Ενδιαφερει να μαθουμε.Οποιαδηποτε πληροφορια δεκτη.
giannis1010
8 November 2007
498
Για αρχή καλό είναι...αλλά είναι κάποια πράγματα που με προβληματίζουν.....πρώτα από όλα η υποστήριξη....οι γνωστές ομάδες για την ώρα δεν ασχολούνται...επίσης από emu μόνο mbox για την ώρα....ένα emu το οποίο επίσης είναι υπό beta μορφή και κατά την γνώμη μου θέλει πολλά ψωμιά ακόμα να γίνει όντος ανταγωνιστικό και εξίσου καλό με τα άλλα...(cccam/mgcmad/gΚουτι)
Τέλος αν αληθεύει ότι δεν χρησιμοποιούν το linux API το κλασικό του DM και ότι η εταιρεία δεν θα δώσει Public πολλά κομμάτια απο drivers και kώδικα....τα βλέπω σκούρα τα πράγματα...σ'ίγουρα είνια μια αρχή για να υπάρξει ανταγωνισμός...αλλα αν όντος θα υπάρχξει θα το δούμε στο μέλλον
nakata
11 June 2007
2,309
var/etc/home
oi πορτογαλλοι υποσχεθηκαν οτι θα δωσουν public το API τωρα αν εχουν πληρωσει για το API που χρησημοποιει η dream multimedia η καποιο ποιο φτηνο δεν ξερω
btw
το 1010 μεταφραζεται σε ten-ten και οι καταρακτες στο αβαταρ σε σκετα βραχια?:BDGBGDB55::BDGBGDB55:
nakata
11 June 2007
2,309
var/etc/home
Re: Απάντηση: AZBOX PREMIUM HD
Συγνωμη αλλα μολις τωρα ειδα το ποστ σου τα γεραματα βλεπεις
λοιπον ουτε το usals δουλευει οπως πρεπει ια την ακριβεια δουλευει αλλα στελνει το πιατο οπου αυτο θελει οσο για το τι καρτες βλεπει ο δεκτης απο οτι ξερω απο πληροφοριες φιλων Conax και Nagra3 καρτες δουλευουν με το MultiCAS 1.55a.Απο κει και περα καποιος Κροατης λεει οτι εχει καταφερει να τρεξει το newcs εμεις δεν το εχουμε καταφερει ακομα αλλα εμεις ειμαστε αυτο που λενε μεσοι χρηστες και οχι καποιοι με πολλες γνωσεις
nakata
11 June 2007
2,309
var/etc/home
οσο για το CI δεν βλεπει καθολου τα moduls αλλα απο οτι λενε στο νεο firmware θα τα βλεπει υπομονη απο χτες στειλανε τα πρωτα 1000? κομματια στην κεντρικη και βορεια Ευρωπη και αυτο ειναι καλο γιατι οσοι περισοτεροι εχουν τον δεκτη τοσο ευκολοτερο ειναι να εντοπιστουν τα οποια προβληματα και να διορθωθουν(?) ειδωμεν
