Color Correction & color Grading in video
  • Αγαπητοί φίλοι και φίλες.
Dark74
25 August 2010
476
What-is-Color-Correction-Color-Grading-Color-Correcting-Guide-Header-StudioBinder.jpg
The Difference Between Color Correction & Color Grading
In the post-production process, color is done through color correction or color grading, but color correction and color grading are, in fact, different.
Color Correction
Color correction refers to the process where each clip of footage is altered to match a consistent standard of appearance. Basically, correcting problems of the underlying image by balancing out the colors, making the whites appear white, the blacks appear black, and making sure that everything is even. The goal is to match the video footage to a standard that would be an accurate portrayal of how the human eye would view it.
An example of this is when you’re shooting outside over the course of the day. During the day, the quality of the sun is going to change, and certain shots of your video will not match up. That’s why color correction is important, as it will make your video look like it was all shot at the same time.
Color correction is really just the first pass in a color workflow. It is the first thing a colorist needs to look at before moving forward to color grading.
Color correcting changes an image to portray how the human eye would see it.
Color Grading:
Color grading is taking what you have done in color correction a step further. Color grading enhances your story by manipulating colors to create a new tone or mood or to achieve a certain look to tell the story. According to Studiobinder.com, “Color can affect us emotionally, psychologically and even physically, often without us becoming aware.” Color grading can make a drastic change to footage
Ξεκινάω αυτό το thread καθώς θεωρώ ότι είναι από τα ουσιώδη ζητήματα και στη φωτογραφία και στο video. Εδώ όμως είμαστε στο video (αν και η λογική έιναι ακριβώς η ίδια). Πριν ξεκινήσω τις ερωτήσεις μου, και για όσους διαβάζουν και ενδεχομένως έχουν παρόμοιες απορίες, κάνω μια μικρή εισαγωγή με το τι έχω καταλάβει μέχρι στιγμής.
Color correction : Η πρώτη βασική χρωματική διόρθωση ώστε όλα τα clip σε ένα βίντεο να "μοιάζουν" χρωματικά μεταξύ τους, ειδικά αν έχουν τραβηχθεί από διαφορετικές κάμερες. Δευτερευόντως, μια πρώτη διόρθωση σε white balance (αν απαιτείται) ή στις εντάσεις (contrast κλπ) ή στο χρώμα προκειμένου να προσομοιάσουν πιο πολύ στην εικόνα της "πραγματικής" λήψης.
Color Grading : Το δεύτερο βήμα μετά το color correction, όπου αφορά στην επεξεργασία όλων των παραπάνω με στόχο να δημιουργήσει την "ατμόσφαιρα" που θέλουμε (ψυχρή, φουτουριστική, θερμή κλπ), δηλ. να το πω μεταφορικά το "συναίσθημα" που απορρέει απο την εικόνα. π.χ. ένα κλιπ ταινίας τρόμου, είναι πιο ψυχρό, με μειωμένο saturation και ελαφρώς μπλε αποχρώσεων. Αντιθέτως μια αισθηματική ταινία, πιο ουδέτερη, πιο θερμή, πιο "πορτοκαλί" χρώμα κλπ. Γενικά τώρα.
Επειδή όλα αυτά είναι υποκειμενικά και σχετικά, θα ήθελα να επικεντρωθώ στο ΤΕΧΝΙΚΟ μέρος, τις βασικές αρχές δηλαδή και πιο συγκεκριμένα να ρωτήσω τα εξής :
Δύο εργαλεία που βλέπω ότι χρησιμοποιούνται για τη ΒΑΣΙΚΗ διόρθωση είναι τα :
a) RGB Parade
b) Waveform (luma)
Τι πρέπει να προσέξει κανείς χρησιμοποιώντας τα δύο αυτά εργαλεία ? ποιές είναι οι βασικές γενικές αρχές ? π.χ. ποιά θα πρέπει να είναι τα όρια (π.χ. 100 και 0) που δεν πρέπει να ξεπεράσει ή τα όρια μέσα στα οποία πρέπει να κινείται ? ή οτιδήποτε άλλο πιστεύεται πως έχει αξία ?
ευχαριστώ​
Constantinos Milonas
20 August 2006
1,783
Προσπάθησε να βρεις αυτό το Tutorial "INFINITE SKILLS COLOR CORRECTION WITH SPEEDGRADE AND PREMIERE PRO" απλά λέει και εξηγεί τα πάντα.
Αναβιώνω το θέμα για κάποιες ερωτήσεις.
Δοκίμασα να κάνω color correction (και όχι τόσο grading) σε κάποια βιντεάκια από drone, χρησιμοποιώντας Premiere Pro CC 2017 και τα Lumetri Scopes. Το θέμα είναι πως, ενώ το original footage είναι άψογο, στο επεξεργασμένο παρατηρώ artifacts. Δεν είμαι σίγουρος αν αυτά προκαλούνται από την επεξγασία ή από το τελικό encoding. Είναι πάντα το ίδιο πράγμα που συμβαίνει, η εικόνα από crispy μετατρέπεται σε μια θολούρα, και μετά ξανά crispy και πάει λέγοντας. Μπορείτε να το δείτε να συμβαίνει στο παρακάτω βιντεάκι στο 0:05, στο 0:09, στο 0:12 πάνω στο γρασίδι. Αυτό συμβαίνει σε σχεδόν όλα μου τα βίντεο όταν τα επεξεργαστώ.
https://www.youtube.com/watch?v=96IjxXx98iA
Οι ρυθμίσεις που έχω επιλέξει για το τελικό output φαίνονται παρακάτω, ενώ σας δείχνω και πως φαίνονται τα scopes τη συγκεκριμένη στιγμή που συμβαίνει το artifact. Το πρώτο scope που υποτίθεται κοιτάς για να μην έχεις artifacts φαίνεται ότι βρίσκεται σαφώς εντός των ορίων. Το δεύτερο είναι πιο φλου.
22 June 2006
34,697
NEO HRAKLEIO
Ok... δοκιμασε VBR 2 passes, με υψηλοτερο bitrate και δες το αποτελεσμα στον υπολογιστη σου και πες μας.
Ασε το youtube γιατι μπορει να κανει τα δικα του.
τι bitrate εχει το αρχικο σου υλικο ?
Θαενκς! Το κάνει και στο αρχικό (exported) αρχείο, δεν είναι πρόβλημα του YouTube. Το αρχικό υλικό αν δεν κάνω λάθος είναι 100Mbps (4Κ/60p).
Κάνω τώρα μια δοκιμή να δω με VBR2 στα 49.2Mbps (διπλάσιο δηλαδή από πριν).
22 June 2006
34,697
NEO HRAKLEIO
Μη πεφτεις κατω απο το αρχικο bitrate.... Και παντα 2 pass vbr
Επισης το target bitrate αν ειναι πχ 100 mbps το maximum θα το βάζεις 30% παραπανω.
Sent from my SM-T560 using Tapatalk
Reactions: Photis
Όντως, αυτό έφταιγε! Ακόμα και με τα 49Mbps η διαφορά είναι παραπάνω από αισθητή, φαντάζομαι ότι στα 100 θα εξαλειφθεί τελείως.
Μια ακόμα ερώτηση... αν παρατηρήσεις στο βίντεο, επειδή στο πανεπιστήμιο παίζει πολύ ψιλό τουβλάκι στους τοίχους, έχω πολύ συχνά έντονο moire. Αυτό πως μπορω να το αντιμετωπίσω (πέρα απ'το να κατεβάσω το sharpness στην κάμερα κατά τη λήψη);;
Ευχαριστώ για το ξεστράβωμα!!! :grinning-smiley-043
22 June 2006
34,697
NEO HRAKLEIO
Re: Color Correction & color Grading in video
Δυστυχως αυτο δεν φευγει... τελειως.
Μειωσε οσο παει το sharpness στη καμερα και αν δε μειωθει, δοκιμασε να βαλεις ενα φιλτρο motion blur . 5 pixel blur στο καθετο αξονα στο Premiere .
Αυτο ειναι χακατηριστικο της καμερας....
Επισης δοκιμσαε καποιο πολωτικο φιλτρο ή nd filter στη καμερα και παντα το sharpness τελειως off.
Θαενκς, έχω ήδη παραγγείλει κάτι ND/PL φιλτράκια, θα δω αν κάνουν διαφορά.
Btw... ξανακάνω render το βίντεο όπως πρότεινες, και βλέπω ότι το αρχείο βγαίνει κτηνώδες (1.6GB για 2μιση λεπτά). Αυτό άραγε θα μπορεί να παιχτεί από τις συνήθεις πηγές (Android TV κλπ); Ή θα πρέπει πάλι να το μικρύνω; Και αν χρειαστεί να το μικρύνω, πως θα έχω τις ελάχιστες απώλειες σε ποιότητα;
Λοιπόν, μετά τις συμβουλές σου πράγματι το φαινόμενο εξαλείφθηκε! Το video φαίνεται απείρως καλύτερο, ενώ περιέργως το αρχείο των 1.7GB έπαιζε αέρα στο MBP (στο PC βέβαια που είναι 2 χρόνια νεώτερο ούτε γι'αστείο :D )
https://www.youtube.com/watch?v=Mebn9-5b6ys
Το moire έφτιαξε αρκετά με post sharpness reduction, παραμένει όμως σε πολλά σημεία. Την επόμενη φορά που θα βρεθώ εκεί θα κατεβάσω το sharpness στο -3 στο Phantom, δυστυχώς προχθές που έκανα τη λήψη το είχα απλά στο -1, που γενικά δουλεύει καλά.
22 June 2006
34,697
NEO HRAKLEIO
το καλυτερο προγραμμα για grading εγινε και πιο γρηγορο!
\Το Davinci resolve εφτασε στην 14η εκδοση, κι επιτελους καταφερε να βελτιωσει πολυ την αποδοση σε αρχεια h.264 που μεχρι τωρα ηταν σχεδον αδυνατον να μονταρεις χωρις μετατροπη.
Δοκιμαστε το , υπαρχει και δωρεαν εκδοση...
https://www.blackmagicdesign.com/support/family/davinci-resolve-and-fusion
https://www.blackmagicdesign.com/products/davinciresolve#play-video-whats-new
Kosh
7 September 2006
90,496
Εκεί ψηλά.....
Το καταπλητικοτερο πλεον ειναι οτι η τιμη του επεσε απο τα 1000$ στα 300$.
Η blackmagic συνεχιζει να μας εκπλησει ευχαριστα.
