Με διάθεση που ξεκινάει από το τέλος Απριλίου,για την Αμερικάνικη αγορά, η Denon ανακοίνωσε την νέα σειρά ενισχυτών της για το 2011.
AVR-1312
AVR-1612
AVR-1712
AVR-2112CI
Dolby TrueHD and DD+
• dts-HD Master Audio and dts-HR decoding
• Dolby PLIIz Matrix decoding, Front Height effects
• dts decoding, including dts 96/24 5.1 for DVD-Video, dts ES Discrete 6.1, ES Matrix 6.1, and Neo:6 Cinema & Music modes 7 channels equal power amplifier section, fully discrete construction
• 90 watts per channel (8 ohms, 20 – 20kHz, <0.08% THD)
• 2 Source/Zone Audio
• HDMI 1.4a Repeaters with 3D, Audio Return Channel (6/1)
• Works with iPhone Certified
• Rear panel RS-232C and Ethernet ports for Third Party control communication
• Remote Access via the Internet
• AirPlay enabled
• Internet Radio, Rhapsody, Napster and Pandora
• DLNA 1.5 Certified
• 7.1 24/96 Uncompressed Audio Compatible
• Analog Video to HDMI Conversion (480p), with overlay (HD)
• Dedicated iPod™ compatible port (for use with optional ASD-11R Dock, with GUI and remote control)
• Audyssey MultEQ XT, calibration microphone included
• Audyssey Dynamic EQ and Dynamic Volume
• Power Amplifier Assign
• Fixed Zone 2 preout
AVR-2312CI
• Dolby TrueHD and DD+
• Features latest 32-bit Floating Analog Devices SHARC Processors
• 7 channels equal power amplifier section, fully discrete construction
• 105 watts per channel (8 ohms, 20 – 20kHz, <0.08% THD)
• HDMI 1.4a Repeaters with 3D, Audio Return Channel (7/1)
• Front Panel USB input, iPod Direct
• Ethernet port with built-in Multi-Media Command and Control functionality
• Web Browser Control
• Firmware update/upgrade
• AirPlay enabled
• Dedicated iPod™ Control port (for use with optional ASD-11R Dock, with GUI and remote control)
• Party Mode Plus
• Audyssey Pro Installer Ready
• Analog/HDMI Video to HDMI Scaling (1080p) featuring Analog Devices full 12-bit Processing Engine, with New GUI and overlay (HD and 3D)
• AM/FM tuner with auto preset FM memory (56 stations)
• Multi-zone CI modes
• Variable Zone 2 preout
• New Style Pre-programmed Remote Control
• Denon Control App available from the App Store
AVR-3312CI
http://news.cnet.com/8301-17938_105-20053559-1.html?tag=mncol;title
http://store.audioholics.com/product/3834/66566/denon-avr-2112ci-surround-receiver
http://store.audioholics.com/product/3833/66566/denon-avr-2312ci-surround-receiver
http://www.audioholics.com/reviews/receivers/denon-avr-3312ci-fl
http://usa.denon.com/us/product/pag...roductId=1bc1c58f-4aef-47b8-b401-02eb4ef6182f
http://usa.denon.com/US/Product/Pag...roductId=f68ac75c-565a-4fe9-83db-868c09d1c2dd
http://usa.denon.com/US/Product/Pag...roductId=333b93c6-1dd0-4176-a06c-d2224674832a
AVR-1312
- 5.1 AV receiver, 110 watts per channel
- Four HDMI inputs
- 3D video pass-through, standby pass-through, and audio return channel
- Graphical user interface, overlaid on HDMI sources
- Two digital audio inputs (one optical, one coaxial)
- $250 list price; available later in April
AVR-1612
- 5.1 AV receiver, 120 watts per channel
- iPhone/iPod-compatible USB port
- Audyssey MultEQ and automatic speaker calibration
- Dolby Pro Logic IIz
- $350 list price; available later in April
AVR-1712
- 7.1 AV receiver, 125 watts per channel
- Six HDMI inputs
- Onscreen step-by-step setup wizard
- $400 list price; available in June
- 7.1 AV receiver, 90 watts per channel
- Built-in AirPlay support
- Can be controlled via Denon Remote App on iPhone/iPod Touch
- Ethernet port
- Internet radio, plus streaming media from Pandora, Napster, Rhapsody, and Flickr
- DLNA-compatible for network audio streaming, including FLAC HD files
- $530 list price; available later in April
AVR-2112CI
• AirPlay enabled
AVR-2312CI
• AirPlay enabled
• Party Mode Plus
AVR-3312CI
- HDMI 1.4a 7In/2Out 3D Ready
- AirPlay Ready
- Discrete Power Amps rated at 125 watts each x 7 channels
- Audyssey DSX
- HD Radio
- 3D pass thru
- 3 source / 3 zone output
- Dimensions: 17-1/8” x 6 37/64” x 15-3/64”
- Weight: 26lbs
