DVDO i scan VP 50
Larry
Μέλος Δ.Σ.
20,868
η DVDO ανανεωσε την γκαμα της τον αξιολογων scaler της με τον i scan VP 50
με 12 εισοδους !!!!!!! για να βαλεις πανω τα παντα και με τιμη γυρω στα 2000 ευρω (αυτο Τασο θα το περασουμε σαν εκουαλαιζερ !!!!)
Τhe DVDO® iScan™ VP50 is a high-definition video processor and A/V hub that converts standard definition, high definition and PC signals from your DVD player, HD-DVD player, Blu-ray Disc player, HD DVR, game console or PC to any output resolution between VGA and 1080p, including popular HDTV resolutions such as 720p and 1080i.
The VP50 serves as your complete A/V hub, providing audio/video switching that simultaneously eliminates A/V lipsync and allows a one wire connection to display for all of your video needs.
VRS Video Reference Series Technology by ABT VRS Precision Deinterlacing™ technology by ABT - 480i/576i/1080i Motion, Edge & Source-Adaptive Deinterlacer
* Five-field motion adaptive deinterlacing
* Edge adaptive processing for smooth diagonal edges
* Three frame video processing delay (Max)
* Game Modes with very low latency
o Sub-1 frame delay with edge adaptive processing
o 2 frame delay with edge and motion adaptive processing
VRS Precision Video Scaling II™ technology by ABT - 10-bit Scaling with Enhanced Sharpness Control
ABT's Precision Gamma Correction™ - individual R/G/B Adjustments (0.5-2.5)
ABT's Precision AV LipSync™ - intelligent digital audio delay technology to match Audio & Video timing
ABT's RightRate™ - High-Performance Framerate Conversion
ABT's AutoVFR™ - Intelligent Component Video Inputs with Automatic Video Format Routing
ABT's AutoCUE-C™ - Automatic Chroma Upsampling Error detection & correction
Analog HD Transcoding and Processing
4 HDMI inputs which process up to 1080p-50/60 input signals
Flexible Input and Output Aspect Ratio Controls
Display Profiles – For multiple display, framerate, and image shift configurations (10)
10-bit, 300 MHz Instrumentation Quality DACs (2x Oversampling for 1080p)
Full-frame Timebase Correction
High performance, multi-standard video decoder (10-bit: 480i/576i; 12-bit: 480p/576p/720p/1080i)
High-quality super-adaptive comb filter with 2D Y/C separation
Flexible Digital and Analog Audio switching and routing – 4 HDMI audio/video inputs, 5 assignable audio inputs (4 digital, 1 analog) with 1 HDMI audio/video output and 2 active digital audio outputs.
Software Upgradeable
Inputs
Twelve Video Inputs Available
* 2 Composite (NTSC/PAL/SECAM)
* 2 S-Video (NTSC/PAL/SECAM)
* 2 Component (YPbPr or RGB/S) processes 480i/p-60, 576i/p-50, 720p-50/60, 1080i-50/60
* 1 RGBHV/Component (BNC-style connectors) processes 480p-60, 576p-50, 720p-50/60, 1080i-50/60, VGA-SXGA@60Hz
* 4 HDMI (RGB or YCbCr) processes 480i/p-60, 576i/p-50, 720p-50/60, 1080i-50/60, 1080p-50/60, VGA-SXGA@60Hz
* 1 SD-SDI (Serial Digital Interface) Optional processes 480i-60, 576i-50
Nine Audio Inputs
* 4 HDMI
* 2 Assignable Coaxial Digital
* 2 Assignable Optical Digital
* 1 Assignable Analog Pair (L/R)
Outputs
One Analog Video Output
* Using High Quality BNC-style connectors
* Configurable for YPbPr, RGBHV, RGB/S, or RGB
One Digital Audio/Video Output
* Using HDMI (High Definition Multimedia Interface) connector
* Configurable for YPbPr or RGB
* Also carries digital audio
Two Digital Audio Outputs
* One Coaxial Digital
* One Optical Digital
Controls
Input Aspect Ratio Controls
* Presets: 4:3 full frame, 4:3 letterbox, Panorama, 16:9 full frame or user defined aspect ratio (10)
* Flexible Horizontal and Vertical Zooming (up to 2x) & Panning Controls
* Overscan Adjustment per input
* Presets: 4:#, 16:9, 2.35:1, or custom aspect ratio
* Separate Display/Screen Adjustments
* Underscan Adjustment to address Overscan inherent in a display
Picture Controls
* Fully programmable controls with non-volatile memories per input and input resolution
* Brightness, Contrast, Saturation, Hue, Sharpness, and Fine Y/C Delay
Operation
* Intuitive On Screen Display and easy to read 2 line, 20 character Front Panel Display
* Front Panel Controls, including IR Remote Control (discrete codes available), Automation via RS232 port
Output Controls
* Output Resolution, Sync Type, Colorspace (RGB or YPbPr/YCbCr), Frame Lock, Gamma (R/G/B and up to 1024 point Gamma individual RGB correction), Display Profiles (10)
35 Built-in test patterns and VRS Optimization & Evaluation DVD included for optimal setup
Software Upgradeable via Serial Port (USB-to-Serial Adapter included)
23,692
Τωρα θ ατην πω την κακία μου αλλά δεν μπορώ: μα χάθηκε ο κόσμος να βάλουν μια δεύτερη ψηφιακή έξοδο; Τόσο πολύ κοστίζει πιά;
Δεν μ' ενδιαφέρει για την δική μου χρήση, αλλά αν θα είχα στον χώρο μου και τηλεόραση, θα άλλαζαν τα πράγματα.
Πότε είπαμε είναι διαθέσιμο Larry;
Larry
Μέλος Δ.Σ.
20,868
Τασο μην βαρας,
με την τρεχουσα ισοτιμια του δολαριου γυρω στο 1,28-1,29 οντως η τιμη παει στα 2200 -2300 ευρω + βεβαιως τα μεταφορικα
οι τιμες ειναι αυτες που αναφερει το www.dvdo.com
η αναφορα μου σε τιμες δεν ειχε να κανει μονο με πιθανη αγορα και αν συμφερει ή οχι αλλα γιατι αποφασισε να βγαλει αυτο το μοντελο τσιμπημενο κατα 1000 δολαρια σε σχεση με το vp 30 και ουσιαστικα με bonus την sdi
23,692
1.28 έχει τώρα. Ούτε θες να ξέρεις τι spread βάζουν οι κάρτες για την μετατροπή. Αλλά το θέμα μας δεν είναι 100 πάνω 100 κάτω.
Το θεμα είναι αν προσφέρει κάτι ουσιαστικά παραπάνω από το VP30.
κατά την εταιρεία έχουν συμβεί οι παρακάτω αλλαγές:
http://www.dvdo.com/pro/pro_cf.php
Κατ' εμέ έχουν βάλει standard την έξτρα κάρτα για deinterlacing που αν ήθελες έβαζες στο VP30
Η SDI ΕΞΑΚΟΛΟΥΘΕΙ να είναι optional.
The iScan VP50 also adds:
  • <LI class=inferior>World Class 1080i Deinterlacing - Motion, Edge and Source-Adaptive Processing <LI class=inferior>Complete processing of 1080p for PC, HD-DVD and Blu-ray Disc formats as well as upcoming PS3 <LI class=inferior>Ability to update all processing algoriths through software updates
  • Progressive Source Input Cadence Detection (Source-Locked Output without Deinterlacing)
PanMan
9,242
Νεο Ψυχικο
Ειναι τα ιδια μονο που το 50 εχει την ντιτερλεισινγκ καρτα φορεμενη. Αν το κανω απγκρειτ θα μου δωσουν μεταλλικο 5 να κολλησω μπροστα?
16 June 2006
7,335
127.0.0.1
(Serial Digital Interface) A physical interface widely used for transmitting digital video in various formats. For electrical transmission, it uses a high grade of coaxial cable and a single BNC connector with Teflon insulation. It also uses optical fibers with ST, SC and FC connectors. Following are the common digital formats transmitted over SDI.
Standard Definition Aspect Transfer
SD-SDI Ratio Rate
Digitized NTSC (4FSC) 4:3 143 Mbps
Digitized PAL (4FSC) 4:3 177 Mbps
Component ITU-R BT.601 4:3 270 Mbps
Component ITU-R BT.601 16:9 360 Mbps
High Definition
HD-SDI
Component ITU-R BT.709 16:9 1,485 Mbps
23,692
Ε ναι φυσικά SD= standard definition.
Συγνώμη , εδώ δεν εχουν βγει καλά καλά τα players και μου θέλετε και sdi στα 1080i ή p ; (αν και νομίζω ότι δεν θα έχει και τόσο νόημα τότε η sdi αφού η εγγενής ανάλυση του δίσκου θα είναι έτσι κι αλλιώς στα 1080)
Babis K.
28,610
ΟΙΚΟΝΟΜΟΥ ΤΑΣΟΣ said:
Τι ακριβώς δεν κατάλαβες ρε μπαγάσα, γιατί θα με τρελάνεις....-bye-
SD-SDI = support SDTV only
HD-SDI = support SDTV/EDTV/HDTV
....αν και νομίζω ότι δεν θα έχει και τόσο νόημα τότε η sdi αφού η εγγενής ανάλυση του δίσκου θα είναι έτσι κι αλλιώς στα 1080)
Και τώρα που η εγγενής ανάλυση του δίσκου είναι 576i τι χρειάζεται η SD-SDI;
NassosT
4,692
Re: Απάντηση: DVDO i scan VP 50
Μόνο που δεν πρόκειται για την ABT102 που δεχόταν μόνο 480i/576i αλλά για νέα κάρτα που επεξεργάζεται και 1080i σήμα.
Όσο για το θέμα SD ή HD SDΙ ορίστε κάτι σχετικό δια στόματος Josh Allen, DVDO Product Manager από το avsforum: We intend on designing an HD-SDI input module for the VP50. Until, the board is built and tested, we will not announce this as a product.
Βέβαια, συμφωνώ κι εγώ ότι χρήσιμη θα ήταν και μία επιπλέον ψηφιακή είσοδος, αλλά αν το μηχάνημα κάνει στα 1080 αυτά που κάνει το VP30/ABT102 στα 576 τότε με βλέπω για αλλαγή όσο είναι ακόμα φρέσκο το VP30 μου.
Απάντηση: Re: Απάντηση: DVDO i scan VP 50
Αντε να το διαπιστωσεις.:flipout: ...δυσκολο..Λεω να βαλουμε τον τασουλη να το κανει αυτο....:damnyou:
