Απάντηση: Εγγραφη Audio σε Mac (απο minidisk-lp)
Kαλημερα σε ολους!
Τελικα βρηκα πως γινεται.
Για οποαδηποτε εγγραφη αναλογικη (ειτε απο lp ειτε απο md) μπορουμε να χρησιμοποιησουμε το cd spinner doctor της roxio που ειναι στο πακετο του toast titanium 7-8 και την αναλογικη εισοδο της καρτας μας.
Αναλυτικα:
CD Spin Doctor®
* Convert your music for iMovie and iPhoto projects
* Record live events using your built-in microphone
* Record your own podcast and encode with iTunes!
CD Spin Doctor® helps you to digitize analog audio from your vinyl LPs or tapes. You can define tracks, reduce noise and enhance sound quality with included filters, and add the audio to your iTunes library with ease. This application is perfect for rediscovering your classic collection of LPs and cassettes, recording live performances, sermons or lectures, and creating your own podcasts!
Record
Guided recording sheet ensures error-free recording sessions
Desktop recording widget for instant audio capture (requires Mac OS 10.4 or higher)
Supports all internal audio devices included with Macintosh computers
Supports USB and Firewire external audio devices such as Griffin iMic and iSight camera Provides full quality levels of the audio input device - up to 192 khz/24 bit, stereo
Includes 4 recording quality presets - Voice, CD, DVD and DVD High Quality
Playthrough option allows you to preview the audio being recorded
Input volume slider helps you set ideal capture levels
Timer automatically stops recording for unattended audio capture
Uses Mac OS X pro quality CoreAudio technologies for recording
Edit
Overview waveform displays the entire recording
Zoom region shows precise audio detail
One-click automatic track definition - with adjustment preferences for music with natural pauses
Manually define tracks by click & drag, or in real-time during playback with a single mouse click
Color coded track markers are superimposed directly on the waveform
Track markers are saved inside the audio file, so you can make additional edits or changes later
Unlimited undo capabilities to remove defined tracks
Restore
Includes audio filters to reduce noise, such as clicks, crackles and hiss
Includes audio filters and 10-band equalizer to enhance sound quality
Filters can be previewed in real-time prior to applying to the audio
Automatically creates a copy of the unfiltered audio for preservation of the original recording
Enjoy
Familiar iTunes style interface with track list and playback controls
Playback supports skipping between tracks and scrubbing the playhead through tracks
Listen to the entire recording or individual groups of tracks
Save the entire recording or individual tracks as standard full-quality AIFF files
One-click iTunes integration automatically adds tracks to your music library and your iPod
One-click Toast integration to create audio CDs or audio DVDs (Toast 7 sold separately)
