Εντυπωσιακες υλοποιησεις ΗΤ σε 2.35.1 !
takisot
Μέλος Δ.Σ.
27,814
Παλλήνη
Το παρον thread ειναι αφιερωμενο σε εκεινους που εκνευριζονται οταν ποσταρουμε φωτος και σχολια απο μεγαλυτερα fora του εξωτερικου -bye- οπου εκει υπαρχουν ανθρωποι με απειρο χρημα και διαθεση να κανουν την υπερβαση...
Μιας που τετοιες υλοποιησεις δυσκολα θα συναντησουμε στην πατριδα μας, "παρτε ματι" τι μπορει να γινει με 16Χ9 προβολεα, αναμορφικο φακο και 2:35:1 πανι....
(Πηγη: Avsforum:grinning-smiley-043 )
Some details: The Screen is a 12' wide 2.35:1 DIY Curved SmX Audio Transparent Screen.
It is currently the highest gain weaved transparent screen vailable
at a 1.16 gain.
The Projector is an Optoma H-79 with an ISCO II Anamorphic Lens.
For Scaling, a Lumagen Vision HDQ is used and Theatertek.
Speakers: 7.1 Klipsch THX Ultra 2 surround sound system and 2 Danley
DTS-20 Subs.
Processing: Outlaw 990 processor
Amps: 4 Crown XTi 1000's for Mains and surrounds and 1 Crown XTi 4000
for Subs.
On to the pictures.
takisot
Μέλος Δ.Σ.
27,814
Παλλήνη
96" X 48" Parkland Plastics DIY Portable Screen with four-position masking (41” high at 2.35:1)
InFocus X1 PJ with 35mm Hypergonar H. Chretien HI-FI-2 lens
Zenith DVB318 set at 1080i over component with vertical zoom
Seating at 10ft.
takisot
Μέλος Δ.Σ.
27,814
Παλλήνη
Ενα...εξωτερικου χωρου:
Who says you cannot construct a collapsible/portable 235:1 scope screen for an outdoor movie partie. Im so glad to see true scope ratio was the choosen format, way to go
The screen is about 16 feet wide..Wow.
Some day 10 to 15 footer will become the norm for indoor use, I wish
Thanks for sharing these Steve.
takisot
Μέλος Δ.Σ.
27,814
Παλλήνη
...και ενα με DIY φακο:
Another fine 235:1 theater from Mark Techer.
A nice DIY lens project. What out Shawn.
Mark thanks for sending the pictures.
A few words and pics from Mark:
A quick diagram of the lens that I have built. The prisms were made by a local plastics engineer out of 6mm perspex using a jig that I made for him. He used a strip heater to bend the perspex so that sides of the prism would remain flat. because they are liquid filled, I got him to add an expansion chamber to each which acts as an adjustment knob.
A close up of the prism based anamorphic lens. I had to built the lens big to work with my short throw, recessed lens projector
Heres a few more shots.
Heres the theater before.
After.
A few screen shots.
takisot
Μέλος Δ.Σ.
27,814
Παλλήνη
Carada 128" Diag (118" W) Brilliant White screen.
Prismasonic H600M lens.
Sanyo Z4 projector.
1st row of seating is at 13 ft., 2nd row at 19 ft.
Berkline 090 seating with ButtKicker in the captain's seat, and in the riser.
takisot
Μέλος Δ.Σ.
27,814
Παλλήνη
Ενα απο τα αγαπημενα μου:
The system highlights a C3X Lite, Motorized H1200R, MX3000 and the Stewart Ultramatte 127” X 54”. Lots of punch. Looks like your looking out a window. Thanks for sharing Ray.
takisot
Μέλος Δ.Σ.
27,814
Παλλήνη
Και ενα ακομα "τερατακι":
This theater has it all. JBL cinema speakers, DPI 3 chip DLP, and the screen is a 16 foot wide Harkness Hall mini perforated. Wow 16 feet wide !!
If thats not enough he also has a few D-Box 3 Axis recliners.
I definitely would give up a pool for the theater.
Thanks for sharing.
Heres where it all started.
Progress.
Dream come true.
Browser
10,575
Τακη , απ'οτι ειδες και λεγαμε και τις προαλλες, οι περισσοτεροι των αναμορφικων ειναι orizontal expand κατι που ακομα εχω απορια γιατι.
Ειχα βρει ενα αρθρο που εξηγουσε καποιους λογους, αλλα δεν το βρισκω τωρα. Θα ψαξω παλι μπας και βγαλουμε ακρη,.....
@Κωστα Κ.
.....καλα τα λες , αλλα τι γινεται με το focus??
Browser
10,575
Για βρειτε μου τι δεν κολαει με τιποτα μεσα στο χωρο που εφτιαξε ο τυπος.............?????
