H Sony ανακοίνωσε την Nex-5R
emperorgr
10 June 2010
1,448
Μόλις βγήκε η πρώτη ανακοίνωση για τον αντικαταστάτη της Nex-5N, η 5R με αρκετά βελτιωμένα χαρακτηριστικά και ενδεχομένως απόδοση. Ενα πρωτο preview εδω, και καποιες τιμες για pre-order $648 μονο σωμα, $748 για σωμα+18-55mm φακο κιτ.
Ο reviewer αναφέρει "The autofocus is excellent (I was told the production version may be even faster), and near bridges the speed gap of DSLR territory. I didn't get a chance to do much subject tracking but the moving objects I did try the camera seemed to keep up very quickly (moving my feet back and forth while focused on a stationary object, for example). I used one of the first three lenses that are supported by the FAST AF feature of the 5R, the 24mm Zeiss f/1.8. Only that lens and the 18-55/55-210mm lenses are supported initially but this will indeed change as new firmware upgrades come to allow other lenses to be used."
Η καμερα πλεον θα υποστηριζει και "apps" και οι πρωτες πληροφοριες μιλανε για
  • Direct Upload
  • Picture Effect+
  • Bracket Pro
  • Multi Frame NR
  • Photo Retouch
  • Smart Remote Control (έλεγχος remote μέσω wifi για Android συσκευες)
  • Time-Lapse και Cinematic Photo στο εγγύς μέλλον
Features:
  • DSLR-quality in about half the size and weight
  • 16 MP APS-C sensor with fast up to 10 fps shooting speed
  • Fast Hybrid AF includes phase-detection for DSLR-like focus
  • Full HD movie shooting at 60p/24p with full exposure control
  • Wi-Fi sharing and downloadable camera apps
  • 180° tilt-able touch-screen LCD for easy self-portraits
  • Easy intuitive interface with improved control dial
  • Unlimited creativity with 11 built-in Picture Effects
  • Up to ISO 25600 provides versatile low-light performance
  • Wide selection of interchangeable lenses to expand your creativity
With the Sony Nex-5R (body only) - Black shoot and share DSLR-quality photos online, straight from the camera. With built-in Wi-Fi®, the NEX-5R even lets you download camera apps for endless creative possibilities, and the 16.1MP APS-C size sensor delivers breathtaking stills with pro-grade defocused backgrounds. All this and more in a camera that’s about half the size of a DSLR.
With the NEX-5R, the camera delivers superlative image quality thanks to an APS-C image sensor, and is equipped with improved Fast Hybrid AF – a hallmark of conventional DSLR cameras. With functionality guaranteed to appeal to photographers, the NEX-5R raises the bar for mirror-less cameras. Moreover, the newly designed body gives the camera a distinctly DSLR-like feel, making it a tempting alternative for people considering a DSLR camera.
16.1 MP APS-C size HD image sensor: The same sensor format that Sony builds into the full-sized DSLRs. With 13 times the area of the typical point-and-shoot image sensor, APS-C sensor size makes the difference between “snapshots” and “photographs,” delivering an exceptional combination of high resolution, high sensitivity and gorgeous, blurred backgrounds.
Fast Hybrid AF: Sony’s advanced Fast Hybrid AF combines two technologies for outstanding performance: Phase detection auto focus for quick response that is ideal when tracking fast-moving subjects and contrast-detection auto focus for added precision. A perfect match that delivers optimal Auto Focus for fast, precise focusing in any scene.
Full HD Movies1 at 60p/60i/24p: Capture HD Movies in your choice of super-smooth 60p, standard 60i or cinematic 24p, all at Full HD 1920x1080 resolution.1 AVCHD™ codec delivers stunning picture quality. MP4 codec offers smaller files for easier upload to the web.
Wi-Fi® Sharing: Wi-Fi® capability – a first for Alpha-series – lets users transfer photos directly to smartphones and tablets with the PlayMemories Mobile™ app. Wi-Fi capability allows for sharing, viewing and saving photos for expanded photo-shooting enjoyment. Photos can be easily transferred to smartphones and tablets, viewed on large screen TVs or saved to PC’s.11
PlayMemories Camera Apps: Supports PlayMemories Camera Apps, the world’s first application download service that lets users install new camera functions as needed.
180-degree tilt-able 3.0” Touch LCD: The NEX-5R is equipped with a tilt-able LCD screen that flips up 180-degrees without sacrificing the compactness for which the 5-series is renowned for. This makes taking great self-portraits incredibly easy since users can precisely compose shots, choosing to include people or objects in the frame for more satisfying results.
Control Dial: Control dial, Fn (function) button and touch screen (including touch shutter function) greatly facilitate operation and getting the shot that much easier.
Picture Effect mode: There are 7 types (11 variations) of picture effects to choose from: Posterization (Color), Posterization (B/W), Pop Color, Retro Photo, Partial Color(R), Partial Color(G), Partial Color(B), Partial Color(Y), High-key, High Contrast Monochrome, Toy Camera. Each is unique and each give you a new and exciting way to make your images and videos pop.
6-image layering: The camera leverages the large, APS-C image sensor and captures six images in a fraction of a second. The camera then combines the data from the 6 different images up to ISO 25600 to create a single image. This method is used to control blur in Anti-Motion Blur mode or to get cleaner, sharper nighttime pictures in Hand-held Twilight mode.
Photo Creativity Touch interface: The Photo Creativity touch interface enables you to easily enjoy the creative expression of SLR-quality digital imaging without the complicated settings. Changes can be easily made using the control dial with results seen in real time on the LCD. Settings include; Background Defocus, Brightness, Color, Vividness and most Picture Effects.
Auto Portrait Framing: Simply photograph a person and Auto Portrait Framing will save an additional, optimally framed image in portrait or landscape orientation. Combining Face Detection and By Pixel Super Resolution technologies with rule of thirds, Auto Portrait Framing provides beautifully composed and appealingly balanced full resolution portraits.
Clear Image Zoom: Utilizing Sony’s exclusive By Pixel Super Resolution Technology, Clear Image Zoom increases the effective focal length of your lens up to 2x by digitally magnifying the center of your image with nearly imperceptible degradation. It virtually doubles the effective focal length of whatever lens you’re using providing greater shooting flexibility.
Convenient USB charging: Easily recharge the camera via USB charging. Simply connect the bundled USB cable and recharge the battery without removing it from the camera, either via AC outlet or PC connection.
Multi-interface terminal: Multi-interface Smart Accessory 2 shoe greatly expands the connectivity options such as external flash units.
Auto HDR built into camera: High Dynamic Range (HDR) photography captures more scene contrast than a single exposure can handle by combining the best highlight detail from one shot and the best shadow detail from another for one incredible shot. Handles severe backlighting and other high-contrast scenes. Captures in a split second. (Recommended for still subjects.)
Sweep Panorama™ Technology: Capture expansive landscapes automatically. Press the shutter, sweep vertically or horizontally. The camera does the rest, continuously shooting images and stitching them together. Up to 23 MP image size. Up to 202 degrees maximum sweep angle (18mm focal length).
Fast Auto Focus: Some cameras in this class are slow to focus. That can make you miss the shot on fast-moving subjects like sports and unpredictable subjects like pets and babies. Sony’s fast Contrast Auto Focus system typically takes as little as 0.3 seconds and also offers continuous Auto Focus when shooting movies.
evanfotis
26 March 2008
5,668
Η είσοδος των εφαρμογών ;ισως ανοίξει δρόμο για πολλές βελτιώσεις άν αφήσουν ανοικτό κωδικα όπως στa Android, αντι να τις χακεύουνε a la magic Lantern να βγαίνουν κανονικές εφαρμογές.
22 June 2006
35,125
NEO HRAKLEIO
αυτο που θελω να δω ειναι κυριως το Ηybrid Af και η ταχυτητα του....
Η ταχυτητα εστιασης της νεχ 5ν σε κινουμενα θεματα και χαμηλο φωτισμο ειναι ενας απο τους 2 λογους που κραταω την Α65.
ΥΓ.. ο δευτερος ειναι ο ενσωματωμενος σταθεροποιητης !
http://www.youtube.com/watch?v=K7N1hOJtI_I
yiannakas
28 September 2006
1,714
χωρίς ενσωματωμένο φλας, χωρίς pancake φακούς (κοίτα samsung nx), ευχαριστώ δεν θα πάρω....
cacau
7 June 2008
20,950
Και χωρίς ενσωματωμένο σταθεροποιητή, ώστε οι φακοί να είναι ακόμα πιο μεγάλοι από όσο θα μπορούσαν... Δεν είχαν χώρο? Για δέστε την Olympus E-PM1...
Edit: ή την PL3 με σπαστή οθόνη κι αυτή, για να είμαστε δίκαιοι :)
22 June 2006
35,125
NEO HRAKLEIO
οποιος θελει ενσωματομενο φλας και viewfinder , θα βγει η nex 6 σε λιγο.
Σταθεροποιητη δε βλεπω στη σειρα nex, εχουν οι φακοι.
Εγω παντως και χωρις αυτα , δεν την αλλαζω με τιποτα.
Ειναι αλλη αισθηση να εχεις μια μικρη καμερα στη τσεπη σου (η panasonic gh2 Που ειχα ηταν τεραστια μπροστα της) και με 2-3 μικρους φακους πας οπουδηποτε.
Ειναι και το βιντεο φυσικα , οπου εκει η sony δεν εχει ακομη αντιπαλο (πολυ καλο AF, focus peaking για τους manual φακους, 50p κλπ).
gmak13
30 September 2009
586
Έρχεται pancake zoom 16-50 με OSS . Ανακοινώνεται τον Σεπτέμβριο. Με αυτόν το φακό η nex θα αποκτήσει άλλη δυναμική..
22 June 2006
35,125
NEO HRAKLEIO
Για το φακο μιλας η τη μηχανη (350 ευρω) ?
Η μηχανη θ αντικαταστησει την 5n, οποτε περιμενε γυρω στα 600-700 ευρω αρχικα.
Για το φακο δε ξερω....
ΒΛΑΣΙΔΗΣ
19,341
για το φακό Γιάννη. Εκτός αν είναι η αντίστοιχη έκδοση 16-50 2.8 της μοντούρας Α , οπότε μέχρι 600 ευρώ θα είναι καλά.
yiannakas
28 September 2006
1,714
Απάντηση: Re: H Sony ανακοίνωσε την Nex-5R
μπορεί να έχει τα διπλάσια καρέ, αλλά η ποιότητα της εικόνας είναι πολύ κατώτερη απο της GH2.
22 June 2006
35,125
NEO HRAKLEIO
Επειδη ειχα την gh2, δεν ειναι κατωτερη... Με το σπασιμο απλα εχεις μεγαλυτερο bitrate με οτι αυτο συνεπαγεται.
Αντιθετως, εχεις καλυτερο bokeh , και λιγοτερο θορυβο.... κατι κερδιζεις κατι χανεις.
22 June 2006
35,125
NEO HRAKLEIO
δε τη λες φτηνη... αλλα δυστυχως ολες οι mirrorless εχουν ξεφυγει !
H canon eos m εχει 850 ευρω.
Street price παντως θα τη βρισκεις λιγο φτηνοτερη ...
ΥΓ... ευκαιρεια να βρεις καμια nex 5n στις αγγελιες.
