Δες και αυτο.Μπορουμε να στο δωσουμε για test πριν το αγορασεις.
1:8 ATLONA HDMI DISTRIBUTION AMPLIFIER #AT-HDMI18
0%
Atlona 1:8 HDMI Distribution Amplifier. Model: AT-HDMI18
Atlona 1:8 HDMI distribution amplifier is a unique device that allows connecting any of the digital video sources, such as: DVD, Satellite, Cable Box, PC, Xbox, PS3 and more with HDMI output to up to 8 digital displays. AT-HDMI18 splitts hdmi signal up to 8 outputs without signal loss.
User Instructions:
Connect HDMI cable from the digital source to an input of Atlona AT-HDMI18. Connect up to 8 displays to any of the 8 outputs on the AT-HDMI18. Atlona HDMI splitter distributes HDMI ( digital audio/video ) signal to all 8 displays simutaneously. Recommended to use high-quality hdmi cables for the best signal transfer.
Package Includes:
1:8 Atlona HDMI amplifier
5V Universal Power Supply
Users Manual
Features:
HDCP Compliant
Built-in EDID simulator and HDCP keyset allows each output to work independently when connecting to a HDMI display.
Splits an HDMI source up to 8 outputs without signal loss.
Supports DVI source and DVI display by using HDMI to/from DVI adaptor cable.
Supports a wide range of PC and HDTV resolutions from VGA to UXGA and 480p to 1080p.
Can be cascaded up to 3 layers
Each of the buffered output can run up to 15 Meters without a booster
Specifications:
Video Amplifier Bandwidth:1.65 GHz
Max Resolution:1080P
HDMI Input/Output Connector: Type A 19-pin
Power Consumption: 6W Max
Power Supply: 5V DC Universal 110/220
Dimensions: 9 1/2” W x 4” D x 1 1/2” H
Βασιλης Κωνσταντελος
Onar Audiovisual
2103463281
