Horns and multi-amp systems
D I M __ Z
27 June 2006
11,106
Ελλάδα
ETF 2010 (25-28 Νοεμβρίου) ......
http://www.triodefestival.net/index.php?page=etf2010
This year, the main theme is "horns and multi-amp systems"
registration :
"We will compare horn + compression driver couples, above 600Hz. The bass enclosure ( "petite onken" bass reflex with altec lansing 414 ) will be provided, and will be the same for all horn/driver couples.
horns/drivers will be put on a horizontal 1 meter x 1 meter wood board. If needed, a base shall be provided by the participant.
An active crossover will apply the appropriate delay, level and phase for each horn/driver, but frequency, slope and type of filter be the same for all.
The bass and medium amplifier will be the same for all.
The driver impedance shall be about 8 ohm over 600Hz to 10KHz.
A minimum average sensibility of 100dB/1m/2.83V over 600Hz to 10KHz is required.
The shootout listening tests will be MONOPHONIC : there is no need to bring a pair of identical driver+horn, one is enough.
The interface is 2 female 4mm banana plug : Red and black. A positive voltage on the red terminal should move the voice coil toward the horn.
The horn/driver must be made available for the measurement on thursday evening "
*ένα ταξιδάκι σε συνδυασμό με ένα Άμστερνταμ ίσως, θα είναι λουκούμι ....
Δημήτρης Δ.
21 June 2006
5,454
registration :
Μέσα.
