JVC X35/X55/X75/X95
TerI
29 April 2008
1,157
Χίος
Αντιγράφω απο Av Forums περισσότερες πληροφορίες
JVC today announced a new, expanded line of home theater projectors that offers significant improvements in picture performance and upgraded e-shift technology, which upconverts and scales 2D content to a 4K signal. Now called e-shift2, the technology is available in seven new JVC projectors. Other performance-enhancing features include a new illumination system and a new polarizing wire grid in combination with e-shift2 for higher native contrast.
JVC’s 2013 projectors are the Procision Series DLA-X95R, DLA-X75R, DLA-X55R and DLA-X35, marketed by JVC’s Consumer AV Group, and the Reference Series DLA-RS66, DLA-RS56, DLA-RS4810, DLA-RS48 and DLA-RS46, available through JVC Professional Products Company. All are 3D-enabled and all except for the base models in each series offer e-shift2.
Introduced last year on four models, e-shift upconverts and scales 2D HD content to a 4K signal (3840 x 2160) and displays it at full 4K precision. Compared to a Full HD (1920 x 1080) image, that’s twice the horizontal and vertical resolution and four times the number of pixels, or over 8 megapixels. The result is a stunningly detailed image with minimal aliasing artifacts found in standard HD displays. This year’s upgraded e-shift2 technology, available in seven models, provides higher native contrast in combination with a new polarizing wire grid engine.
In other enhancements, new 2K to 4K scaling technology using proprietary JVC algorithms replaces a two-band filter with an eight-band filter to apply more correction to more areas of the image. This delivers a noticeable improvement with any compatible 2D signal. To optimize performance for different content, this Multiple Pixel Control offers five preset modes plus Off.
3D performance has been improved, with new circuitry and a new optical engine responsible for reduced cross talk. The result is more natural, clear and brighter images.
Another key enhancement is a new illumination system, including a new lamp and power supply, which delivers a significant improvement in brightness over the life of the lamp. In addition, the lamp warranty has been extended to one year/1,000 hours.
To provide enthusiasts with a true measure of performance, JVC has long focused on native contrast and refused to artificially enhance contrast specifications through the use of a dynamic iris. For 2013, native contrast has been improved in most models through the use of a new polarizing wire grid, ensuring that every frame consistently and faithfully reproduces peak whites and deep blacks. The flagship DLA-X95R and DLA-RS66 offer a 130,000:1 native contrast ratio. The DLA-X75R and DLA-RS56 offer 90,000:1 native contrast, and the DLA-X55R, DLA-X35, DLA-RS4810, DLA-RS48 and DLA-RS46 offer 50,000:1 native contrast.
Other enhancements new for 2013 are:
· New active shutter glasses for 3D viewing use RF rather than IR technology to offer more stable synchronization and extended range while avoiding possible interference with IR-controlled devices;
· Smartphone application that allows remote control of the projectors from a smartphone or tablet ;
· Additional lens memory settings – Ten for the DLA-X75R, DLA-X95R, DLA-RS56 and DLA-RS66 and five for the DLA-X35, DLA-X55R, DLA-RS46, DLA-RS48 and RS4810. These store custom focus, zoom and horizontal/vertical lens shift position. This allows a constant height display of 4:3, 16:9 , 2.35:1 or any other scope content without an additional anamorphic lens.
The flagship DLA-X95R and DLA-RS66 are built using hand-selected, hand-tested components and have a 130,000:1 native contrast ratio. For 3D viewing, both models come with two pairs of PK-AG3 RF 3D glasses and a PK-EM2 3D Signal Emitter. Both projectors also have a three-year warranty.
The DLA-X75R and DLA-RS56 have a native contrast of 90,000:1.
The DLA-X95R, DLA-X75R, DLA-RS66 and DLA-RS56 feature e-shift2, upgraded light engine, full color management, ISF certification and advanced calibration functionality. In addition, they are designed to pass the 400-plus tests necessary to achieve THX® 3D Certification (pending) – a promise to consumers of the highest level of quality and performance. All JVC THX Certified Projectors include THX 2D and 3D Cinema viewing modes to provide the most accurate color reproduction available in a pre-calibrated setting, ensuring content is rendered back just as its creator intended.
The DLA-X55R, DLA-RS48 and DLA-RS4810 bring e-shift2 to a new price point and feature JVC’s Color Management System, five lens memory presets and a native contrast ratio of 50,000:1. The DLA-RS4810 adds a three year warranty.
The DLA-X35 and DLA-RS46 are 3D-enabled projectors with a 50,000:1 contrast ratio. The DLA-X35 is available with a black or white cabinet.
The new JVC D-ILA home theater projectors will be available in November 2012 at the following prices:
DLA-X95R/DLA-RS66 $11,999
DLA-X75R/DLA-RS56 $7,999
DLA-RS4810 $5,095
DLA-X55R/DLA-RS48 $4,999
DLA-X35/DLA-RS46 $3,499
Together with these new projectors, JVC offers new 3D accessories: the PK-AG3 RF 3D glasses and PK-EM2 RF emitter. Both are compatible with all JVC 3D projectors, including previous models. Also available is a new spare lamp, PK-L2312U, specially designed for JVC’s 2013 models. The PK-L2210U lamp for current JVC projectors remains available.
Accessories prices are:
PK-AG3 RF 3D Glasses $179
PK-EM2 RF Emitter $99
PK-L2312U Lamp $399
TerI
29 April 2008
1,157
Χίος
Απο τα πιο βασικά που ξεχώρισα είναι σίγουρα η αύξηση της φωτεινότητας στα καινούργια μοντέλα, (λογικά θα διαθέτουν καινούργιου τύπου λάμπα?) και άυξηση του χρόνου ζωής κατα 1000 ακόμα ώρες αν και για εμάς τους "καμμένους" μικρή σημασία έχει αυτό καθότι κάθε χρόνο χτυπάμε και μία.Αλλά όπως και να'εχει ακόμα και αυτό κάτι δείχνει στην ποιότητα της φωτεινότητας που ήταν για μένα το τελευταίο κλικ που επιδεχόταν κάποιας διόρθωσης όλη η σειρά Χ της JVC τα τελευταία 2 χρόνια.
spcav
18 August 2006
16,588
2η συνεχόμενη χρονια με face lift η JVC
Αν θυμαμαι καλα, δεν εχει ξανασυμβεί αυτό από εποχης HD-1.
Ενδεικτικό του ποσο εχουν βαλτώσει τα πράγματα στα προβολικά....
vadergr
17 August 2007
27,442
Μεταμορφωση
Προσπαθείς να αντισταθείς ε?Σε νιωθω πάντως ... :p
Portioli
3 June 2007
3,892
Dystopia
Steve Carter, product specialist for JVC UK takes us through the new DLA-X35, DLA-X55, DLA-X75 and DLA-X95. The X55 is a new product added to the line-up with Eshift2 4K and full calibration controls. All the models will be released in November 2012.
Portioli
3 June 2007
3,892
Dystopia
& Άρθρο από το Avforums : Exclusive: JVC Launch DLA-X35, X55, X75 and X95 Projectors
vas_papavas
21 December 2010
8,849
JVC DLA-X55 FULL REVIEW
Εντυπώσεις
Ο προβολέας της δοκιμής μας σε λευκό χρώμα ήρθε στα χέρια μας με μηδενισμένο κοντέρ.
Ο Χ55 είναι αρκετά ήσυχος, κάτι που επιβεβαιώνει τα 23dΒ του ενώ ο θόρυβος αυξάνεται όταν επιλέξουμε τη full λειτουργία όχι όμως σε ενοχλητικό επίπεδο. Εντύπωση μου έκανε η χαμηλή θερμοκρασία του αποβαλλόμενου αέρα από το εμπρός μέρος που δείχνει ότι έχει γίνει καλή δουλειά στο σύστημα ψύξης.
Η ταυτότητα του γνώριμη και οικεία. Εάν μια φορά έχεις δει προβολέα της JVC είναι σίγουρο ότι δεν ξεχνάς την εικόνα του.
Νέο σύστημα ακριβείας pixel alignment έρχεται να βοηθήσει στο σωστό στήσιμό του. Η αλήθεια είναι ότι αποτελεί ίσως ένα από τα καλύτερα συστήματα αυτού του είδους και αυτό γιατί δεν παρουσιάζει παρενέργειες στην εικόνας μας ακόμη και σε υλικό «υψηλών συχνοτήτων» με ενεργοποιημένο ή όχι το «e-shift».
Η επεξεργασία 4K δεύτερης γενιάς δουλεύει και μάλιστα με μεγάλη διαφορά με αυτό που είχαμε δοκιμάσει στον Χ70. Αυτή πλέον μπορεί και συγχωρεί τα λάθη ενώ ταυτόχρονα να ξεδιπλώνει τις αρετές ενός προβαλλόμενου σήματος
Αποτέλεσμα αυτού είναι η εικόνα στο πανί να παρουσιάζεται αέρινη και ανάλαφρη, μεστή και συμπαγής. Υπάρχει η αίσθηση του καμβά και του ενιαίου. Κάθε μία από τις επιλογές που μπορούμε να διαλέξουμε από το μενού έχουν διαφορετικές προρυθμίσεις άσχετα εάν τα εσωτερικά ρυθμιστικά έχουν ίδιες τιμές.
Η φωτεινότητα είναι μικρότερη στα χαρτιά από τον Χ30 π.χ. παρόλο που χρησιμοποιεί νέα λάμπα μεγαλύτερης ισχύος. Το ονομαστικό on/off contrast είναι 50.000:1. Από τα νούμερα και μόνο καταλαβαίνουμε ότι ο προβολέας αυτός με την νέα σχεδίαση του οπτικού μονοπατιού θα έχει βαθύτερο και πιο καθαρό μαύρο.
Μέσω της επιλογής «MPC» μπορούμε να αυξήσουμε την οξύτητα της εικόνας (λειτουργία άμεσα συνυφασμένη με το e-shift).
Η θέαση 2D είναι απολαυστική με τα σκοτεινά και υποφωτισμένα πλάνα να αποτελούν το ατού της εταιρείας και είναι από τα σημεία όπου υπερτερούν οι προβολείς της JVC, ενώ τα φωτεινά πλάνα έχουν μια περίσσια λαμπρότητα, με ισορροπημένη χρωματική συμπεριφορά. Η φωτεινότητα μεγάλη ακόμη και με την λάμπα στην χαμηλή της θέση ενώ το contrast της εικόνας εντυπωσιάζει.
Στον τομέα της κίνησης, ο JVC περνά με επιτυχία τα test. Καλό θα ήταν είναι να μην το παρακάνουμε γιατί η υπερβολή θα δημιουργήσει artifacts στην σκηνή, κάτι το οποίο δεν θέλουμε σε καμιά περίπτωση.
Σε θέαση 3D το αποτέλεσμα ήταν το ίδιο ξεκούραστο, ευχάριστο, με περίσσια κινηματογραφική αίσθηση. Είναι ελαφρά βελτιωμένο σε σχέση με τα προηγούμενα μοντέλα ενώ η πτώση φωτεινότητας με την χρήση των γυαλιών όταν αυτά ενεργοποιηθούν είναι μικρή. Η νέα σύνδεση RF μας δημιούργησε μερικές φορές μικρά θεματάκια σχετικά με το σήμα αλλά την ώρα που γράφονται αυτές οι γραμμές ενημερωθήκαμε ότι η εταιρεία έχει ετοιμάσει νέο λογισμικό που λύνει το όποιο πρόβλημα.
Το crosstalk ήταν περιορισμένο, όπως και το flickering. Δεν μπορώ να πω ότι είναι βελτιωμένο σε σχέση με την προηγούμενη γενιά, ενώ φέτος θα το περίμενα καλύτερο.
Ευχάριστη έκπληξη είναι η μετατροπή από 2D σε 3D. Και το λέω εγώ που δεν αποτελώ fun αυτού του είδους. Παρόλα αυτά έκαστα και είδα 2D σήμα για αρκετή ώρα δίχως αυτό να με κουράσει.
ΣΥΜΠΕΡΑΣΜΑ
Πέρσι πίστευα ότι αυτό το τέχνασμα με το e-shift θα το ακολουθήσουν και άλλες εταιρείες, δεδομένου ότι πολύ εύκολα μπορούν, εάν φυσικά έχουν και την τεχνογνωσία αλλά μάλλον έκανα λάθος. Ίσως να περιμένουν την αμιγώς 4K εποχή. Η jvc όμως με την κίνηση αυτή τραβά ένα μεγάλο μερίδιο αγοράς από άλλους κατασκευαστές ενώ ταυτόχρονα κάνει και μια επίδειξη ισχύος και τεχνογνωσίας.
Φυσικά, τα χρήματα που ζητά ίσως αυτήν την εποχή να αποτελούν για μία μερίδα ανθρώπων ανασταλτικό παράγοντα για την απόκτησή του, αλλά πιστέψτε με θα σας ανταμείψει και με το παραπάνω.
ΥΠΕΡ
- 4Κ e-shift
- 3D με περιορισμένο crosstalk
- Μνήμες θέσης φακού
KATA
- Τιμή
- Τα 3D γυαλιά και o πομπός συγχρονισμού αγοράζονται ξεχωριστά
Μετρήσεις
Η οξύτητας της εικόνας αντιπροσωπεύει το προβολέα της δοκιμής μας, που όμως εξαρτάται αρκετά από το focus του φακού. Ομοιομορφία πάνελ πάνω από 95%, μέσος όρος μέτρησης εννέα διαφορετικών περιοχών. Η φωτεινότητα του προβολέα αυξάνεται μέχρι και 35% με τη χρήση της λάμπας στο High, με επακόλουθη αλλαγή και στην κατανάλωση, από 235W σε 330W. Στο χρωματικό τρίγωνο CIE 1934 επέδειξε σχεδόν άριστη συμπεριφορά, με το πράσινο χρώμα να υπολείπεται ελάχιστα αλλά μπορεί να ρυθμιστεί λεπτομερειακά μέσω του CMS που διαθέτει, ενώ το grayscale ήθελε ελάχιστο πείραγμα στα χαμηλά IRE έχοντας επιλέξει σαν θερμοκρασία χώματος τους 6.500Κ. Με τη χρήση των γυαλιών για θέαση 3D, η φωτεινότητα έπεσε μέχρι και 45%, ενώ η θερμοκρασία χρώματος αλλάζει έως και 2.400 Κ περισσότερο (8.900°Κ). Το on/off contrast μετρήθηκε στο 41.900:1, ενώ το ANSI Contrast 370:1. Η φωτεινότητα του προβολέα για κάδρο 84 ιντσών από απόσταση 3,20 μέτρων μετρήθηκε στα 750 AΝSI Lumens με τη λάμπα στο High και 550 στην θέση low κάτι που σημαίνει ότι μπορεί να ανοίξει με σχετική ευκολία 125 ίντσες για θέαση υλικού 2D.
MEASUREMENTS ON/OFF CONTRAST: 41.900:1
HIGH LAMP IRIS 0 750 LUMENS
Ansi Contrast: 370:1
Recommended screen size:≤120′
Πηγή:
http://www.perfectimage.gr/2013/03/26/jvc-dla-x55-full-review/
Browser
10,575
Αυτο το perfectimage, πολυ perfect μας τις βγαζει τις image τωρα τελευταια :ADFADF1:
35,671
Γιατί? Το χρωματικό τρίγωνο σε default κατάσταση έχει αρκετό σφάλμα και φαίνεται από το γράφημα. Σε RGB και gamma είναι καλός για out of the box!
Browser
10,575
Λογοπαιγνιο ηταν Γιαννη για τον ιστοτοπο του Μανωλη :ernaehrung004:
Στα υπολοιπα, ετσι ειναι , οπως τα λες.
Browser
10,575
Παντως για να τον εχει ο μαστορας editors choise, φανταζομαι τι θα ειδε......:drummer:
ichaltou
Είναι εξαιρετικός προβολέας και με πολλές επιλογές στην ρύθμιση του. Εγώ δε, έχω τύχει και ένα κομμάτι με εξαιρετική σύγκλιση. Όταν με το καλό ο Μανώλης κάνει την τελική του ρύθμιση, πιστεύω πως θα έχουμε πολλά να συζητήσουμε.
3,031
Γιάννη ετοιμάσου γιατί θα ανέβω σύντομα στην Θεσσαλονίκη.
812
ε καλα βρε ........
μονο κατι τζιβι....
....αντε σονια-και επσονες τα πανε καλα χρωματικα και με την αναλογη αντιθεση για να βλεπεις πλησιον του ορθου.
.....η ισορροπημενη αντιθεση σε on/off - ansi contrast - η πολυ καλη χρωματικη τους αποδοση εχοντας σωστο gamma 2.2-2.3 ισορροπημενο σε ολα τα ire,χωρις αυτοματες δυναμικες ιριδες κανει την εικονα τους εικονα αναφορας.
Chrpep
18 June 2010
1,200
Αξιοζήλευτα προβόλια,αλλα ρε παιδιά αξίζει να σκάσει κανείς 5k σήμερα εν όψη 4Κ ανάλυσης; Θα προλάβει να κάνει απόσβεση; Λέω απλά τη σκέψη μου, όποιος έχει γνώμη και θέλει μου απαντάει..
