The audio level between different TV programs, channels, and in particular commercials is very inconsistent. Dolby Laboratories realized that these radical differences between different types of sources, channels and content would be extremely inconvenient for a TV viewer to continually have to adjust the audio level while watching TV. Because of this, Dolby Labs decided to implement a feature called Dialog Normalization. Dolby includes this feature in metadata of any Dolby Digital bitstream. The only piece of metadata that is mandatory for consumers is dialognorm values. Other example such as downmix metadata is optional and the sound engineers can use it at their discretion.
In a soundtrack such as Dolby Digital, the loudest level is expressed as 0dB and the quietest level as -105dB. The Dialnorm value expresses the level of dialogue as how much lower it is than the peak 0dB. A value of -31 indicates 31dB below the peak. This is the value at which no volume adjustment is performed by the receiver/decoder. A Dialnorm value of -27 would indicate to the receiver/decoder that the dialogue is at a point 27dB below the peak, or 4dB higher than a program with a Dialnorm value of -31. The decoder would then turn the volume down by 4dB. A Dialnorm value of -25 would call for a 6dB reduction and so on. The -27dB setting yields a very natural level for talking and has been the standard level for dialogue in motion picture soundtracks.
Dialogue Normalization works by assigning a relative numerical value as described above to the average dialogue level of a given program, commercial, movie etc. This numerical value should be calculated using hardware or software tools offered by Dolby and is then encoded into the Metadata by the content creator or broadcaster. The graph below shows some of the typical relative levels between different types of source material. The black line and the numerical number next to that line, would be the dialog normalization level.
αυριο παραλαμβανω απο multirama την ATI 5450 και θα αρχισω τα τεστ με windows 7 και onkyo 807.ελπιζω να πανε ολα καλα!
Επίσης αφου τα σετάρεις όλα, τσέκαρε και αυτό....
INSTALLATION
Easy Method
1. Go to Start
Computer [Right-click]
Properties [Select]
2. Device Manager [Select]
Monitors[Expand]
Monitor ID [Righ-Click] (usually "Generic PnP Monitor")
Properties [Select]
Driver tab [Select]
Update Driver button [Select].
3. Make sure that the .inf driver is the ONLY one in its dir
Browse my computer for driver software [Select]
Let me pick from a list of device drivers on my computer [Select]
Have Disk [Select]
Browse to the directory where .inf driver is located.
Click on .inf file and then on the Open button
OK [Select]
Next [ Select]
Confirm installation if necessary ([Windows Security] Install this driver software anyway)
Close [Select]
REBOOT
Alternate method
If you have more than 1 monitor setup you most probably will have more than one "Generic PnP Monitor" device in the Monitors tab. Use this alternate procedure for these cases.
1. Mouse on Desktop [Right-click]
Personalize [Select]
2. Display [Select]
Change display settings [Select]
Screen of the display device to override [Select]
Advanced settings [Select]
Monitor Tab [Select]
Properties button [Select]
Driver tab [Select]
3. Follow step 3 from Easy Method above
3. EDID CAPTURE with MONINFO
The EDID Override mod for solving the bitstreaming and/or video handshake issues on the 5xxxs is usually made up by a combination
of the display device video data stored in its corresponding EDID + the audio descriptors of Onkyo TX-NR906 EDID that solves
the bitstreaming issues + rest of information stored in the AVR/AVP EDID.
So, the 2 EDIDs (display device & AVR/AVP) are required to do the mod. Also the full REAL-TIME (no registry entries) 256-byte EDIDs are required. But NOTE that, so far, Moninfo cannot capture the full REAL-TIME EDIDs on the 5xxxs, and I know of no other method to do it.
Display Device EDID Capture
1. Connect the graphic card HDMI-in to your display device HDMI-out.
2. Launch Moninfo.
"[Real time ...]" entry on top left "Display IDs" window [Select]
File [Select]
Create INF [Select]
SAVE TO [Your display device name].inf. (e.g. Samsung LN-S4095D)
AVR/AVP EDID Capture
1. Connect the graphic card HDMI-in to your AVR/AVP HDMI port.
[Optionally] Connect the AVR HDMI port to the display device HDMI-out.
2. Launch Moninfo.
File [Select]
Create INF [Select]
SAVE TO [Your display AVR/AVP name].inf. (e.g. DENON AVR988)
http://rapidshare.com/files/348337294/EDID_Overrides.zip.html
Τα κατάφερες τελικά να πάρεις bitstream; Εγώ παλεύω μια εβδομάδα τώρα και δεν έχω κάνει τίποτα. Αυτό που θέλω να σε ρωτησώ είναι αν τελικά με την ATI 5450 μπορούμε να έχουμε bitstreaming out.
Είναι ευκολο να μου εξηγήσετε σε απλά ελληνικά τι θα το κάνω το αρχείο *.inf;
Τα αγγλικά μου είναι άθλια, το έχω δώσει και σε άνθρωπο σχετικό να μου πει τι θα κάνω, άκρη όμως δεν βγήκε. Επειδή έχω Denon 4308 υποπτεύομαι ότι κάπου εδώ είναι η λύση του προβληματός μου.
Ευχαριστώ.
έχεις πρόβλημα με την HDMI σύνδεση ή με την κάρτα γραφικών? Bitstreaming απλό DTS από την HDMI σύνδεση έχεις κανονικά?
Το νέο αρχείο .inf μπαίνει στην θέση του monitor driver.
Απο την στιγμή που έβαλα το συγκεκριμένο .inf στο ΟΛΑ δουλεύουν τέλεια...
Αν θές διάβασε μερικές σελίδες πίσω ΤΙ προβλήματα είχα, κι αν ταιριάζουν με τα δικά σου προχώρα σε update του monitor .inf και θα είσαι ΟΚ.
Οπως φαίνεται και στις φωτογραφίες ολά δουλεύουν κανονικά πλην του Bitstreaming HD.
Φοβάμαι ότι φταίει η σύνδεση.
Και στο PowerDVD και στον Media Player Classic - Home Cinema είχα τα ίδια αποτελέσματα
Φίλε μου ψυχραιμία
1)Το αρχείο mkv που παίζεις στο MPC-HC είσαι σιγουρός ότι έχει DTS-MA track και όχι απλό DTS? Αν είχε όταν πήγαινες να το επιλέξεις στο FFDshow κατά την αναπαραγωγή θα σου έβγαζε ένα συρτό ήχο συνεχόμενο αν δεν το υποστηρίζει.. Το δοκίμασες?
2)Έχεις βάλει Ατι 10.2 οδηγούς?
3)Έχεις κάνει τις ρυθμίσεις στο FFDshow audio για bitstream DTS-MA και DD true hd?
4)Πήγαινε στο εικονίδιο με το ηχειάκι στην taskbar και δεξι κλικ playback devices/ati hdmi output/supported formats εκεί τι φορμά σου δείχνει να υποστηρίζει? Αν δεν λέει και DTS-MA , DD true hd τότε μάλλον είναι πρόβλημα EDID
Χαράς ευαγγέλια. Έκανα μια δευτέρη προσπάθεια με το .inf αρχείο. Εβαλα ένα *.inf με Denon και το αποτέλεσμα:
1) Στο PowerDVD DTS-MA και DD true hd κανονικότατα.
2) Στο Media Player Classic DD true hd.
Αυτό που μένει είναι το DTS-MA στον MPC. Μου βγάζει τα ίδια όπως φαίνεται στην παραπάνω εικόνα. Το μεγάλο άγχος μου έφυγε πάντως.
Στον MPC ποιον audio renderer έχεις επιλέξει??(στο output)
Ποιές εκδόσεις του MPC και FFdshow έχεις??
