στην έκθεση Hi End Show 2009 θα έχουμε την ευκαιρία να δούμε και την απάντηση των Γερμανών στην υψηλής ευκρίνεια τηλεοράσεις
είναι πάντως κόσμημα....
Images
24p motion picture display
Brightness cd/m²: 500
Contrast panel
Contrast ratio dynamic: 30.000 : 1
Contrast ratio static: 5.000 : 1
Contrast sensor
Format options: 16 : 9, 4 : 3, Panorama, Cinema, Zoom
Fully digitised signal processing
HDTV-ready
Horizontal and vertical viewing angle: 178° / 178°
Image resolution: 1.920 x 1.080
Image+ Active
Picture format: 16 : 9
Picture frequency: 200Hz
Response time: 5 ms
Screen diagonal in cm: 131
Vertical image correction
Audio:
3D-Surround
DTS®
Dolby Digital® [1]
Output in Watts (music/sine): 4x40/20
Panorama
Sound+ with CRX® sound system
Subwoofer Out
Two-channel stereo sound
Connectors:
Antenna DVB-S2: 2x, DVB-T/C: 2x, analogue: 2x
Audio In (Cinch)
Audio Link
Audio Out, controlled: constantly selectable
Common Interface with CI+ Standard: 2
Component (YUV) input
Digital-Audio Out (Cinch): 1
Euro-AV to Euro-AV copy function
Euro-AV/Scart total: 1
Euro-AV/Scart, of which the following number are
Component Video Input-ready: 1
RGB-ready: 1
S-VHS/Hi8-ready: 2
Front AV Video-/S-VHS, Hi-8 ready: 1 / 1
Front-AV to Euro-AV copy function
HDMI including HDCP: 2Headphones (3.5 mm jack)
L-Link
Motor control
Network Media Player
Network connection
RS 232 C
Side AV Video-/S-VHS, Hi-8 ready
USB: 2x
VGA
Video In (cinch)
WLAN antenna: 2x internal
Reception
Audio standard: Two-channel FM / AM, Nicam
Colour standard: PAL, Secam, NTSC, NTSC-V, PAL-V (60 Hz)
DVB-T / DVB-C / DVB-S 2 / Multi-standard (analogue)
Decoding System Audio: MPEG
Decoding System Video: MPEG 2/MPEG 4
Tuner: DVB-T, DVB-C, DVB-S/S2; DVB-T, DVB-C; analogue:
cable, antenna [4]
Weight (approx.) in kg: 59,4
Weight (net) in kg: 59,0
Images
Contrast panel
Contrast sensor
HDTV-ready
Image+ Active
Response time: 5 ms
Audio:
3D-Surround
DTS®
Dolby Digital® [1]
Panorama
Subwoofer Out
Connectors:
Audio In (Cinch)
Audio Link
RGB-ready: 1
S-VHS/Hi8-ready: 2
L-Link
Motor control
Network connection
RS 232 C
USB: 2x
VGA
Video In (cinch)
Reception
cable, antenna [4]
