Logitech® Harmony® 1000 Advanced Universal Remote
Browser
10,575
The latest and most intelligent evolution of simple, one-touch control.
The Logitech® Harmony® 1000 features a brilliant 3.5” color touch screen that allows for one-touch activity-based control of even the most sophisticated A/V components. Say goodbye to the wasted time and unnecessary complexity of multiple remotes controlling multiple devices; Logitech's patented Smart State Technology® makes it easy! Control your HDTV, adjust aspect ratios, or change sound modes—there are no complicated macros to program. Just press an on-screen activity icon and Harmony does the rest.
The Harmony 1000's sleek shape and brushed aluminum surfaces will look right at home as the centerpiece of your digital living room. One remote is all you'll need to control even the most complex home entertainment systems. And when used together with a Harmony® RF Wireless Extender (sold separately), you can further reduce clutter by placing your components out of sight. Since the remote can transmit both infrared and radio frequency commands, you can control equipment inside a cabinet or even in the next room.
USD 499.99
http://www.logitech.com/index.cfm/products/details/US/EN,crid=2084,contentid=12498#Specifications
Browser
10,575
Overview
Gain complete control of components that are hidden behind cabinets or walls. With a range of up to 100 feet, you can place your equipment out of sight, or even move it to the next room. Designed for use with the Logitech® Harmony® 1000 or 890 Advanced Universal Remotes, Z-Wave (RF) Technology enables remote control of audio, visual, lighting, climate, and security systems without direct line-of-sight. Use additional receivers to control multiple entertainment systems.
USD 149.99
http://www.logitech.com/index.cfm/products/detailsharmony/US/EN,CRID=2084,CONTENTID=11039
spcav
18 August 2006
16,598
Προσπαθώ να το βρω καιρό.
Από αντιπροσωπεία μου είπαν ότι λογικά έρχεται όπου να ναι.
Μόλις το έχω θα γράψω εντυπώσεις.
knight_77
14 September 2006
174
Αθηνα
150$ για τηλεκοντρολ δεν ειναι και λιγα παντως:violent-smiley-030:
Nα δουμε ποσο θα κανει εδω στο Ελλαντα.....
Browser
10,575
Ετσι....( πιο κατω, μαλλον τη μετατροπη την πηγες αναποδα!!)
....απλα το αργαλλλειο δεν ειναι απλο τηλεκοντρολ..!!!
sfortis
Administration Team
3 August 2006
11,396
t3.large
Re: Απάντηση: Re: Logitech® Harmony® 1000 Advanced Universal Remote
Μα για μια υπερβολη ζουμε...:award::award:-bye-
:flipout::flipout:
Αρκει να εχουμε και υπερβολικα λεφτα!!:Banane0::music-smiley-005:-bye-
Browser
10,575
Μα αμα εχεις υπερβολικα λεφτα , δεν ειναι υπερβολη....:flipout::flipout:-bye-
:grinning-smiley-043
Νίκος Σχ.
12 July 2006
4,221
Και δεν το κάνω με ένα PDA και IR ; Λίγο πέδεμα στην αρχή , αλλά μετά θα είναι τηλεχειρηστήριο για όλα .... Το κόστος; 200 ευρώ και ένα ΣΚ ...
Θάνος Φούντας
22 June 2006
1,878
Πάντως επειδή πρόσφατα το έψχνα έχει τις ίδιες δυνατότητες με το 895 απλά είναι μεγάλο με touchscreen... Επιβεβαιώνω πάντως ότι δεν το έχει κανείς ακόμα στο Ελλάντα. Από Γερμανία μπορεί...
doros
1,411
Ηράκλειο Αττικής
Μπορεί να είναι λίγο off topic, αλλά κάποιος όπως εγώ, που απλώς θέλει να χρησιμοποιεί ένα universal R C, για τις απλές λειτουργίες (ON, OFF, volume etc), θα μπορούσε να "βολευτεί" με κάτι τέτοιο;
http://www.plaisio.gr/product.aspx?catalog=15&category=39461340&product=890014
Ή θα δυσκολευτώ πολύ να ρυθμίσω;
