madVR v0.87.*
* added debanding algorithm, based on improved version of "flash3kyuu_deband"
* added file name tag "deband=off|low|medium|high"
* added automatic detection for fades from/to black or white (for debanding)
* added support for using OpenCL with NVidia, AMD and Intel GPUs
* added DXVA surface splitting via OpenCL (only AMD and Intel GPUs)
* added error diffusion algorithm (requires DX11 GPU)
* added NNEDI3 chroma upsampling (requires OpenCL)
* added NNEDI3 image doubling/quadrupling (requires OpenCL)
* added flexible settings profile functionality
* added fast and reasonably high quality "ordered dithering" algorithm
* added "rendering\dithering" settings page with many new options
* added linear light processing for ordered dithering and error diffusion
* added "trade quality for performance" option for linear light dithering
* added new windowed presentation path ("present several frames in advance")
* added support for decimating 50p/60p movies to 25p/24p
* added profile strings "filePath/Name/Ext", with wild char ("?", "*") support
* new default dithering is now ordered dithering instead of random dithering
* madTPG now always uses monochromatic ordered dithering
* added file name tag "profile='profile name'"
* added IMadVRSettings2 interface to enumerate settings and manage profiles
* settings can now be edited without madVR running (only on local PC)
* madNvLevelsTweaker -> madLevelsTweaker now also works for Intel GPUs
* madVR doesn't dither, anymore, when a pixel doesn't need dithering
* added Intel driver bug workaround for "use separate device for presentation"
* added madHcNet64.dll to allow madTPG automation from 64bit calibration tools
* added API for asking madVR about the output levels (TV, PC, custom)
* fixed: #032: Smooth Motion FRC sometimes failed to activate
* fixed: #090: FSE mode switched to 23Hz instead of 24Hz in Windows 8
* fixed: #096: Smooth Motion FRC resulted in last/only frame being hidden
* fixed: #097: Smooth Motion FRC didn't respect "treat 25p movies as 24p"
* fixed: #098: "Treat 25p movies as 24p" now only activates up to 25.5fps
* fixed: #104: "Delay playback until ..." failed when toggling subtitles
* fixed: #107: XySubFilter: reducing CPU queue size during playback -> crash
* fixed: #112: 120fps clip resulted in 23Hz being selected instead of 60Hz
* fixed: #113: film mode key shortcut didn't enable Smooth Motion FRC
* fixed: #119: installation resulted in "might not have installed correctly"
* fixed: #123: XySubFilter: Nearest Neighbor/Bilinear distorted subtitles
* fixed: #124: videoLUTs were not properly restored in multi monitor setup
* fixed: #125: forced film mode with unsupported FOURCCs: graphical corruption
* fixed: #127: crash when jumping to next video file on secondary monitor
* fixed: #132: Image corruption when leaving FSE with 3dlut loaded
* fixed: #133: XySubFilter: opaque black box when smooth motion was enabled
* fixed: #136: when playback is stopped, madVR now always turns the video off
* fixed: #137: Nearest Neighbor/Bilinear has problems with post-resize shaders
* fixed: #138: smooth motion FRC flickered when using Nearest Neighbor
* fixed: #145: DCI-P3 was using an incorrect white point
* fixed: #155: screeshots sometimes had an added black border
* fixed: #159: speciying DCI-P3 as the calibrated gamut -> green screen
* fixed: #160: corruption with uncompressed 4096x2304 v210 in AVI
* fixed: #161: YUV 4:4:4 videos with weird resolutions crashed madVR
* fixed: #165: overlay mode restricted madVR to single player window
* fixed: #167: dithering produced dithering noise on pure black areas
* fixed: #169: dithering produced dithering noise on pure white areas
* fixed: #170: Overlay mode sometimes unnecessarily cleared GPU gamma ramps
* fixed: #171: film mode activation with display mode change could crash
* fixed: #173: overlay: exiting multiple windows in same order -> black screen
* fixed: #175: Banding appears if bitdepth is set to '7 bit'
* fixed: #178: RGB/YUV 4:4:4 with mod2 height showed black screen
* fixed: #182: NNEDI3 chroma up neuron count wasn't properly memorized
* fixed: #187: switching subtitles triggered a short black screen
* fixed: #189: Smooth Motion FRC sometimes activated when not needed
* fixed: #193: image corruption when up&down scale is needed at the same time
* fixed: crash in MC19 when switching videos with native DXVA decoding
* fixed: Overlay mode applied 3dlut and gamma ramps in wrong order
* fixed: crash reporting didn't catch exceptions in private threads, anymore
* fixed: crash when using XySubFilter with small GPU queue size
* fixed: DVD navigator was not released properly by madVR
* fixed: smooth motion frc sometimes incorrectly dropped frames
* fixed: Run/Seek hooks also affected secondary DirectShow graphs
* fixed: profile key shortcuts only worked for "scaling" profiles
* fixed: full range YCbCr input produced slightly incorrect colors
* fixed: full backbuffer queue slowed rendering down
* fixed: madTPG sometimes didn't update to newly requested test pattern color
* fixed: madTPG dithering produced blocking artifacts
* fixed: when upscaling exactly 2x, AR filter wasn't active for blue channel
* fixed: ArgyllCMS/HCFR disabling the 3dlut didn't work
* fixed: LAV Video Decoder sending v210 produced corrupted image
* reduced Overlay mode graphical corruption when resizing media player
* exclusive -> windowed switch now shows a black frame instead of an old one
* removed XySubFilter auto-loading functionality, it's now XySubFilter's job
* modified madLevelsTweaker GUI to make intended multi monitor usage clearer
* disabled resolution based DCI-P3 auto detection
* changed default luma doubling value to 32 neurons
* improved frame cropping support
* random dithering doesn't round down to less than 8bit, anymore
* refresh rate hack is now only installed on Windows 8 (and newer)
* "Pause" OSD message no longer blocked
* file "madshi.net/madVR/version.txt" lists the current version number
* file "madshi.net/madVR/sha1.txt" lists SHA1 hash of the current "madVR.zip"
* "present several frames in advance = off" now auto-disables error diffusion
* display bitdepth can be be set to as low as 1bit (just for testing)
* added silent exception handling for Intel OpenCL initialization crashes
* fixed: madTPG API "madVR_ConnectToIp(127.0.0.1)" sometimes didn't work
* madTPG now optionally supports APL windows (gamma and linear light)
* madTPG now has a minimum image area of 4% instead of 10%
* madTPG now draws a 20 pixel black border around the measurement area
* madTPG now properly supports dynamic dithering (didn't before)
* madTPG dithering was optimized to not dither for integer test patterns
* madTPG headers and demo projects updated
* madTPG: added API "Connect" with various options
* madTPG: added API "Quit" to close the connected madTPG instance
* madTPG: added API "GetVersion"
* madTPG: added API "Get/SetSelected3dlut"
* madTPG: added APIs "Get/SetPatternConfig" & "ShowRGBEx"
* madTPG: added APIs "IsStayOnTopButtonPressed" & "SetStayOnTopButton"
* madTPG: added APIs "IsUseFullscreenButtonPressed" & "SetUseFullscreenButton"
* madTPG: added APIs "IsDisableOsdButtonPressed" & "SetDisableOsdButton"
* madTPG: added "madVR_Find" API
* madTPG: added various new 3dlut conversion and loading APIs
* madTPG: added IP address information to title bar
* madTPG: added dropdown box to allow manual gamut/3dlut selection
* madTPG: loading a 3dlut now takes immediate effect in madTPG
* madTPG: number of pre-presented frames is now limited to max 3* madVR in a media player no longer supports test pattern, only madTPG does
* added OSD API stretch option
* improved windowproc hook stability
* a couple of very small pixel shader performance improvements
* optimized madVR default settings
* improved madVR tray icon menu looks on newer OSs
* tags now require "tag=value" or "tag:value"; "tag value" no longer accepted
* disabled automatic DCI-P3 detection through 2048 video width
