Τα συγκεκριμένα δεν έχουν καμία υποδομή για να κρεμαστούν. Μπορούν απλά να "κάθονται" πάνω σε flat επιφάνεια...
Ούτε Keyhole δεν έβαλαν; Καλά θα μου πεις σε αυτή την τιμή πάλι καλά που έχουν βάλει μεγάφωνο...
Σχετικά με την τοποθέτηση των upfiring:
Placement height
For optimal effect and to minimize direct radiating audio at listener level, place Dolby Atmos enabled speakers at or slightly above the height of your ears when seated. Avoid placing the Dolby Atmos enabled speakers higher than one-half the height of your wall.
Note: For some Dolby Atmos enabled in-wall speakers, if the placement is above one-half the height of your wall, you may need to adjust the vertical angle, if the manufacturer implements this feature. Please consult the manufacturer’s user manual for guidance.
Placement relative to listeners
To avoid an unwanted proximity effect, make sure the speakers are at least 3 feet (0.9 meter) away from listening positions, ideally 5 feet (1.5 meters) or more. This distance may be less than 5 feet if the upward-firing driver(s) of the Dolby Atmos enabled speaker is placed well above the level of the closest listener’s head.
Positioning of add-on modules
If you’re using add-on modules, place them either on top of the front and surround (ideally, rear surround) speakers or within 3 feet (0.9 meter) of those speakers. Place on-wall or in-wall add-on modules in the same position. Dolby Atmos enabled speakers should be mounted so that the driver is facing toward the ceiling.
