Nέα γενιά Intel : Ivy Bridge (2012)
Portioli
3 June 2007
3,892
Dystopia
The Ivy Bridge Preview: Core i7 3770K Tested
The Lineup
Processor Core Clock Cores / Threads L3 Cache Max Turbo Intel HD Graphics TDPTιμή (skoutz)
Intel Core i7 3770K 3.5GHz 4 / 8 8MB 3.9GHz 4000 77W314
Intel Core i7 3770 3.4GHz 4 / 8 8MB 3.9GHz 4000 77W280
Intel Core i5 3570K 3.4GHz 4 / 4 6MB 3.8GHz 4000 77W216
Intel Core i5 3570 3.4GHz 4 / 4 6MB 3.8GHz 2500 77W196
Intel Core i5 3550 3.3GHz 4 / 4 6MB 3.7GHz 2500 77W198
Intel Core i5 3470 3.2GHz 4 / 4 6MB 3.6GHz 2500 77W179
Intel Core i5 3450 3.1GHz 4 / 4 6MB 3.5GHz 2500 77W180
Intel Core i5 3330 3.0GHz 4 / 4 6MB 3.2GHz 2500 77W175
Intel Core i3 32403.4GHz2 / 43MB-250055 W135
Intel Core i3 3240T2.9GHz2 / 43MB-250035W-
Intel Core i3 32253.3GHz2 / 43MB-400055 W127
Intel Core i3 32203.3GHz 2 / 43MB-250055 W103
Intel Core i3 3220T2.8GHz2 / 43MB-250035W128
Pentium 21203.1GHz2 / 23MB-Intel HD Graphics55W85
Pentium 2120T2.6GHz2 / 23MB- Intel HD Graphics35W-
Chipset Support
Z77Z75H77Z68P67H67
CPU SupportIVB
LGA-1155
IVB
LGA-1155
IVB
LGA-1155
SNB/IVB
LGA-1155
SNB/IVB
LGA-1155
SNB/IVB
LGA-1155
CPU OverclockingYesYesNoYesYesNo
CPU PCIe Config1 x16 or
2 x8 or
1 x8 + 2 x4
PCIe 3.0
1 x16 or
2 x8 PCIe 3.0
1 x16 PCIe 3.01 x16 or
2 x8 or
1 x8 + 2 x4
PCIe 3.0
1 x16 or
2 x8 PCIe 3.0
1 x16 PCIe 3.0
Processor Graphics SupportYesYesYesYesNoYes
Intel SRT (SSD caching)YesNoYesYesNoNo
USB 2.0 Ports (3.0)14 (4)14 (4)14 (4)141414
Μητρικές m-itx:
Z77
H77
Aντιστοιχία Sandy με Ivy Bridge :
  • Core i7 2600/2700 -> Core i7 37xx
  • Core i5 23xx/24xx/25xx -> Core i5 33xx/34xx/35xx
  • Core i3-21xx -> Core i3 31xx
  • Pentium G8xx -> Pentium G2xxx
Σύγκριση Sandy με Ivy με τα ίδια ρολόγια
Ivy Bridge/SB performance per clock comparision
---GAMES---
Starcraft 2
12% faster
Metro 2033
3.0% faster
Dawn of War II
7.2% faster
Civilization V
9.8% faster
Worlds of Warcraft
6.7% faster
AVERAGE BOOST IN GAMES: 7.7%
AVERAGE BOOST IN GAMES WITHOUT METRO 2033: ~9%
---APPS---
7-zip
12.5% faster
Photoshop CS4
7.3% faster
3dsmax r9
5.6% faster
Cinebench 11.5
6.4% faster
Cinebench 11.5 multithread
8.0% faster
x264 HD Benchmark - 1st pass - v3.03
7.0% faster
11% faster
AES-128 Performance - TrueCrypt 7.1 Benchmark
6.3% faster
AVERAGE BOOST IN APPS: ~8%
I'm impressed by the gains we see with Ivy Bridge. It's hard to increase IPC from a modern architecture today. This IPC improvements combined with higher clocks (I think it'll clock alot higher than SB) and faster supported memory will make Ivy a clear step up.
Hell yeah, Ivy comes to me fast and target is 6GHz on AIR...:cool:
πηγή xtremesystems.org : Ivy Bridge Sandy Bridge clock to clock comparision
μητρικές mATX & mini-itx για Ivy socket: LGA 1155 chipset : Z77
This post is to designed to be a compilation of the more-exciting motherboards that will be arriving with Ivy Bridge. I'll try and keep this updated as more details are released.
Micro ATX
Z77
Gigabyte
G1.Sniper M3 (VR-Zone)
9-phase VRM (CPU); 6 SATA (2 x 6Gb/s); Creative SoundCore 3D w/ headphone amplifier; Intel NIC; Rear panel: 2 x USB 3.0, 4 x USB 2.0;​
ASRock
Fatal1ty Professional-m (TechPowerUp, Overclockers Club)
11 phase VRM (CPU); 8 SATA (4 x 6Gb/s); Rear panel: 4 x USB 3.0 (?), 2 x USB 2.0 (?);​
Asus
Maximus V gene (VR-Zone; [H]ardOCP)
12 phase VRM (CPU); 6 SATA (2 x 6Gb/s); Supreme FX III sound card; Rear panel: 4 x USB 3.0, 4 x USB 2.0; mPCIe slot;​
mini-ITX
Z77
ASRock
Z77 E-ITX (TechPowerUp)
6 phase VRM (CPU); 4 SATA (2 x 6Gb/s); 4 x USB 3.0;​
Asus
P8Z77-I deluxe (VR-Zone; ChipHell)
8 phase VRM (CPU); 4 SATA (2 x 6Gb/s); 4 x USB 3.0, 4 x USB 2.0; mPCIe slot​
πηγή : Ivy Bridge high-end SFF motherboard compilation
QuickSync Performance
Late last year we mentioned that Intel would be bringing improved QuickSync to Ivy Bridge. Details were scarce, but we theorized that improvements to Ivy Bridge's video decoder might be part of the reason. At least with the drivers we tested with, improved video decoder speed was largely responsible for the advantage you can see below.
For this test we transcoded a 3GB AVC main profile movie using ArcSoft's 720p 3Mbps YouTube HD profile:
Once again we're showing a ~40% improvement over Sandy Bridge - a big step forward. The QuickSync side of IVB is one of the lesser known aspects of the architecture, I suspect we'll have to wait for the launch to truly understand what we can expect from Ivy. Needless to say, QuickSync is even faster this year.
New slide confirms April 29th launch date for Ivy Bridge
29 Απριλίου οι πρώτοι Core i7 & i5, 3 Ιουνίου μερικοί ακόμα i5
το καλοκαίρι οι μικροί i3 και pentium.
Read more: http://vr-zone.com/articles/new-sli...-date-for-ivy-bridge/15198.html#ixzz1ocFJoeKL
naxian
30 October 2007
1,091
Re: Nέα γενιά Intel : Ivy Bridge
στο κομματι του 24p playback εχουν λυθει τα προβληματα?
vas_papavas
21 December 2010
8,849
κάπου πήρε το μάτι μου ότι πάνε για ιούνιο το launch date. έχουν μείνει σε stock κάποιοι i7 και i5 mobile και θέλουν να ξεστοκάρουν. είμαι στο περίμενε αλλά πάει μακριά η βαλίτσα (αναμονή για παιδικές ασθένειες κλπ). βέβαια δεν την βιάζει κανείς την intel. ετσι και αλλιώς μόνη της παίζει στο παιχνίδι. μιλάνε για αυξημένες επιδόσεις - μειωμένη κατανάλωση και ίδια - μειωμένη τιμή με τους sandy.
lykman
29 June 2006
5,798
Aθήνα
Απάντηση: Nέα γενιά Intel : Ivy Bridge
Και τα πρώτα νέα για τους ivy pentiums... Δεδομένου μάλιστα της επιτυχίας των G6XX αναμένονται και αυτοί να σαρώσουν, φτηνοί, με χαμηλή κατανάλωση, και ισχυρότατοι!
2 πυρήνες, χωρίς ΗΤ, χωρίς turbo, στα 3.10GHz (αρκετά ψηλότερα από τους τωρινούς ξεκινάνε). Στα 65W το TDP τους...
Intel's first Pentium processors based on the 22 nm "Ivy Bridge" silicon will arrive in Q4, 2012. One of the first models in the series, is the Pentium G2120. Specifications reveal that the chip will be quite generously designed as far as specifications go. To begin with, it is a dual-core processor, with a clock speed of 3.10 GHz. It lacks HyperThreading, so 2 logical CPUs is all that the OS will see; as well as Turbo Boost, so the clock speed won't normally scale beyond 3.10 GHz. Interestingly, the chip has 3 MB of L3 cache, on par with some Core i3 dual-core chips. The instruction-set has SIMD instructions up to SSE 4.2, but lacks AVX. Further, the PCI-Express root hub only supports PCI-Express 2.0, lacking PCI-Express 3.0 support. Its TDP is rated at 65W.
http://www.techpowerup.com/162683/Intel-quot-Ivy-Bridge-quot-Pentium-G2120-Arrives-in-Q4-2012.html
Portioli
3 June 2007
3,892
Dystopia
A Brief Look at Some Upcoming 7-Series Motherboards
Chipset Comparison
Z77Z75H77Z68P67H67
CPU SupportIVB
LGA-1155
IVB
LGA-1155
IVB
LGA-1155
SNB/IVB
LGA-1155
SNB/IVB
LGA-1155
SNB/IVB
LGA-1155
2 x8 or
1 x8 + 2 x4
PCIe 3.0
1 x16 or
2 x8 PCIe 3.0
2 x8 or
1 x8 + 2 x4
PCIe 3.0
1 x16 or
2 x8 PCIe 3.0
1 x16 PCIe 3.0
RAID SupportYesYesYesYesYesYes
SATA Total (Max Number of 6Gbps Ports)6 (2)6 (2)6 (2)6 (2)6 (2)6 (2)
lykman
29 June 2006
5,798
Aθήνα
Portioli και λοιποί που είσαστε???
http://www.anandtech.com/show/5773/intels-ivy-bridge-an-htpc-perspective
Να τα πω, ή να τα διαβάσετε μόνοι σας? (να ενημερώσουμε και το τόπικ με τις κάρτες γραφικών μόλις επιβεβαιωθούν τα λεγόμενα της Ιντελ...)
Αντε δεν κρατιέμαι:
Discrete HTPC GPUs are necessary only if one has plans to upgrade to 4K in the near term. Otherwise, the Ivy Bridge platform has everything that a HTPC user would ever need.
23,976:
How does Ivy Bridge fare? The short story is that the behaviour on the P8H77-M Pro board is very similar to Sandy Bridge. As the screenshot below shows, the refresh rate is quite stable around 23.973 Hz. This is as good as the bad AMD and NVIDIA GPU cards.
The good news is that Intel is claiming that this issue is fully resolved in the latest production BIOS on their motherboard. This means that BIOS updates to the current boards from other manufacturers should also get the fix
Γενικότερα πάντως, σήμερα έσκασαν μύτη τα reviews των τετραπύρηνων Ivy...
vas_papavas
21 December 2010
8,849
σήμερα είναι και η πρώτη μέρα κυκλοφορίας τους στην αμερική.
kernel panic
18 November 2008
970
Κεφαλλονιά
πολύ ζέστη κάνει όμως ρε παιδιά
πολύ ζέστη λέμε
καλά έκανες vas και δεν περίμενες, δεν το βλέπω το 20% καλύτερο της Intel με τπτ
το tdp δεν μου λέει κάτι με τέτοιες θερμοκρασίες, άσε που με o/c κοντά είναι
vas_papavas
21 December 2010
8,849
kernel στην αναμονή είμαι. το ποστ του i7 στα 5.5 ήτανε 1 απριλίου :ernaehrung004: o q6600 ήτανε με 800χ400 στο svp για να τερματίσω ρυθμίσεις.
τον θέλω για svp και θα παω μάλλον σε fx8120. παει στα 3.6 τoυ 8150 και στο svp είναι σαν i7-2600k. πρόσεξε στο svp μόνο γιατί το τόνισα και στο thelab. και άναψε 1 flame αλλο πράγμα. κατά τα άλλα ακόμη και o ι5 -2500K τον πατάει κάτω.
βέβαια μετά το πάσχα ο i7 έχασε 30 ευρώ.
αυτή τη στιγμή ο 8120 με μια 990 ερχεται στα 270 περίπου με καλύτερη μητρικη από 1155 και ο i7 στα 370 με entry level z68.
αναμένω παιδικές ασθένεις λόγω 22. τα ίδια με τον i7 -920 c0 και d0
kernel panic
18 November 2008
970
Κεφαλλονιά
όχι vas μην το κάνεις αυτό
μην δίνετε λεφτά στους ηλίθιους του amd
ψεύτες και ζούνε αποκλειστικά για τους gamers πλέον
που είναι οι εποχές phenomII !
* φτου το πίστεψα
vas_papavas
21 December 2010
8,849
μαζί σου με χίλια. μεγάλη πατάτα με μεγάλη κατανάλωση. αλλά για την δουλεια που τον θέλω είναι ταμαμ. το svp θέλει πυρήνες. οι ivy απότι διαβάζω πάνε για ιούνιο ελλάδα.
tmjuju
Administration Team
21 January 2007
21,651
Αντε δεν κρατιέμαι:
23,976:
Καλή φάση, μακάρι όντος να δούμε αυτά τα BIOS updates.
Διαφορετικά θα είναι δύσκολο να ξέρεις ποιά Motherboard κλειδώνει καλά. Μετά από ποίο BIOS κ.ο.κ. Μεγάλο μπέρδεμα.
Μια λέμε ότι είναι hardware το πρόβλημα, που για τις HD4000 δε πρέπει να ισχύει.
Την άλλη τα ρίχνουμε στην ομάδα drivers της intel _ εκεί έχουμε διάφορα παράπονα.
Τώρα λένε για BIOS, πιθανά, BIOS και drivers να είναι λύση.
tmjuju
Administration Team
21 January 2007
21,651
Με ένα μεγάλο κουτί HTPC στιβαρό σα τα Silverstone που φοριούνται πολύ και καλή ψήκτρα
Μια χαρά htpc φτιάχνουμε και ήσυχο ανεξάρτητα εάν ο επεξεργαστής είναι 90w ή ακόμα και παραπάνω.
Σίγουρα είναι ακριβή λύση για htpc σε σχέση με atom/fusion αλλά την έξτρα δύναμη κανείς δε τη μίσησε
naxian
30 October 2007
1,091
με τον 2500Κ και τις καινουργιες μητρικες εχω hd4000 η hd3000???
tmjuju
Administration Team
21 January 2007
21,651
http://ark.intel.com/products/52210
hd3000
πάντως δε βλέπω ούτε το anandtech να διευκρινίζει το τι ακριβώς παίζει με τις Intel hd*
τάζει upgrades για BIOS/motherboars αλλά χωρίς καμία άλλη λεπτομέρεια, λίγο θετικό marketing δηλαδη ΙΜΗΟ…
