Panasonic LUMIX Box-Style Camera DC-BGH1
kbouk
8 January 2010
22,215
ΠΕΙΡΑΙΑΣ
Improvements
Date/VersionDescription
Nov. 4, 2021
Ver.2.3
  1. RAW video data output over HDMI to Blackmagic Video Assist 12G HDR
    - [4K] / [Anamorphic (4:3) 3.7K] 12-bit RAW video data can be output over HDMI to Blackmagic Video Assist 12G HDR, to be recorded as Blackmagic RAW.
    * All functions may not be available depending on the situation.
    * DaVinci Resolve or DaVinci Resolve Studio is required to play back the Blackmagic RAW data.
    DaVinci Resolve Studio is required to edit the Blackmagic RAW data.
  2. Expanded compatibility with DJI Gimbal
    - Active Track Function of DJI Gimbal "DJI RS 2" and "DJI RSC 2" can be used.
    For details, please check the DJI official announcement.
    · DJI RS 2 Release Notes
    · DJI RSC 2 Release Notes
  3. Added functions
    - [Focus Ring Control] function has been added.
    - It is possible to assign [HDMI RAW data output] function to the Fn button and users can directly turned it ON or OFF from the camera.
    - [Photo Style] function for still image shooting has been added.
    - Zoom operation of the LUMIX G power zoom lenses can be controlled from LUMIX Tether for Multicam.
    * The firmware of LUMIX Tether for Multicam software is also required to be updated to Ver.1.3 or higher.
Operating Instructions for the Change of Specifications
Kosh
7 September 2006
91,112
Εκεί ψηλά.....
Recommended settings
Among the most important settings, Netflix reasonably suggests the following in order to obtain the maximum image quality and flexibility in post:
  • A resolution of 4096×2160 or 3840×2160
  • Full-frame or S35mm modes with 1:1 pixel sampling
  • Use of V-Log, with 18% middle gray exposed at 42 IRE
  • 4:2:2 chroma subsampling
  • 10-bit color depth (Netflix only accepts 12-bit RAW or 10-bit Log footage)
  • ALL-I recording
  • A bitrate of 400Mbps
  • Turn off diffraction compensation, noise reduction, sharpening, and vignetting compensation
evanfotis
26 March 2008
5,475
E-Stabilization (Video)
Not available when the following functions
are in use:
- 6K/5.9K/5.4K video
- Variable Frame Rate (VFR) mode
- HDMI RAW Output
Ενδιαφέρον... Στα φορμάτ που θέλει κανείς η ηλεκτρονική σταθεροποίηση δεν λειτουργεί;...
Παρα μονο σε 4Κ κροπάροντας και μειώνοντας ποιότητα...
Επίσης, παίρνει "πιστοποίηση" ενω τραβά σε 4:2:0;
Large Format 3:2→6K/24p/420/10-L
Academy 4:3→ 4K-A/48p/420/10-L
