Re: pionner 427XD
Δοκιμασε αυτο (δεν ξερω αν σου κανει σιγουρα):
* Switch to normal TV, through an aerial (you do not need one connected), by pressing a channel on your remote - say channel 2. Note that this does not work if you put it in standby from an input source, you must switch it to TV - even if you don't have an aerial connected - and then put it in standby for this to work.
* Put the plasma and the media box is in standby.
* Press and release the following button:
* 435XDE/505XDE/436FDE/506FDE: Display/Info button below 4 button
* 436XDE: Display/Info button below 9 button
* 436SXE/436RXE: TV/External input mode button (i+) below 7 button
* wait for 3 seconds
* press Left, Up, Left, Right, Power On to get the INFORMATION page.
It may take several attempts before you get into the service menu.
so for you, as you have the xde:
press the 'tv/dtv' button in the middle of the remote until you are watching analogue tv (has to be analogue, doesn't work with digital), turn the tv off, press the 'info' button below 9, wait 3 seconds, press 'left' 'up' 'left' 'right' in that order and then power the tv on again. it should come straight up. timing is critical, the first time i did it, it took me about 20 attempts before it worked.
