IMAGE FOR DM8000HD PVR!!!!
dreambox-image-dm8000-20090124035215.nfi
md5: 018ab19174ecaa1c8b0d38d8e30c6ed7
OE Build Configuration:
BB_VERSION = "1.8.12"
METADATA_BRANCH = "experimental"
METADATA_REVISION = "90cfc96e8cf690961d6033be9b89d2b16b038b71"
TARGET_ARCH = "mipsel"
TARGET_OS = "linux"
MACHINE = "dm8000"
DISTRO = "opendreambox"
DISTRO_VERSION = "1.6.0"
TARGET_FPU = "soft"
ruDREAM team & Orbitasat presents the new INNOVATIVE IMAGE for DM800HD PVR - ruDREAM Infinity!!!
ruDREAM Infinity - no more windows and borders in images!!!
This image for DM8000HD PVR based on standard еnigma2 image, with many changes and patches from ruDREAM team.
ruDREAM Infinity presents the revolutionary New Graphic Interface (skin) with new design, with scrolling lines in menus and lists, when showed info is bigger than current fields, and using original solution for cursors to navigate in lists and menus and many other interesting things. We decide to use only HD skins in our images (1280x720) as more perspective and nice.
TARGET_OS = "linux"
MACHINE = "dm8000"
TARGET_FPU = "soft"
Some info about image:
Standard infobar, show You info about current channel, now and next event (with scrolling lines in description) picons and info-icons about stream, provider name and orbitral position (last function is switchable on/off in customize menu)
Extended infobar - resolution, current transpoder data (signal quality in db, BER, Frequency, SR, FEC, Polarisation, CAM info, Info about coding)
You can have Extended infobar always on, by swithching it on/off in customize menu.
Function Keys:
1 x OK - Standard infobar
1 Long Press OK - Extended infobar
1 х BLUE – CAMMD MANAGER
1 Long Press Blue – Extentions
RED – Select Record Mode
Yellow - Timeshift
1 x TEXT - Teletext
1 Long Press TEXT – Subtitles Selection
Downloading Updates, Plugins and Extentions from IPKG MANAGER
ATTENTION!!!
For now some Extentions are not adapted yet for usage in our image. If downloaded Extention dont start or crash enigma2, please be patient and check time to time for adapted version in Download Manager.
All Extentions will be adapded asap.
VERY IMPORTANT!!!!!!!!!
Because of many unique changes in image no ANY SKIN from other sources is compatible with this image!!!!!!!!!
We hope that You will like our skin and very soon our friends skin makers will release other skins for ruDREAM Infinity!!!
many thanks to all team and our betatesters - nixus, tenten78 & satrobihood
List of adapted plugins:
FileManager
MovieCut
MovieRetitle
MovieTagger
LogoManager
TagEditor
DVDPlayer
MediaScanner
StartupToStandby
UnwetterInfo
AutoTimer
EPGRefresh
ZapHistoryBrowser
PasswordChanger
FritzCall
DynDNS
PermanentClock
VlcPlayer
YouTubePlayer
GoogleMaps
DiSEqC Testter
SatelliteEquipmentControl
Autoresolution
Bitrate
CCcamInfo
DreamExplorer
MediaCenter
Suomipoeka
Sgc
Sherlock
Webinterface
Netcaster
LastFM
RSdownloader
HTTPproxy
DVDburn (DM8000)
CDinfo(DM8000)
