- 29 October 2008
- 8,982
65"...[geex.x-kom.pl]...Sony XR-65X95K review..https://geex.x-kom.pl/recenzje/test-i-recenzja-sony-65x95k/
The tv was produced in May 2022, and a test copy was provided by the manufacturer himself.
VA panel + viewing angle compensation film
Direct backlighting
FALD mini LED LCD
100/120Hz με MCFI
Wide colour gamut DCI-P3 (CIExy) space coverage : 94%
During the test, I identified 36 zones horizontally and 12 vertically, for a total of 432 independent zones.
Another advantage of Sony 65X95K is the brightness in full-screen mode, which amounted to 728 cd/m² (nits).
Therefore, the light conversion takes place not on the diode, but outside it (in the so-called QDEF foil).
In short, in the 2022 TV range, Sony has... "QLED TV". And, of course, he keeps this fact a secret.
It is important to keep in mind that any multi-zone backlight is a compromise and will never show 100% of the image intended by the creator.
Designers must choose whether they prefer deep blacks or maintaining the original brightness.
Sony chose the latter option.
I respect this choice and I am aware of the advantages of this solution.
On the other hand, I also saw rivals who in their algorithms put on deep blacks at the expense of reducing the original brightness.
As I have already mentioned, no solution is perfect and will have its supporters and opponents.
Of course, OLED tvs are a way out, but they also get short of breath in bright scenes, not to mention losing details in the shadows.
Who knows, perhaps the solution would be for Sony (as well as competitors) to add an additional option in the menu, which would indicate to algorithms what the viewer prefers.
I mean:
HDR : The Revenant (2015)
SPD
65"...[clubic.com]...Sony Bravia XR-65X95K test...https://www.clubic.com/pro/entreprises/sony/test-produit-440724-test-sony-xr-65x95k.html
Direct backlighting
FALD mini LED LCD
100/120Hz με MCFI
- in its history, Sony has offered tvs with a higher number of zones – for example, the excellent 65ZD9 model from 2016 had as many as 646.
I mean:
- Preserving the original brightness (luminance preference);
- Black Preference.
SPD
