Τι δεν κατάλαβα καλά?
Magellan
Banned
28 July 2006
19,085
Εν πλώ
Ο λόγος για το νέο universal player Metis30 Goldmund..
(Από εδώ μπορείτε να κατεβάσετε το manual σε μορφή pdf.)
Ολα καλά....Aλλά γιατί $16000?
Goldmund Metis 30 is equipped with an Oppo player that is compatible with the following formats:
High Definition (HD) movie and music discs High Definition (HD) movie and music discs High Definition (HD) movie and music discs High Definition (HD) movie and music discs
BD-ROM and BD-RE/BD-R discs in BDMV and BDAV mode, including 8cm discs.
Discs supporting BONUSVIEW (BD-ROM version 2 Profile. 1 version 1.1/Final Standard Profile) that allows Virtual packages or Picture-in-Picture functions to be used.
Discs supporting BD-Live (BD-ROM version 2 Profile 2) that provides interactive features when the player is connected to the Internet.
High quality movie and music discs.
Commercially released DVD discs, DVD+RW/DVD+R/DVD-RW/DVD-R in DVD-Video format, finalized.
Multi-channel or stereo high resolution audio with compressed digital video or still pictures. Some DVD-Audio discs also contain a DVD-Video portion.
SACD: High resolution audio-only disc with stereo and/or multi-channel audio.
Hybrid disc with both high resolution and CD-compatible layers.
Compact Discs (CD) that contain audio tracks.
High-definition digital video camera format using efficient data compression coding technology.
TECHNICAL SPECIFICATIONS
COMPATIBILITY
BD-VIDEO, DVD-Video, DVD-Audio, AVCHD, SACD, CD, HDCD, Kodak Picture CD, CD-R/RW, DVD±R/RW, DVD±R DL, BD-R/RE
BD Profile:
BD-ROM Version 2.4 (also compatible with Profile 1 Version 1.0 and 1.1)
OUTPUT
Analog Audio: stereo Right & Left
Digital Audio: Coaxial, Optical.
HDMI Audio: Stereo, up to 7.1ch high-resolution PCM, up to 5.1ch DSD, bitstream or LPCM conversion of Dolby Digital, Dolby Digital Plus, Dolby TrueHD
DTS, DTS-HD High Resolution Audio, and DTS-HD Master Audio.
Digital Video: HDMI with HDCP (NTSC480i/480p/720p/1080i/1080p/1080p24,PAL 576i/576p/720p/1080i/1080p/1080p24)
AUDIO CHARACTERISTICS
Frequency: 20Hz – 20kHz (-0.3 ±0.05
Signal-to-Noise Ratio: >110dB (A-we
THD+N: < 0.002% (1kHz at 0dBFS, 2
POWER
Power Supply: ~ 100V – 240V, 50/60
Power Consumption: 35W (0.5W Standby)
SIZE AND WEIGHT
440 W x 300 H x 70 D (mm). 5.5 kg.
supersonic
49,351
μια χαρά τα κατάλαβες.
Πάρε ένα οπο σε τιμη γκολντμουντ...
(άλλωστε το λέει και η λέξη, τυχαία το διάλεξαν το όνομα ?)
supersonic
49,351
πάντως είναι μια πρόοδος.
Παλιά μέσα είχε φτηνα pioneer...
Τώρα έχει state of the art oppo....
(με sabre μέσα)
10 July 2006
5,257
Απάντηση: Re: Τι δεν κατάλαβα καλά?
(με sabre μέσα)
όπως το βουβάλι έ;
(κάπταιν, φιρί-φιρί το πήγαινες :flipout: :flipout::flipout: -bye-)
10 July 2006
5,257
Απάντηση: Re: Απάντηση: Re: Τι δεν κατάλαβα καλά?
από το στόμα μου το πήρες, άτιμε...
Να σου ετοιμάσω ένα άλλο πουλίμ' :
Κάπταιν, αφού το λέει τόνοματ', μπρε:
Γκόλντμουν => Θα τό'χει χρυσό φαίνεται
:flipout::flipout:
Magellan
Banned
28 July 2006
19,085
Εν πλώ
όπως το βουβάλι έ;
Ντεν ξέρει βουβάλι...δεν θέλω βουυυβααλι Χρώμα βουβαλί και μαλλί
λύκου....Βουβαλοδαρμενα Υψη...
..Που είναι αυτό το ανάποδο άσπρο σακάκι που φόραγα το πρωί....
Δημήτρης Δ.
21 June 2006
5,455
16000 φάπες τους χρειάζονται.
(*) Ξερουμε ποιό είναι το Οππο που αντιγράφουν?
more peers
24 April 2009
20,155
Captain πρώτα απ'όλα δεν ξέρουμε αν έχει την ίδια υλοποίηση dac. Το γεγονός ότι φοράει sabre, απο μόνο του δεν λέει πολλά.
Σίγουρα δεν φοράει το audioboard και την τροφοδοσία του oppo 95 (1000$), σίγουρα θα έχει προσεχθεί το σασί και οι αποσβέσεις, σίγουρα θα έχουν βάλει το χεράκι τους (πχ είναι region free by default).
Κατα τα άλλα δεν δίνει 7/1 αναλογικές εξόδους, οπότε σε πολυκάναλο ήχο η αξία του παίζει να είναι ακριβώς ίδια με το oppo93, δηλ500$ και δεν λένε κουβέντα για δικτυακή αναπαραγωγή.
(Άσε που το power socket μοιάζει πολύ με αυτό που πήρα για το βουβάλι και κοστίζει 3Ε... και απλά αλλάξαν ταμπελάκι στο rc της oppo!!!)
Παρότι δεν έχουμε πληρη spec και αξιολόγηση-μετρήσεις... τολμώ να πω μακριά και αλάργα... άλλη μια περίπτωση αναζήτησης κορόιδων ή επιδειξιών.
Magellan
Banned
28 July 2006
19,085
Εν πλώ
Re: Απάντηση: Τι δεν κατάλαβα καλά?
Σίγουρα δεν φοράει το audioboard και την τροφοδοσία του oppo 95 (1000$), σίγουρα θα έχει προσεχθεί το σασί και οι αποσβέσεις, σίγουρα θα έχουν βάλει το χεράκι τους.
Κατα τα άλλα δεν διαθέτει 2 hdmi (που θα απαιτούσαν 2 video chips) δεν δίνει 7/1 αναλογικές εξόδους, οπότε σε πολυκάναλο ήχο η αξία του παίζει να είναι ακριβώς ίδια με το oppo93, δηλ500$ και δεν λένε κουβέντα για δικτυακή αναπαραγωγή.
(Άσε που το power socket μοιάζει πολύ με αυτό που πήρα για το βουβάλι και κοστίζει 3Ε...)
Παρότι δεν έχουμε πληρη spec και αξιολόγηση-μετρήσεις... τολμώ να πω μακριά και αλάργα... άλλη μια περίπτωση αναζήτησης κορόιδων.
Πιό σασί βρε?..Ποιές αποσβέσεις?
5,5 κιλάκια ζυγίζει!
Φτερνίζεσαι και φεύγει από το ρακ!
Magellan
Banned
28 July 2006
19,085
Εν πλώ
Όσο πιο ελαφρύ τόσο πιο εύκολο στους κραδασμούς, captain.
Πιό ευάλωτο στους κραδασμούς θες να πεις Νικόλα...Μετά τα 115db το βρίσκεις σε άλλη πόζα!
more peers
24 April 2009
20,155
Αυτό λέω. Το "πιάνει θάλασσα" πιο εύκολα. Άρα θέλει μεγαλύτερη επέμβαση.
(δεν λέω βέβαια ότι αυτό έχει γίνει στο συγκεκριμένο! :Banane0:)
Tzimisce
Administration Team
1 February 2007
33,093
127.0.0.1
Να σου δώσω ένα Digital που μου έχει περισσέψει;
Λίγο χοντρό να είναι το καλώδιο ρεύματος αποκτάει την τέλεια αντικραδασμική προστασία! Στέκεται σούζα στον αέρα! :flipout:
Ρε μήπως να φτιάχναμε και εμείς κανένα να γινόμασταν πλούσιοι εις υγείαν των κορόιδων; :p
